[Swift-commit] r7865 - in SwiftApps/swift-galaxy/swift: . old
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon May 12 14:44:03 CDT 2014
Author: ketan
Date: 2014-05-12 14:44:03 -0500 (Mon, 12 May 2014)
New Revision: 7865
Added:
   SwiftApps/swift-galaxy/swift/old/2stage.xml
   SwiftApps/swift-galaxy/swift/old/dogftp.sh
   SwiftApps/swift-galaxy/swift/old/edrevised.mod
   SwiftApps/swift-galaxy/swift/old/gftplist.swift
   SwiftApps/swift-galaxy/swift/old/mysim.xml
   SwiftApps/swift-galaxy/swift/old/swift-2stage
   SwiftApps/swift-galaxy/swift/old/swift-3stage
   SwiftApps/swift-galaxy/swift/old/swift-skeleton.sh
   SwiftApps/swift-galaxy/swift/old/swift-skeleton.xml
   SwiftApps/swift-galaxy/swift/old/tc
Removed:
   SwiftApps/swift-galaxy/swift/2stage.xml
   SwiftApps/swift-galaxy/swift/dogftp.sh
   SwiftApps/swift-galaxy/swift/edrevised.mod
   SwiftApps/swift-galaxy/swift/gftplist.swift
   SwiftApps/swift-galaxy/swift/mysim.xml
   SwiftApps/swift-galaxy/swift/swift-2stage
   SwiftApps/swift-galaxy/swift/swift-3stage
   SwiftApps/swift-galaxy/swift/swift-skeleton.sh
   SwiftApps/swift-galaxy/swift/swift-skeleton.xml
   SwiftApps/swift-galaxy/swift/tc
Log:
move old stuff in old
Deleted: SwiftApps/swift-galaxy/swift/2stage.xml
--- SwiftApps/swift-galaxy/swift/2stage.xml	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/2stage.xml	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,23 +0,0 @@
-<tool id="2stage" name="A Swift 2 stage workflow">
-  <description>A 2 stage Swift workflow</description>
-  <command interpreter="bash">
-  swift-2stage "$site" "$data" "$n" "$html_file.files_path" "$log_file" "$html_file"
-  </command>
-  <inputs>
-    <param name="site" type="select" label="Execution Location">
-       <option value="localhost">Localhost</option>
-       <option value="midway">Midway</option>
-       <option value="uc3">UC3</option>
-       <option value="stampede">Stampede</option>
-    </param>
-    <param name="n" type="text" value="1" label="Number of jobs to run (tested ranges 1 - 1000)"/>
-    <param name="data" type="data" label="Input data file"/>
-    <!--<param name="outdir" type="text" value="/tmp/outdir" label="Directory to put output data into"/>-->
-  </inputs>
-  <outputs>
-     <data format="txt" name="log_file" type="data" label="Swift output" />
-     <data format="html" name="html_file" label="2stageoutput.html" />
-  </outputs>
-</tool>
Deleted: SwiftApps/swift-galaxy/swift/dogftp.sh
--- SwiftApps/swift-galaxy/swift/dogftp.sh	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/dogftp.sh	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,16 +0,0 @@
-#!/bin/bash -x
-#stagein
-#eg. globus-url-copy file:///work/01739/ketan/JSC_AdaptiveSchedule/workflow/sample.txt gsiftp://gridftp.stampede.tacc.utexas.edu:2811/scratch/01739/ketan/storage/
-src=$1
-dest=$2
-token=$3
-#echo $src > $token
-#echo $dest >> $token
-globus-url-copy $src $dest
-#ssh -i /home1/01739/ketan/.ssh/id_rsa maheshwari at swift.rcc.uchicago.edu globus-url-copy gsiftp://trestles-dm2.sdsc.edu:2811/home/ketan/storage/$src gsiftp://gridftp.stampede.tacc.utexas.edu:2811/work/01739/ketan/JSC_AdaptiveSchedule/workflow/dir/$dest
-echo $? > $token
Deleted: SwiftApps/swift-galaxy/swift/edrevised.mod
--- SwiftApps/swift-galaxy/swift/edrevised.mod	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/edrevised.mod	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,115 +0,0 @@
