[Swift-commit] r7866 - in SwiftApps/swift-galaxy/swift: . old
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon May 12 14:45:47 CDT 2014
Author: ketan
Date: 2014-05-12 14:45:46 -0500 (Mon, 12 May 2014)
New Revision: 7866
Added:
   SwiftApps/swift-galaxy/swift/old/swiftforeach.sh
   SwiftApps/swift-galaxy/swift/old/swiftforeachlist.py
   SwiftApps/swift-galaxy/swift/old/swiftforeachrange.py
   SwiftApps/swift-galaxy/swift/old/swiftforeachrange.sh
   SwiftApps/swift-galaxy/swift/old/test_exec/
Removed:
   SwiftApps/swift-galaxy/swift/swiftforeach.sh
   SwiftApps/swift-galaxy/swift/swiftforeachlist.py
   SwiftApps/swift-galaxy/swift/swiftforeachrange.py
   SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
   SwiftApps/swift-galaxy/swift/test_exec/
Log:
clean
Copied: SwiftApps/swift-galaxy/swift/old/swiftforeach.sh (from rev 7862, SwiftApps/swift-galaxy/swift/swiftforeach.sh)
--- SwiftApps/swift-galaxy/swift/old/swiftforeach.sh	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/swiftforeach.sh	2014-05-12 19:45:46 UTC (rev 7866)
@@ -0,0 +1,282 @@
+#!/bin/bash
+# originally list
+#echo $@ > /tmp/args.txt
+#set workdir
+wdir=$(mktemp -d /tmp/swift-gal.XXXX)
+#determine loop mode: over a list or a range
+range_or_list=$1
+shift
+#determine invocation: Swift /K or /T
+k_or_t=$1
+shift
+#build commandline arguments
+sites=$1
+shift
+swiftargs=$1
+shift
+interpreter=$1
+shift
+executable=$1
+shift
+stdin=$1
+shift
+if [ "$range_or_list" = "list" ] ; then
+    listfile=$1
+    shift
+    n=$(wc -l < $listfile)
+else
+    rstart=$1
+    shift
+    rend=$1
+    shift
+    stepsize=$1
+    shift
+    n=$(( ($rend - $rstart) / $stepsize ))
+fi
+outloc=$1
+shift
+logfile=$1
+shift
+outlistfile=$1
+shift
+stringargs=$1
+shift
+swift=$(\which swift 2>/dev/null)
+BASEDIR=$(dirname $0)
+#workout the file args
+fileargs=()
+while [ $# -gt 0 ] ; do
+  fileargs+=("\"$1\"")
+  shift
+done
+#create outloc dir
+mkdir -p $outloc
+#workout the stringargs
+if [ "${stringargs}"  ] ; then
+    stringarrayexpr='string stringargs[]=['$(echo $stringargs | sed -e 's/ *$//g' -e 's/[^ ][^ ]*/"&"/g' -e 's/ /,/g')'];';
+else
+    stringarrayexpr='string stringargs[];'
+fi
+#workout standard input file
+if [ "${stdin}" ] ; then
+    if [ "${k_or_t}" = "swiftK" ] ; then
+       stdinfilexpr='file stdinfile<'\"${stdin}\"'>;'
+    else
+       stdinfilexpr='file stdinfile = input('\"${stdin}\"');'
+    fi
+else
+        stdinfilexpr='file stdinfile<'\"/dev/null\"'>;'
+    else
+        stdinfilexpr='file stdinfile = input('\"/dev/null\"');'
+    fi
+fi
+#workout the array only if user adds args else make it blank
+if [ ${#fileargs[@]} -gt 0 ] ; then
+  tmp=$(printf -- '%s,' "${fileargs[@]}")
+  filearrayexpr='file fileargs[] <fixed_array_mapper; files="'$(echo $tmp | sed -e 's/,$//' -e 's/\"//g')'">;';
+else
+  filearrayexpr='file fileargs[];'
+fi
+#build swift source
+ if [ "$range_or_list" == "list" ] ; then ## list
+ cat << EOF > $wdir/script.swift
+ * Swift source script is generated automatically via the Swift-Galaxy
+ * integration tool. Be careful before making any changes to it directly as
+ * it might be tied with other configuration and paramter values.
