Getting Started doc
Thomas Uram
turam at mcs.anl.gov
Thu Feb 20 12:26:31 CST 2003
Hi Jennifer:
You might remember that we met at SC02. I'm working on AG2 development
at ANL.
I made the following changes to the "getting started" doc, and attached
a copy. Also, I have the following questions:
- Did you have to install python and ActivePython?
- Encryption should be working; if it's not, please file a bug report.
- What kind of information is the VenueClient asking for in minimized
windows? That's definitely not intentional behavior.
* Changes
- Changed "Venue Client GUI" to "Node Management GUI" where you "Attach
to Node" and "Add Host"
- Re-ordered "Node Management" and "Venue Client" sections: the node
should be
configured before the venue client enters a venue, to avoid the problem
of having to re-enter after configuring the node (so that comment has
been removed.)
Thanks for putting this doc together.
Tom
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-dev/attachments/20030220/fddbecec/attachment.txt>