-# ampl model declaration
-# V. M. Zavala - MCS/ANL 2012
-# scenarios
-param NS;                        # number of scenarios
-set SCEN := 1..NS;               # set of scenarios
-# dispatch horizon
-param T;                         # horizon length
-param TH;                        # simulation horizon (hours)
-param dt;                        # length of time step [hr]
-set HORIZON := 0..T-1;           # horizon minus one
-set TESTTIME:=0..T;              # set of test times
-param idx_data;                  # auxiliary parameter
-param idx_state;                 # auxiliary parameter
-# lines
-set LIN;                         # set of lines
-param  status{LIN}, symbolic;    # line status
-param snd_bus{LIN};              # sending bus
-param rec_bus{LIN};              # receiving bus
-param       X{LIN};              # reactance - Ohm
-param       V{LIN};              # voltage drop - kV
-param    Pmax{LIN};              # maximum line capacity - MW
-param install_cost{LIN};         # annualized installation cost $/yr
-# buses
-set BUS;                         # set of buses
-param lat_bus{BUS};              # latitude of bus
-param lon_bus{BUS};              # longitude of bus
-param      ref_bus, symbolic;    # reference bus
-# generators
-set GEN;
-param    bus_gen{GEN};            # generator bus
-param     np_cap{GEN};            # name place capacity - MW
-param    sum_cap{GEN};            # summer capacity - MW
-param    win_cap{GEN};            # winter capacity - MW
-param    min_cap{GEN};            # minimum capacity - MW
-param       fuel{GEN}, symbolic;  # type of fuel for generator
-param  min_hrate{GEN};            # heat rate at minimum capacity - BTU/kWh
-param  min_power{GEN};            # power at minimum capacity - MW
-param     max_ur{GEN};            # minimum up ramp - MW
-param     max_dr{GEN};            # maximum down ramp - MW
-param    lat_gen{GEN};            # latitude of generation bus
-param    lon_gen{GEN};            # longitude of generation bus
-param   gen_cost{GEN};            # generation cost $/MWhr
-param  Pgen_init{GEN};            # initial conditions generators MW
-param clgen_cost{TESTTIME};       # closed-loop generation cost $/MWh
-# fuels
-set FUEL;
-param   Description{FUEL}, symbolic;  # fuel description
-param            HV{FUEL};            # heating value (Mbtu/unit)
-param     Unitprice{FUEL};            # unit price ($/unit)
-param         Units{FUEL}, symbolic;  # units
-# loads
-set TIME;                            # set of times for loads
-set LOAD;                            # set of loads
-param   bus_load{LOAD};              # load bus
-param loads{TIME,LOAD};              # loads in space and time - MW
-param wind_totalmh{SCEN,TESTTIME};   # total wind power - MW
-# wind data
-set WIND;
-param wind_total{SCEN,TIME};        # total wind power - MW
-param   bus_wind{WIND};             # wind bus
-param wind_share{WIND};             # wind share of total power MW/MW
-# variables
-var  Pgen{SCEN,TESTTIME,GEN};                            # generation levels - MW
-var Pload{SCEN,TESTTIME,LOAD};                           # load levels - MW
-var         yuc{TESTTIME,j in GEN} >= 0, <= 1;           # ON/OFF Status generators
-var slackp{s in SCEN, t in TESTTIME}>=0;                 # slack - for modeling purposes only