+ type file;
+ app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){
+     $interpreter @_exec _i _stringargs @_fileargs stdin=@_stdin stdout=@_out stderr=@_err;
+ $stringarrayexpr
+ $filearrayexpr
+ $stdinfilexpr
+ file exec<"$executable">;
+ file listfile<"$listfile">;
+ string list[] = readData(listfile);
+ foreach l, i in list{
+     file out <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".out")>;
+     file err <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".err")>;
+     (out,err) = anapp(exec, i, stringargs, fileargs, stdinfile);
+EOF
+else ## range
+cat << EOF > $wdir/script.swift
+type file;
+app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){
+$stringarrayexpr
+$filearrayexpr
+$stdinfilexpr
+file exec<"$executable">;
+foreach i in [$rstart:$rend:$stepsize]{
+    file out <single_file_mapper; file=@strcat("$outloc", "/", i, ".out")>;
+    file err <single_file_mapper; file=@strcat("$outloc", "/", i, ".err")>;
+EOF
+fi
+touch None # Create a "None" file in case user does not specify any stdin file
+############# End common setup ################
+if [ "$k_or_t" = "swiftK"  ] ; then #### invoke K
+$BASEDIR/buildsite.sh $sites $wdir
+#build config
+cat << EOF > $wdir/cf
+use.provider.staging=true
+wrapperlog.always.transfer=true
+execution.retries=0
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+lazy.errors=false
+EOF
+#build tc from sites and interpreter
+IFS=',' read -ra S <<< "$sites"
+for site in "${S[@]}" ; do
+cat << EOF >> $wdir/tc
+$site $interpreter $interpreter
+EOF
+done
+$swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
+EXITCODE=$?
+else
+### Invoke T
+ #workout the array only if user adds args else make it blank
+ if [ ${#fileargs[@]} -gt 0 ] ; then
+ else
+ fi
+ import files;
+ import string;
+ import io;
+     "$interpreter" _exec _i _stringargs _fileargs @stdin=_stdin @stdout=_out @stderr=_err;
+main{
+ $stringarrayexpr
+ $filearrayexpr
+ $stdinfilexpr
+ file exec=input("$executable");
+ $( if [ "$range_or_list" = "list" ] ; then
+  echo "file listfile=input("$listfile");"
+  echo "string list[] = split(read(listfile),"\n");"
+  echo "foreach l, i in list{"
+  echo "    file out <sprintf(\"$outloc/%s.%i.out\", l, i)>;"
+  echo "    file err <sprintf(\"$outloc/%s.%i.err\", l, i)>;"
+ else
+  echo "foreach i in [$rstart:$rend:$stepsize]{"
+  echo "    file out <sprintf(\"$outloc/%i.out\", i)>;"
+  echo "    file err <sprintf(\"$outloc/%i.err\", i)>;"
+ fi
+ printf("%s", "Done!");
+EOF
+EXITCODE=0
+case $sites in
+  "localhost" )
+   #echo "in localhost" >> /tmp/status.txt
+   STC=$(\which stc)
+   #echo "got stc" >> /tmp/status.txt
+   turbine=$(\which turbine)
+   #echo "got turbine" >> /tmp/status.txt
+   $STC -j $(\which java) $wdir/script.swift 2>$logfile
+   #echo "done running stc" >> /tmp/status.txt
+   #echo $turbine -n $n $wdir/script.tcl "${swiftargs}" >> /tmp/status.txt
+   $turbine -n $n $wdir/script.tcl "${swiftargs}" </dev/null
+   #echo "done running turbine, for $n" >> /tmp/status.txt
+   EXITCODE=$?
