IPv6
Robert Olson
olson at mcs.anl.gov
Wed Apr 14 10:56:57 CDT 2004
At 05:07 PM 4/13/2004, Caren Litvanyi wrote:
>The 2621 will do v6. I'd need to compare its performance capabilities
>with your needed average packet-per-second rate, though. I bet it
>is not able to handle much, but I am not sure.
>The question is, who do you want to talk to? If you literally only
>want *within* a lab, no router is needed. We create a vlan for you,
>and you play in that isolated vlan sandbox. The switches won't care.
>When you want to test v6 AG (or any other app), with another site,
>well, then we have some planning and work to do. Getting from here
>to there is what requires infrastructure upgrades, or, for the short-
>term, engineering around the problem in one of several ways.
>Also, don't forget infrastructure issues like supporting v6 in DNS.
The first step would be to be able to talk v6 between a set of hosts
locally, and unicast v6 to hosts externally.
I wonder how painful it is to use v6 without DNS..
--bob
