transfer server
    Robert Olson
    olson at mcs.anl.gov
    Thu Feb 20 16:34:53 CST 2003
oh, and you can use the DataStore.GSIDownloadFile(url, destination_file,
size, checksum) function to effect the download. See the new
AccessGrid/tests/test_datastore_{put,get}.py.
--bob
At 04:31 PM 2/20/2003 -0600, Robert Olson wrote:
>the refactored transfer server should do what you want now. I'm waiting to
>commit changes until ivan gets his fixes in, but here is what the code
>will sort of look lke (from teh bottom of the datastore module).
>What you'd do is define a handler class that answers GetDownloadFilename
>with the pathname of the things you want to export. The URLs to those
>things are generated by calling the GetDownloadDescriptor method on the
>transfer server. You'll need to register a prefix for your downloads like
>I do below.
>If you have CanUploadFile return 0 and GetUploadFilename returnm, upload
>attempts will fail.
>--bob
>     s = GSIHTTPTransferServer(('', 9011))
>     class Handler:
>         def GetDownloadFilename(self, id_token, url_path):
>             print "Get download: id='%s' path='%s'" % (id_token, url_path)
>             return r"c:\temp\junoSetup.exe"
>         def GetUploadFilename(self, id_token, file_info):
>             print "Get upload filename for %s %s" % (id_token, file_info)
>             return os.path.join("c:\\", "temp", "uploads", file_info['name'])
>         def CanUploadFile(self, id_token, file_info):
>             print "CanUpload: id=%s file_info=%s" % (id_token, file_info)
>             return 1
>         def AddPendingUpload(self, id_token, filename):
>             print "AddPendingUpload: %s %s" % (id_token, filename)
>         def CompleteUpload(self, id_token, file_info):
>             print "CompleteUpload %s %s" % (id_token, file_info)
>     prefix = "test"
>     s.RegisterPrefix(prefix, Handler())
>     print s.GetDownloadDescriptor(prefix, "JunoSetup.exe")
>     print s.GetUploadDescriptor(prefix)
>     s.run()
>     try:
>         while 1:
>             time.sleep(.1)
>     except:
>         os._exit(0)
