[Fwd: FW: URGENT CALL for Access Grid Expertise from PRAGMA site (fwd)]
Thomas Uram
turam at mcs.anl.gov
Thu May 22 21:38:33 CDT 2003
Hi Steven:
I'm sure you could configure your system to start the VenueClient at
startup. But you should note that the proxy may have to be renewed at
startup, so the process probably can't be entirely automatic.
We do have plans to develop/integrate a whiteboard as a shared
application on top of AG2. We've talked about this the same way you
describe, as shared markup of images. I am interested in your solution.
If you have any questions about integrating it into AG2, let us know.
Let me know how things are going, and if there's any way we can help.
Tom
Steven Shiau wrote:
>Hi! Tom:
>We spent a lot time to deploy the hardware system, so did reply you
>immediately.
>I think you are right, our concerns are related to the initial hurdle of
>getting the system configured. That should be done by us, once it's ok,
>doctors should be able to use that. Now, if the configuration is ok, is
>that possible to automatically start AG 2.0 client when the Linux
>machine startup ? I think for doctors, what they want is specific
>purpose. If we can do that, that would be easier for them to use.
>By the way, is there any plan to put "whiteboard" function in AG 2.0 ? I
>did not see it in Linux version. We just implement the function to have
>X-ray photo shown, and let users to draw and mark notes on that photo.
>But it's not in AG, we just use VIC and RAT. It's written in TCL/TK. We
>will try to put it into AG 2.0, if we need some help, I will let you know.
>Steven.
>Thomas Uram wrote:
>> Steven:
>>I think many of your concerns about ease of use are related to the
>>initial hurdle of getting the system configured. Once the user's
>>certificate is in place and the node has been configured with video and
>>audio, operation becomes relatively simple. We are trying to make the
>>software easy to use; please let us know what things you find difficult
>>to use, or you think the doctors would find difficult to use, and how
>>you think they could be improved.
>>As for RedHat 9, you do need to use the pyopenssl rpm that we are
>>distributing. Beyond that, we have done some testing of RedHat 9, but
>>as far as I know, this is still in process.
>>Tom
>>Steven Shiau wrote:
>>>Tom:
>>>By the way, is that possible to find someone to modify the UI or the
>>>script ? You know, it's not easy for doctors in hospital to use it.
>>>Now there are some steps they have to fill in GUI, select some
>>>functions, so it's not easy for us to write some scripts to run it. And
>>>we guys are not familar with the AG 2.0 source, it takes time if we want
>>>to modify the code.
>>>Another thing, the AG 2 RC1 now only works for Redhat 7.3 ? We tried
>>>it in Redhat 9.0, but some errors. My colleague did a quick servey,
>>>found that it seems we use the "pyopenssl" provided by ANL, not by the
>>>distributed, then it shold be ok. Is that right ?
>>>Thanks.
>>>Steven.
>>>Thomas Uram wrote:
>>>>Hi Steven:
>>>>Can you let us know your status on working with the cvs version of AG2?
>>>>We are ready to help and answer any questions you might have.
>>>>Tom Uram
>>>>Steven Shiau wrote:
>>>>>I just check out the CVS version of AG 2.0, and see the INSTALL and install.linux files in CVS, but it seems there is no installation note for CVS version.
>>>>>Could someone tell me where I can find the doc or tell me how to do it ?
>>>>>Thanks.
>>>>>On Sat, May 17, 2003 at 08:22:04PM -0500, Thomas Uram wrote:
>>>>>>Can we get the names for the other machines? And if the login
>>>>>>information is any different, please include that, too.
>>>>>>Thanks,
>>>>>>Tom Uram
>>>>>>ANL/FL/AccessGrid
>>>>>>630-252-4596
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030522/ff9ef549/attachment.htm>