+   #echo "exit code obtained" >> /tmp/status.txt
+"Vesta" )
+  TURBINE_HOME=/home/wozniak/Public/sfw/turbine
+  STC=/home/wozniak/Public/sfw/stc/bin/stc
+  $STC -j $(\which java) -t checkpointing -r ${PWD} $wdir/script.swift 2>$logfile
+  $TURBINE_HOME/scripts/submit/cobalt/turbine-cobalt-run.zsh -n $n -s $HOME/cf $wdir/script.tcl
+  EXITCODE=$?
+"Mira" )
+  TURBINE_HOME=/home/wozniak/Public/sfw/ppc64/turbine
+  STC=/home/wozniak/Public/sfw/ppc64/stc/bin/stc
+  $TURBINE_HOME/scripts/submit/cobalt/turbine-cobalt-run.zsh -n $n -i $HOME/prerun.sh -s $HOME/cf $wdir/script.tcl
+  EXITCODE=$?
+esac
+fi
+cat << EOF > $outlistfile
+$(for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done)
+EOF
+if [ "$EXITCODE" -ne "0" ]; then
+      cat $logfile >&2
+fi
+exit $EXITCODE
Copied: SwiftApps/swift-galaxy/swift/old/swiftforeachlist.py (from rev 7862, SwiftApps/swift-galaxy/swift/swiftforeachlist.py)
--- SwiftApps/swift-galaxy/swift/old/swiftforeachlist.py	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/swiftforeachlist.py	2014-05-12 19:45:46 UTC (rev 7866)
@@ -0,0 +1,110 @@
+#!/usr/bin/env python
+import subprocess
+import sys
+#import rpy
+import os
+def setwdir():
+    return subprocess.check_output(["mktemp", "-d", "/tmp/swift-gal.XXXX"])
+# numeric range
+def main():
+    print "%d" % (len(sys.argv))
+    print "%s" % (sys.argv)
+    try:
+        sites=sys.argv[1] # comma separated list of sites
+        swiftargs=sys.argv[2]
+        interpreter=sys.argv[3]
+        executable=sys.argv[4]
+        rstart=sys.argv[5]
+        rend=sys.argv[6]
+        stepsize=sys.argv[7]
+        outloc=sys.argv[8]
+        outlistfile=sys.argv[9]
+        logfile=sys.argv[10]
+        stringargs=sys.argv[11]
+    except:
+        #rpy.stop_error('Wrong number or type of args')
+        sys.exit(1)
+    print sites
+    print swiftargs
+    print interpreter
+    if stringargs:
+        stringarrayexpr="string stringargs[]="+str(stringargs.split())+";\n"
+    else:
+        stringarrayexpr="string stringargs[];\n"
+    fileargs=list()
+    for files in sys.argv[12:]:
+        fileargs.append(files)
+    #workout the array only if user adds file args else make it blank
+    if fileargs:
+        filearrayexpr="file fileargs[]="+str(fileargs)+";\n"
+    else:
+        filearrayexpr="file fileargs[];\n"
+    wdir=setwdir().rstrip()
+    #Build Swift source code
+    f=open(wdir+"/script.swift", 'w');
+    f.write("type file; \n")
+    f.write("app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[]){ \n")
+    f.write("    "+interpreter+" @_exec _i _stringargs @_fileargs stdout=@_out stderr=@_err; \n")
+    f.write("}\n")
+    f.write(stringarrayexpr)
+    f.write(filearrayexpr)
+    f.write("file exec<'"+executable+"'>;\n")
+    f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{\n")
+    f.write("    file out <single_file_mapper; file=@strcat("+outloc+", '/', i, '.out')>;\n")
+    f.write("    file err <single_file_mapper; file=@strcat('"+outloc+"', '/', i, '.err')>;\n")
+    f.write("    (out,err) = anapp(exec, i, "+stringargs+", "+",".join(fileargs)+");\n")
+    f.write("}\n")
+    f.close()
+    swift=subprocess.check_output(["which", "swift"]).rstrip()
+    #build site
+    if os.path.dirname(sys.argv[0]):
+        basedir=os.path.dirname(sys.argv[0])
+    else:
+        basedir='.'
