globus worries
Robert Olson
olson at mcs.anl.gov
Thu Jan 29 18:07:17 CST 2004
Drat, here are the files.
--bob
At 06:01 PM 1/29/2004, Robert Olson wrote:
>I determined today that we've not actually been getting encryption on our
>globus data connections, only the default of integrity checking, despite
>the easy misreading of the docs that would imply that GSS_WRAP means
>encrypted connections.
>The larger problem is that it appears that under the old winglobus turning
>on encryption causes authentication errors.
>Can someone with a pyGlobus built against the latest winglobus please try
>the attached client and server? just run testserv.py, then testcli.py on
>the same machine.
>thanks,
>--bob
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040129/25d8ce70/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20040129/25d8ce70/attachment-0001.obj>