-var slackm{s in SCEN, t in TESTTIME}>=0;                 # slack - for modeling purposes only
-var Pgen_initial{GEN};                                   # initial state for generators - MW
-# params for inference
-param fix_x;
-# power flow equations
-pfeq{s in SCEN, t in TESTTIME}:
-         +(sum{i in GEN}  Pgen[s,t,i])
-         -(sum{i in LOAD} Pload[s,t,i])
-         + wind_totalmh[s,t]
-         = slackp[s,t]-slackm[s,t];
-# upper bound and lower bounds for generation flows [MW]
-Pgenequb{s in SCEN,t in TESTTIME,i in GEN}:  Pgen[s,t,i] <=  np_cap[i]*yuc[t,i];
-Pgeneqlb{s in SCEN,t in TESTTIME,i in GEN}:  Pgen[s,t,i] >=  0;
-Pgenequbinit{i in GEN}:  Pgen_initial[i] <=  np_cap[i]*yuc[1,i];
-Pgeneqlbinit{i in GEN}:  Pgen_initial[i] >=  0;
-# upper and lower bounds on ramps
-upramp{s in SCEN,t in HORIZON,i in GEN}:   Pgen[s,t+1,i] -  Pgen[s,t,i] <= +max_ur[i];
-loramp{s in SCEN,t in HORIZON,i in GEN}:   Pgen[s,t,i]  - Pgen[s,t+1,i] >= -max_dr[i];
-upramp0{s in SCEN,i in GEN}:   Pgen[s,1,i] -  Pgen_initial[i] <= +max_ur[i];
-loramp0{s in SCEN,i in GEN}:   Pgen_initial[i]  - Pgen[s,1,i] >= -max_dr[i];
-# time-dependent generation costs
-var   tot_gen_cost{s in SCEN,t in TESTTIME} = 1e+0*sum{i in GEN}  (gen_cost[i]*Pgen[s,t,i]);
-# time-dependent startup/shutdown costs
-var   tot_start_cost{t in TESTTIME} = 1e+3*(sum{i in GEN} yuc[t,i]);
-# time-dependent slack costs
-var   tot_slack_cost{s in SCEN,t in TESTTIME} = 1e+4*(slackp[s,t]+slackm[s,t]);
-# cost function
-minimize cost: sum{t in TESTTIME} tot_start_cost[t]
-               + (1/(card(SCEN)))*sum{s in SCEN,t in TESTTIME} tot_gen_cost[s,t]
-               + (1/(card(SCEN)))*sum{s in SCEN,t in TESTTIME} tot_slack_cost[s,t];
Deleted: SwiftApps/swift-galaxy/swift/gftplist.swift
--- SwiftApps/swift-galaxy/swift/gftplist.swift	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/gftplist.swift	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,18 +0,0 @@
-type file;
-app (file _status, file _stdout, file _stderr) stage (string _src, string _dst){
-   stage _src _dst @_status stdout=@_stdout stderr=@_stderr;
-string src="gsiftp://trestles-dm2.sdsc.edu:2811/home/ketan/storage/";
-string dst="gsiftp://gridftp.stampede.tacc.utexas.edu:2811/scratch/01739/ketan/dest/";
-string data[] = readData("datlist.txt");
-foreach d, i in data{
-  file status <single_file_mapper; file=@strcat("outdir/status.",i,".txt")>;
-  file out <single_file_mapper; file=@strcat("outdir/std.",i,".out")>;
-  file err <single_file_mapper; file=@strcat("outdir/std.",i,".err")>;
-  //trace (@strcat(src, d));
-  (status, out, err)  = stage (@strcat(src, d), @strcat(dst, d));
Deleted: SwiftApps/swift-galaxy/swift/mysim.xml
--- SwiftApps/swift-galaxy/swift/mysim.xml	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/mysim.xml	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,24 +0,0 @@
-<tool id="mysim" name="mysim application">
-  <description>A Swift tool to run the mysim workflow</description>
-  swift-mysim "$site" "$nsim" "$steps" "$range" "$vals" "$html_file.files_path" "$log_file" "$html_file"
-  </command>
-  <inputs>
-    </param>
-    <param name="nsim" type="text" value="10" label="Number of simulation tasks to run "/>
-    <param name="steps" type="text" value="1"  label="Number of timesteps per simulation"/>
-    <param name="range" type="text" value="100"  label="Range of the generated random numbers"/>