+    print "%s %s %s" %(basedir, sites, wdir)
+    subprocess.call([basedir+"/buildsite.sh", sites, wdir])
+    #build config
+    f=open(wdir+"/cf", 'w');
+    f.write('use.provider.staging=true')
+    f.write('wrapperlog.always.transfer=true')
+    f.write('execution.retries=0')
+    f.write('provider.staging.pin.swiftfiles=false')
+    f.write('sitedir.keep=true')
+    f.write('lazy.errors=false')
+    f.close()
+    #build tc
+    f=open(wdir+"/tc", 'w');
+    for site in sites.split():
+        f.write(site+' '+interpreter+' '+interpreter)
+    f.close()
+    #exitcode=subprocess.call([swift, '-sites.file', wdir+"/sites.xml", '-tc.file', wdir+"/tc", "-config", wdir+"/cf", wdir+"/script.swift", swiftargs, "2>logfile"])
+    #`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
+    #Populate output file
+    outlist=subprocess.check_output(["find", outloc, "-type", "f", "-iname", "*.out"])
+    f=open(outlistfile)
+    f.write(outlist);
+    f.close()
+    #dum ditty dum ditty dum dum dum
+if __name__=='__main__':
+    main()
Copied: SwiftApps/swift-galaxy/swift/old/swiftforeachrange.py (from rev 7862, SwiftApps/swift-galaxy/swift/swiftforeachrange.py)
--- SwiftApps/swift-galaxy/swift/old/swiftforeachrange.py	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/swiftforeachrange.py	2014-05-12 19:45:46 UTC (rev 7866)
@@ -0,0 +1,110 @@
+import subprocess
+import sys
+#import rpy
+import os
+def setwdir():
+# numeric range
+def main():
+    try:
+        rend=sys.argv[6]
+    except:
+        sys.exit(1)
+    print sites
+    print swiftargs
+    print interpreter
+    if stringargs:
+    else:
+    fileargs=list()
+    if fileargs:
+    else:
+    f.write("}\n")
+    f.write("}\n")
+    f.close()
+    #build site
+    else:
+        basedir='.'
+    #build config
+    f.close()
+    #build tc
+    f.close()
+    f.write(outlist);
+    f.close()
+    main()
Copied: SwiftApps/swift-galaxy/swift/old/swiftforeachrange.sh (from rev 7862, SwiftApps/swift-galaxy/swift/swiftforeachrange.sh)
--- SwiftApps/swift-galaxy/swift/old/swiftforeachrange.sh	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/swiftforeachrange.sh	2014-05-12 19:45:46 UTC (rev 7866)
@@ -0,0 +1,138 @@
+#!/bin/bash
+echo $@ > /tmp/args.txt
+k_or_t=$1
+shift
+sites=$1 # comma separated list of sites
+shift
+swiftargs=$1
+shift
+interpreter=$1
+shift
+executable=$1
+shift
+stdin=$1
+shift
+rstart=$1
+shift
+rend=$1
+shift
+stepsize=$1
+shift
+outloc=$1
+shift
+logfile=$1
+shift
+outlistfile=$1
+shift
+stringargs=$1
+shift
+else
+fi
+else
+fi
+fileargs=()
+  shift
+done
+#workout the array only if user adds file args else make it blank
+    #file fileargs[] <fixed_array_mapper; files="/Users/ketan/galaxy-dist/database/files/000/dataset_308.dat, /Users/ketan/galaxy-dist/database/files/000/dataset_307.dat">;
+else
+fi
+#Build Swift source code
+* Swift source script is generated automatically via the Swift-Galaxy
+* integration tool. Be careful before making any changes to it directly as
+* it might be tied with other configuration and paramter values.
