AG 2.0 memory leak?
Ivan R. Judson
judson at mcs.anl.gov
Wed Sep 3 11:04:28 CDT 2003
The SOAP patch was in before the 2.0 release, so you should have a patched
copy from cvs. It'd be really helpful if you filed this with bugzilla and
definitely included your logs. Then if you happen to discover behavior that
causes this you could annotate the bug; and we'll be able to keep it open in
bugzilla until we confirm it's solved.
--Ivan
-----Original Message-----
From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On Behalf
Of Terry Disz
Sent: Wednesday, September 03, 2003 10:49 AM
To: 'Thomas D. Uram'
Cc: ag-dev at mcs.anl.gov
Subject: RE: AG 2.0 memory leak?
Tom,
How far back was that SOAP patch made? I have a server from just before the
last release. Maybe that's all that's wrong here.
The process does seem to be slowly but steadily growing, I'll keep an eye on
it all day.
Terry
Sent: Wednesday, September 03, 2003 10:40 AM
To: Terry Disz
Subject: Re: AG 2.0 memory leak?
I know the SOAP implementation leaked memory a while back, but that's been
patched. Also, I've seen the process size grow, but it has always
retreated. Are you seeing it steadily grow?
Terry Disz wrote:
Um, of course the process manager gives memory in k bytes, not bytes, that's
what I meant - growth by 4k, 8k, etc.
Terry
Of Terry Disz
Sent: Wednesday, September 03, 2003 10:07 AM
To: ag-dev at mcs.anl.gov
Subject: AG 2.0 memory leak?
I am running a server locally, no clients attached to it and it is slowly
growing. It grows in various increments, I have seen 4 bytes, 8 bytes and 12
so far. I t grows every few minutes or so.
Has anyone monitored the server for this behavior? Is it normal? Do we
already know about this?
Terry
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030903/fbc90ef5/attachment.htm>