-    <param name="vals" type="text" value="10"  label="Number of values generated per simulation"/>
-  </inputs>
-  <outputs>
-     <data format="html" name="html_file" label="mysimoutput.html" />
-  </outputs>
-</tool>
Copied: SwiftApps/swift-galaxy/swift/old/2stage.xml (from rev 7862, SwiftApps/swift-galaxy/swift/2stage.xml)
--- SwiftApps/swift-galaxy/swift/old/2stage.xml	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/2stage.xml	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,23 @@
+<tool id="2stage" name="A Swift 2 stage workflow">
+  <description>A 2 stage Swift workflow</description>
+  <command interpreter="bash">
+  swift-2stage "$site" "$data" "$n" "$html_file.files_path" "$log_file" "$html_file"
+  </command>
+  <inputs>
+    <param name="site" type="select" label="Execution Location">
+       <option value="localhost">Localhost</option>
+       <option value="midway">Midway</option>
+       <option value="uc3">UC3</option>
+       <option value="stampede">Stampede</option>
+    </param>
+    <param name="n" type="text" value="1" label="Number of jobs to run (tested ranges 1 - 1000)"/>
+    <param name="data" type="data" label="Input data file"/>
+    <!--<param name="outdir" type="text" value="/tmp/outdir" label="Directory to put output data into"/>-->
+  </inputs>
+  <outputs>
+     <data format="txt" name="log_file" type="data" label="Swift output" />
+     <data format="html" name="html_file" label="2stageoutput.html" />
+  </outputs>
+</tool>
Copied: SwiftApps/swift-galaxy/swift/old/dogftp.sh (from rev 7862, SwiftApps/swift-galaxy/swift/dogftp.sh)
--- SwiftApps/swift-galaxy/swift/old/dogftp.sh	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/dogftp.sh	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,16 @@
+#!/bin/bash -x
+#stagein
+#eg. globus-url-copy file:///work/01739/ketan/JSC_AdaptiveSchedule/workflow/sample.txt gsiftp://gridftp.stampede.tacc.utexas.edu:2811/scratch/01739/ketan/storage/
+src=$1
+dest=$2
+token=$3
+#echo $src > $token
+#echo $dest >> $token
+globus-url-copy $src $dest
+#ssh -i /home1/01739/ketan/.ssh/id_rsa maheshwari at swift.rcc.uchicago.edu globus-url-copy gsiftp://trestles-dm2.sdsc.edu:2811/home/ketan/storage/$src gsiftp://gridftp.stampede.tacc.utexas.edu:2811/work/01739/ketan/JSC_AdaptiveSchedule/workflow/dir/$dest
+echo $? > $token
Copied: SwiftApps/swift-galaxy/swift/old/edrevised.mod (from rev 7862, SwiftApps/swift-galaxy/swift/edrevised.mod)
--- SwiftApps/swift-galaxy/swift/old/edrevised.mod	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/edrevised.mod	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,115 @@
+# ampl model declaration
+# V. M. Zavala - MCS/ANL 2012
+# scenarios
+param NS;                        # number of scenarios
+set SCEN := 1..NS;               # set of scenarios
+# dispatch horizon
+param T;                         # horizon length
+param TH;                        # simulation horizon (hours)
+param dt;                        # length of time step [hr]
+set HORIZON := 0..T-1;           # horizon minus one
+set TESTTIME:=0..T;              # set of test times
+param idx_data;                  # auxiliary parameter
+param idx_state;                 # auxiliary parameter
+# lines
+set LIN;                         # set of lines
+param  status{LIN}, symbolic;    # line status
+param snd_bus{LIN};              # sending bus
+param rec_bus{LIN};              # receiving bus
+param       X{LIN};              # reactance - Ohm