+type file;
+$stringarrayexpr
+$filearrayexpr
+$stdinfilexpr
+EOF
+swift=$(which swift)
+#build site
+#build config
+sitedir.keep=true
+lazy.errors=false
+EOF
+#build tc
+EOF
+done
+    $swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
+    EXITCODE=$?
+else
+    echo "stc + turbine; not implemented yet" > /tmp/swiftT.txt
+fi
+#`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
+#Populate output file
+`for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done`
+EOF
+#cleanup
+#rm -rf /tmp/sites.xml /tmp/tc /tmp/cf /tmp/script.swift
+       cat $logfile >&2
+fi
+exit $EXITCODE
+#dum ditty dum ditty dum dum dum
Deleted: SwiftApps/swift-galaxy/swift/swiftforeach.sh
--- SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-12 19:44:03 UTC (rev 7865)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-12 19:45:46 UTC (rev 7866)
@@ -1,282 +0,0 @@
-#!/bin/bash
-# originally list
-#echo $@ > /tmp/args.txt
-#set workdir
-wdir=$(mktemp -d /tmp/swift-gal.XXXX)
-#determine loop mode: over a list or a range
-range_or_list=$1
-shift
-#determine invocation: Swift /K or /T
-k_or_t=$1
-shift
-#build commandline arguments
-sites=$1
-shift
-swiftargs=$1
-shift
-interpreter=$1
-shift
-executable=$1
-shift
-stdin=$1
-shift
-if [ "$range_or_list" = "list" ] ; then
-    listfile=$1
-    shift
-    n=$(wc -l < $listfile)
-else
-    rstart=$1
-    shift
-    rend=$1
-    shift
-    stepsize=$1
-    shift
-    n=$(( ($rend - $rstart) / $stepsize ))
-fi
-outloc=$1
-shift
-logfile=$1
-shift
-outlistfile=$1
-shift
-stringargs=$1
-shift
-swift=$(\which swift 2>/dev/null)
-BASEDIR=$(dirname $0)
-#workout the file args
-fileargs=()
-while [ $# -gt 0 ] ; do
-  fileargs+=("\"$1\"")
-  shift
-done
-#create outloc dir
-mkdir -p $outloc
-#workout the stringargs
-if [ "${stringargs}"  ] ; then
-    stringarrayexpr='string stringargs[]=['$(echo $stringargs | sed -e 's/ *$//g' -e 's/[^ ][^ ]*/"&"/g' -e 's/ /,/g')'];';
-else
-    stringarrayexpr='string stringargs[];'
-fi
-#workout standard input file
-if [ "${stdin}" ] ; then
-    if [ "${k_or_t}" = "swiftK" ] ; then
-       stdinfilexpr='file stdinfile<'\"${stdin}\"'>;'
-    else
-       stdinfilexpr='file stdinfile = input('\"${stdin}\"');'
-    fi
-else
-        stdinfilexpr='file stdinfile<'\"/dev/null\"'>;'
-    else
-        stdinfilexpr='file stdinfile = input('\"/dev/null\"');'
-    fi
-fi
-#workout the array only if user adds args else make it blank
-if [ ${#fileargs[@]} -gt 0 ] ; then
-  tmp=$(printf -- '%s,' "${fileargs[@]}")
-  filearrayexpr='file fileargs[] <fixed_array_mapper; files="'$(echo $tmp | sed -e 's/,$//' -e 's/\"//g')'">;';
-else
-  filearrayexpr='file fileargs[];'
-fi
-#build swift source
- if [ "$range_or_list" == "list" ] ; then ## list
- cat << EOF > $wdir/script.swift
- * Swift source script is generated automatically via the Swift-Galaxy
- * integration tool. Be careful before making any changes to it directly as
- * it might be tied with other configuration and paramter values.
