transfer server
Robert Olson
olson at mcs.anl.gov
Thu Feb 20 16:31:37 CST 2003
the refactored transfer server should do what you want now. I'm waiting to
commit changes until ivan gets his fixes in, but here is what the code will
sort of look lke (from teh bottom of the datastore module).
What you'd do is define a handler class that answers GetDownloadFilename
with the pathname of the things you want to export. The URLs to those
things are generated by calling the GetDownloadDescriptor method on the
transfer server. You'll need to register a prefix for your downloads like I
do below.
If you have CanUploadFile return 0 and GetUploadFilename returnm, upload
attempts will fail.
--bob
s = GSIHTTPTransferServer(('', 9011))
class Handler:
def GetDownloadFilename(self, id_token, url_path):
print "Get download: id='%s' path='%s'" % (id_token, url_path)
return r"c:\temp\junoSetup.exe"
def GetUploadFilename(self, id_token, file_info):
print "Get upload filename for %s %s" % (id_token, file_info)
return os.path.join("c:\\", "temp", "uploads", file_info['name'])
def CanUploadFile(self, id_token, file_info):
print "CanUpload: id=%s file_info=%s" % (id_token, file_info)
return 1
def AddPendingUpload(self, id_token, filename):
print "AddPendingUpload: %s %s" % (id_token, filename)
def CompleteUpload(self, id_token, file_info):
print "CompleteUpload %s %s" % (id_token, file_info)
prefix = "test"
s.RegisterPrefix(prefix, Handler())
print s.GetDownloadDescriptor(prefix, "JunoSetup.exe")
print s.GetUploadDescriptor(prefix)
s.run()
try:
while 1:
time.sleep(.1)
except:
os._exit(0)