+param       V{LIN};              # voltage drop - kV
+param    Pmax{LIN};              # maximum line capacity - MW
+param install_cost{LIN};         # annualized installation cost $/yr
+# buses
+set BUS;                         # set of buses
+param lat_bus{BUS};              # latitude of bus
+param lon_bus{BUS};              # longitude of bus
+param      ref_bus, symbolic;    # reference bus
+# generators
+set GEN;
+param    bus_gen{GEN};            # generator bus
+param     np_cap{GEN};            # name place capacity - MW
+param    sum_cap{GEN};            # summer capacity - MW
+param    win_cap{GEN};            # winter capacity - MW
+param    min_cap{GEN};            # minimum capacity - MW
+param       fuel{GEN}, symbolic;  # type of fuel for generator
+param  min_hrate{GEN};            # heat rate at minimum capacity - BTU/kWh
+param  min_power{GEN};            # power at minimum capacity - MW
+param     max_ur{GEN};            # minimum up ramp - MW
+param     max_dr{GEN};            # maximum down ramp - MW
+param    lat_gen{GEN};            # latitude of generation bus
+param    lon_gen{GEN};            # longitude of generation bus
+param   gen_cost{GEN};            # generation cost $/MWhr
+param  Pgen_init{GEN};            # initial conditions generators MW
+param clgen_cost{TESTTIME};       # closed-loop generation cost $/MWh
+# fuels
+set FUEL;
+param   Description{FUEL}, symbolic;  # fuel description
+param            HV{FUEL};            # heating value (Mbtu/unit)
+param     Unitprice{FUEL};            # unit price ($/unit)
+param         Units{FUEL}, symbolic;  # units
+# loads
+set TIME;                            # set of times for loads
+set LOAD;                            # set of loads
+param   bus_load{LOAD};              # load bus
+param loads{TIME,LOAD};              # loads in space and time - MW
+param wind_totalmh{SCEN,TESTTIME};   # total wind power - MW
+# wind data
+set WIND;
+param wind_total{SCEN,TIME};        # total wind power - MW
+param   bus_wind{WIND};             # wind bus
+param wind_share{WIND};             # wind share of total power MW/MW
+# variables
+var  Pgen{SCEN,TESTTIME,GEN};                            # generation levels - MW
+var Pload{SCEN,TESTTIME,LOAD};                           # load levels - MW
+var         yuc{TESTTIME,j in GEN} >= 0, <= 1;           # ON/OFF Status generators
+var slackp{s in SCEN, t in TESTTIME}>=0;                 # slack - for modeling purposes only
+var slackm{s in SCEN, t in TESTTIME}>=0;                 # slack - for modeling purposes only
+var Pgen_initial{GEN};                                   # initial state for generators - MW
+# params for inference
+param fix_x;
+# power flow equations
+pfeq{s in SCEN, t in TESTTIME}:
+         +(sum{i in GEN}  Pgen[s,t,i])
+         -(sum{i in LOAD} Pload[s,t,i])
+         + wind_totalmh[s,t]
+         = slackp[s,t]-slackm[s,t];
+# upper bound and lower bounds for generation flows [MW]
+Pgenequb{s in SCEN,t in TESTTIME,i in GEN}:  Pgen[s,t,i] <=  np_cap[i]*yuc[t,i];
+Pgeneqlb{s in SCEN,t in TESTTIME,i in GEN}:  Pgen[s,t,i] >=  0;
+Pgenequbinit{i in GEN}:  Pgen_initial[i] <=  np_cap[i]*yuc[1,i];
+Pgeneqlbinit{i in GEN}:  Pgen_initial[i] >=  0;
+# upper and lower bounds on ramps
+upramp{s in SCEN,t in HORIZON,i in GEN}:   Pgen[s,t+1,i] -  Pgen[s,t,i] <= +max_ur[i];