- type file;
- app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){
-     $interpreter @_exec _i _stringargs @_fileargs stdin=@_stdin stdout=@_out stderr=@_err;
- $stringarrayexpr
- $filearrayexpr
- $stdinfilexpr
- file exec<"$executable">;
- file listfile<"$listfile">;
- string list[] = readData(listfile);
- foreach l, i in list{
-     file out <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".out")>;
-     file err <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".err")>;
-     (out,err) = anapp(exec, i, stringargs, fileargs, stdinfile);
-EOF
-else ## range
-cat << EOF > $wdir/script.swift
-type file;
-app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){
-$stringarrayexpr
-$filearrayexpr
-$stdinfilexpr
-file exec<"$executable">;
-foreach i in [$rstart:$rend:$stepsize]{
-    file out <single_file_mapper; file=@strcat("$outloc", "/", i, ".out")>;
-    file err <single_file_mapper; file=@strcat("$outloc", "/", i, ".err")>;
-EOF
-fi
-touch None # Create a "None" file in case user does not specify any stdin file
-############# End common setup ################
-if [ "$k_or_t" = "swiftK"  ] ; then #### invoke K
-$BASEDIR/buildsite.sh $sites $wdir
-#build config
-cat << EOF > $wdir/cf
-use.provider.staging=true
-wrapperlog.always.transfer=true
-execution.retries=0
-provider.staging.pin.swiftfiles=false
-sitedir.keep=true
-lazy.errors=false
-EOF
-#build tc from sites and interpreter
-IFS=',' read -ra S <<< "$sites"
-for site in "${S[@]}" ; do
-cat << EOF >> $wdir/tc
-$site $interpreter $interpreter
-EOF
-done
-$swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
-EXITCODE=$?
-else
-### Invoke T
- #workout the array only if user adds args else make it blank
- if [ ${#fileargs[@]} -gt 0 ] ; then
- else
- fi
- import files;
- import string;
- import io;
-     "$interpreter" _exec _i _stringargs _fileargs @stdin=_stdin @stdout=_out @stderr=_err;
-main{
- $stringarrayexpr
- $filearrayexpr
- $stdinfilexpr
- file exec=input("$executable");
- $( if [ "$range_or_list" = "list" ] ; then
-  echo "file listfile=input("$listfile");"
-  echo "string list[] = split(read(listfile),"\n");"
-  echo "foreach l, i in list{"
-  echo "    file out <sprintf(\"$outloc/%s.%i.out\", l, i)>;"
-  echo "    file err <sprintf(\"$outloc/%s.%i.err\", l, i)>;"
- else
-  echo "foreach i in [$rstart:$rend:$stepsize]{"
-  echo "    file out <sprintf(\"$outloc/%i.out\", i)>;"
-  echo "    file err <sprintf(\"$outloc/%i.err\", i)>;"
- fi
- printf("%s", "Done!");
-EOF
-EXITCODE=0
-case $sites in
-  "localhost" )
-   #echo "in localhost" >> /tmp/status.txt
-   STC=$(\which stc)
-   #echo "got stc" >> /tmp/status.txt
-   turbine=$(\which turbine)
-   #echo "got turbine" >> /tmp/status.txt
-   $STC -j $(\which java) $wdir/script.swift 2>$logfile
-   #echo "done running stc" >> /tmp/status.txt
-   #echo $turbine -n $n $wdir/script.tcl "${swiftargs}" >> /tmp/status.txt
-   $turbine -n $n $wdir/script.tcl "${swiftargs}" </dev/null
-   #echo "done running turbine, for $n" >> /tmp/status.txt
-   EXITCODE=$?
-   #echo "exit code obtained" >> /tmp/status.txt
-"Vesta" )
-  TURBINE_HOME=/home/wozniak/Public/sfw/turbine
-  STC=/home/wozniak/Public/sfw/stc/bin/stc
-  $STC -j $(\which java) -t checkpointing -r ${PWD} $wdir/script.swift 2>$logfile
-  $TURBINE_HOME/scripts/submit/cobalt/turbine-cobalt-run.zsh -n $n -s $HOME/cf $wdir/script.tcl
-  EXITCODE=$?
