AG 2.0 memory leak?
Terry Disz
disz at mcs.anl.gov
Wed Sep 3 11:16:11 CDT 2003
I'll keep an eye on it today, like I said, there is no activity or
behavior against it. I was just wondering if this was new or what.
Later today I'll look around for log files.
-----Original Message-----
From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
Sent: Wednesday, September 03, 2003 11:04 AM
To: 'Terry Disz'; 'Thomas D. Uram'
Cc: ag-dev at mcs.anl.gov
Subject: RE: AG 2.0 memory leak?
The SOAP patch was in before the 2.0 release, so you should have a
patched copy from cvs. It'd be really helpful if you filed this with
bugzilla and definitely included your logs. Then if you happen to
discover behavior that causes this you could annotate the bug; and we'll
be able to keep it open in bugzilla until we confirm it's solved.
--Ivan
From: owner-ag-dev at mcs.anl.gov [mailto:owner-ag-dev at mcs.anl.gov] On
Behalf Of Terry Disz
Sent: Wednesday, September 03, 2003 10:49 AM
To: 'Thomas D. Uram'
Tom,
How far back was that SOAP patch made? I have a server from just before
the last release. Maybe that's all that's wrong here.
The process does seem to be slowly but steadily growing, I'll keep an
eye on it all day.
Terry
Sent: Wednesday, September 03, 2003 10:40 AM
To: Terry Disz
Subject: Re: AG 2.0 memory leak?
I know the SOAP implementation leaked memory a while back, but that's
been patched. Also, I've seen the process size grow, but it has always
retreated. Are you seeing it steadily grow?
Terry Disz wrote:
Um, of course the process manager gives memory in k bytes, not bytes,
that's what I meant - growth by 4k, 8k, etc.
Terry
Sent: Wednesday, September 03, 2003 10:07 AM
To: ag-dev at mcs.anl.gov
Subject: AG 2.0 memory leak?
I am running a server locally, no clients attached to it and it is
slowly growing. It grows in various increments, I have seen 4 bytes, 8
bytes and 12 so far. I t grows every few minutes or so.
Has anyone monitored the server for this behavior? Is it normal? Do we
already know about this?
Terry
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030903/3a7c1ce2/attachment.htm>