+loramp{s in SCEN,t in HORIZON,i in GEN}:   Pgen[s,t,i]  - Pgen[s,t+1,i] >= -max_dr[i];
+upramp0{s in SCEN,i in GEN}:   Pgen[s,1,i] -  Pgen_initial[i] <= +max_ur[i];
+loramp0{s in SCEN,i in GEN}:   Pgen_initial[i]  - Pgen[s,1,i] >= -max_dr[i];
+# time-dependent generation costs
+var   tot_gen_cost{s in SCEN,t in TESTTIME} = 1e+0*sum{i in GEN}  (gen_cost[i]*Pgen[s,t,i]);
+# time-dependent startup/shutdown costs
+var   tot_start_cost{t in TESTTIME} = 1e+3*(sum{i in GEN} yuc[t,i]);
+# time-dependent slack costs
+var   tot_slack_cost{s in SCEN,t in TESTTIME} = 1e+4*(slackp[s,t]+slackm[s,t]);
+# cost function
+minimize cost: sum{t in TESTTIME} tot_start_cost[t]
+               + (1/(card(SCEN)))*sum{s in SCEN,t in TESTTIME} tot_gen_cost[s,t]
+               + (1/(card(SCEN)))*sum{s in SCEN,t in TESTTIME} tot_slack_cost[s,t];
Copied: SwiftApps/swift-galaxy/swift/old/gftplist.swift (from rev 7862, SwiftApps/swift-galaxy/swift/gftplist.swift)
--- SwiftApps/swift-galaxy/swift/old/gftplist.swift	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/gftplist.swift	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,18 @@
+type file;
+app (file _status, file _stdout, file _stderr) stage (string _src, string _dst){
+   stage _src _dst @_status stdout=@_stdout stderr=@_stderr;
+string src="gsiftp://trestles-dm2.sdsc.edu:2811/home/ketan/storage/";
+string dst="gsiftp://gridftp.stampede.tacc.utexas.edu:2811/scratch/01739/ketan/dest/";
+string data[] = readData("datlist.txt");
+foreach d, i in data{
+  file status <single_file_mapper; file=@strcat("outdir/status.",i,".txt")>;
+  file out <single_file_mapper; file=@strcat("outdir/std.",i,".out")>;
+  file err <single_file_mapper; file=@strcat("outdir/std.",i,".err")>;
+  //trace (@strcat(src, d));
+  (status, out, err)  = stage (@strcat(src, d), @strcat(dst, d));
Copied: SwiftApps/swift-galaxy/swift/old/mysim.xml (from rev 7862, SwiftApps/swift-galaxy/swift/mysim.xml)
--- SwiftApps/swift-galaxy/swift/old/mysim.xml	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/mysim.xml	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,24 @@
+<tool id="mysim" name="mysim application">
+  <description>A Swift tool to run the mysim workflow</description>
+  swift-mysim "$site" "$nsim" "$steps" "$range" "$vals" "$html_file.files_path" "$log_file" "$html_file"
+  </command>
+  <inputs>
+    </param>
+    <param name="nsim" type="text" value="10" label="Number of simulation tasks to run "/>
+    <param name="steps" type="text" value="1"  label="Number of timesteps per simulation"/>
+    <param name="range" type="text" value="100"  label="Range of the generated random numbers"/>
+    <param name="vals" type="text" value="10"  label="Number of values generated per simulation"/>
+  </inputs>
+  <outputs>
+     <data format="html" name="html_file" label="mysimoutput.html" />
+  </outputs>
+</tool>
Copied: SwiftApps/swift-galaxy/swift/old/swift-2stage (from rev 7862, SwiftApps/swift-galaxy/swift/swift-2stage)
--- SwiftApps/swift-galaxy/swift/old/swift-2stage	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/swift-2stage	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,319 @@
+#!/bin/bash
+site=$1
+data=$2
+n=$3
+outdir=$4
+logfile=$5
+htmlfile=$6
+mkdir -p $outdir
+echo $@ >> /tmp/args.txt
+swift=/home/maheshwari/swift-0.94/cog/modules/swift/dist/swift-svn/bin/swift
+# use "here" document for configs
+cat << EOF > /tmp/2stage.swift
+type file;