-"Mira" )
-  TURBINE_HOME=/home/wozniak/Public/sfw/ppc64/turbine
-  STC=/home/wozniak/Public/sfw/ppc64/stc/bin/stc
-  $TURBINE_HOME/scripts/submit/cobalt/turbine-cobalt-run.zsh -n $n -i $HOME/prerun.sh -s $HOME/cf $wdir/script.tcl
-  EXITCODE=$?
-esac
-fi
-cat << EOF > $outlistfile
-$(for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done)
-EOF
-if [ "$EXITCODE" -ne "0" ]; then
-      cat $logfile >&2
-fi
-exit $EXITCODE
Deleted: SwiftApps/swift-galaxy/swift/swiftforeachlist.py
--- SwiftApps/swift-galaxy/swift/swiftforeachlist.py	2014-05-12 19:44:03 UTC (rev 7865)
+++ SwiftApps/swift-galaxy/swift/swiftforeachlist.py	2014-05-12 19:45:46 UTC (rev 7866)
@@ -1,110 +0,0 @@
-#!/usr/bin/env python
-import subprocess
-import sys
-#import rpy
-import os
-def setwdir():
-    return subprocess.check_output(["mktemp", "-d", "/tmp/swift-gal.XXXX"])
-# numeric range
-def main():
-    print "%d" % (len(sys.argv))
-    print "%s" % (sys.argv)
-    try:
-        sites=sys.argv[1] # comma separated list of sites
-        swiftargs=sys.argv[2]
-        interpreter=sys.argv[3]
-        executable=sys.argv[4]
-        rstart=sys.argv[5]
-        rend=sys.argv[6]
-        stepsize=sys.argv[7]
-        outloc=sys.argv[8]
-        outlistfile=sys.argv[9]
-        logfile=sys.argv[10]
-        stringargs=sys.argv[11]
-    except:
-        #rpy.stop_error('Wrong number or type of args')
-        sys.exit(1)
-    print sites
-    print swiftargs
-    print interpreter
-    if stringargs:
-        stringarrayexpr="string stringargs[]="+str(stringargs.split())+";\n"
-    else:
-        stringarrayexpr="string stringargs[];\n"
-    fileargs=list()
-    for files in sys.argv[12:]:
-        fileargs.append(files)
-    #workout the array only if user adds file args else make it blank
-    if fileargs:
-        filearrayexpr="file fileargs[]="+str(fileargs)+";\n"
-    else:
-        filearrayexpr="file fileargs[];\n"
-    wdir=setwdir().rstrip()
-    #Build Swift source code
-    f=open(wdir+"/script.swift", 'w');
-    f.write("type file; \n")
-    f.write("app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[]){ \n")
-    f.write("    "+interpreter+" @_exec _i _stringargs @_fileargs stdout=@_out stderr=@_err; \n")
-    f.write("}\n")
-    f.write(stringarrayexpr)
-    f.write(filearrayexpr)
-    f.write("file exec<'"+executable+"'>;\n")
-    f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{\n")
-    f.write("    file out <single_file_mapper; file=@strcat("+outloc+", '/', i, '.out')>;\n")
-    f.write("    file err <single_file_mapper; file=@strcat('"+outloc+"', '/', i, '.err')>;\n")
-    f.write("    (out,err) = anapp(exec, i, "+stringargs+", "+",".join(fileargs)+");\n")
-    f.write("}\n")
-    f.close()
-    swift=subprocess.check_output(["which", "swift"]).rstrip()
-    #build site
-    if os.path.dirname(sys.argv[0]):
-        basedir=os.path.dirname(sys.argv[0])
-    else:
-        basedir='.'
-    print "%s %s %s" %(basedir, sites, wdir)
-    subprocess.call([basedir+"/buildsite.sh", sites, wdir])
-    #build config
-    f=open(wdir+"/cf", 'w');
-    f.write('use.provider.staging=true')
-    f.write('wrapperlog.always.transfer=true')
-    f.write('execution.retries=0')
-    f.write('provider.staging.pin.swiftfiles=false')
-    f.write('sitedir.keep=true')
-    f.write('lazy.errors=false')
-    f.close()
-    #build tc
-    f=open(wdir+"/tc", 'w');
-    for site in sites.split():
-        f.write(site+' '+interpreter+' '+interpreter)
-    f.close()
-    #exitcode=subprocess.call([swift, '-sites.file', wdir+"/sites.xml", '-tc.file', wdir+"/tc", "-config", wdir+"/cf", wdir+"/script.swift", swiftargs, "2>logfile"])
-    #`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
-    #Populate output file
-    outlist=subprocess.check_output(["find", outloc, "-type", "f", "-iname", "*.out"])
-    f=open(outlistfile)
-    f.write(outlist);
-    f.close()
-    #dum ditty dum ditty dum dum dum
-if __name__=='__main__':
-    main()
Deleted: SwiftApps/swift-galaxy/swift/swiftforeachrange.py
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.py	2014-05-12 19:44:03 UTC (rev 7865)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.py	2014-05-12 19:45:46 UTC (rev 7866)
@@ -1,110 +0,0 @@
-import subprocess
-import sys
-#import rpy
-import os
-def setwdir():
-# numeric range
-def main():
-    try:
-        rend=sys.argv[6]
-    except:
-        sys.exit(1)
-    print sites
-    print swiftargs
-    print interpreter
-    if stringargs:
-    else:
-    fileargs=list()
-    if fileargs:
-    else:
-    f.write("}\n")
-    f.write("}\n")
-    f.close()
-    #build site
-    else:
-        basedir='.'
-    #build config
-    f.close()
-    #build tc
-    f.close()
-    f.write(outlist);
-    f.close()
-    main()
Deleted: SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.sh	2014-05-12 19:44:03 UTC (rev 7865)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.sh	2014-05-12 19:45:46 UTC (rev 7866)
@@ -1,138 +0,0 @@
-#!/bin/bash
-echo $@ > /tmp/args.txt
-k_or_t=$1
-shift
-sites=$1 # comma separated list of sites
-shift
-swiftargs=$1
-shift
-interpreter=$1
-shift
-executable=$1
-shift
-stdin=$1
-shift
-rstart=$1
-shift
-rend=$1
-shift
-stepsize=$1
-shift
-outloc=$1
-shift
-logfile=$1
-shift
-outlistfile=$1
-shift
-stringargs=$1
-shift
-else
-fi
-else
-fi
-fileargs=()
-  shift
-done
-#workout the array only if user adds file args else make it blank
-    #file fileargs[] <fixed_array_mapper; files="/Users/ketan/galaxy-dist/database/files/000/dataset_308.dat, /Users/ketan/galaxy-dist/database/files/000/dataset_307.dat">;
-else
-fi
-#Build Swift source code
-* Swift source script is generated automatically via the Swift-Galaxy
-* integration tool. Be careful before making any changes to it directly as
-* it might be tied with other configuration and paramter values.
-type file;
-$stringarrayexpr
-$filearrayexpr
-$stdinfilexpr
-EOF
-swift=$(which swift)
-#build site
-#build config
-sitedir.keep=true
-lazy.errors=false
-EOF
-#build tc
-EOF
-done
-    $swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
-    EXITCODE=$?
-else
-    echo "stc + turbine; not implemented yet" > /tmp/swiftT.txt
-fi
-#`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
-#Populate output file
-`for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done`
-EOF
-#cleanup
-#rm -rf /tmp/sites.xml /tmp/tc /tmp/cf /tmp/script.swift
-       cat $logfile >&2
-fi
-exit $EXITCODE
-#dum ditty dum ditty dum dum dum