+type script;
+app (file o) s (file i) {
+  cat @i stdout=@o;
+file out1[]<simple_mapper; location="$outdir", prefix="f1.",suffix=".txt">;
+file out2[]<simple_mapper; location="$outdir", prefix="f2.",suffix=".txt">;
+string d=@arg("data");
+foreach j in [1:@toInt(@arg("n","1"))] {
+ file data<single_file_mapper; file=d>;
+ out1[j] = s(data);
+ out2[j] = s(out1[j]);
+EOF
+case "$site" in
+midway )
+cat << 'EOF' > /tmp/sites.xml
+<config>
+  <pool handle="midway">
+    <execution provider="coaster" jobmanager="local:slurm"/>
+    <profile namespace="globus" key="queue">sandyb</profile>
+    <profile namespace="globus" key="jobsPerNode">16</profile>
+    <profile namespace="globus" key="maxWalltime">02:00:00</profile>
+    <profile namespace="globus" key="maxTime">7500</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="globus" key="slots">2</profile>
+    <profile namespace="globus" key="maxNodes">1</profile>
+    <profile namespace="globus" key="nodeGranularity">1</profile>
+    <profile namespace="karajan" key="jobThrottle">.31</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <workdirectory>/tmp/swift.work</workdirectory>
+  </pool>
+</config>
+EOF
+cat << 'EOF' > /tmp/tc
+midway echo  echo
+midway cat   cat
+EOF
+cat << 'EOF' > /tmp/cf
+use.provider.staging=true
+wrapperlog.always.transfer=true
+execution.retries=1
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+lazy.errors=false
+EOF
+uc3 )
+<config>
+  <pool handle="uc3">
+    <execution provider="coaster" url="uc3-sub.uchicago.edu" jobmanager="ssh-cl:condor"/>
+    <!--<execution provider="coaster" jobmanager="local:condor"/>-->
+    <profile namespace="karajan" key="jobThrottle">.09</profile>
+    <profile namespace="karajan" key="initialScore">1000</profile>
+    <profile namespace="globus"  key="jobsPerNode">1</profile>
+    <profile namespace="globus"  key="maxWalltime">3600</profile>
+    <profile namespace="globus"  key="slots">1</profile>
+    <profile namespace="globus"  key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile>
+    <profile namespace="globus"  key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
+    <profile namespace="globus"  key="jobType">nonshared</profile>
+    <filesystem provider="local" url="none" />
+    <!--<workdirectory>/home/maheshwari/test/catsn/swift.work</workdirectory>-->
+  </pool>
+</config>
+EOF
+uc3 echo  /bin/echo
+uc3 cat   /bin/cat
+EOF
+sitedir.keep=true
+lazy.errors=false
+EOF
+stampede )
+<config>
+<pool handle="stampede">
+  <execution provider="coaster" jobmanager="gt2:gt2:slurm" url="login5.stampede.tacc.utexas.edu:2119/jobmanager-slurm"/>
+  <!--<execution provider="coaster" jobmanager="ssh-cl:slurm" url="stampede.tacc.utexas.edu"/>-->
+  <!--<filesystem provider="gsiftp" url="gsiftp://gridftp.stampede.tacc.utexas.edu:2811"/>-->
+  <filesystem provider="local"/>
+  <profile namespace="globus" key="ppn">16</profile>
+  <profile namespace="globus" key="project">TG-STA110005S</profile>
+  <profile namespace="globus" key="queue">normal</profile>
+  <profile namespace="globus" key="slurm.mail-user">ketancmaheshwari at gmail.com</profile>
+  <profile namespace="globus" key="slurm.mail-type">ALL</profile>
+  <profile namespace="globus" key="maxTime">8000</profile>
+  <profile namespace="karajan" key="jobThrottle">.15</profile>
+</pool>
+</config>
+EOF
+stampede echo echo
+stampede cat cat
+EOF
+sitedir.keep=true
+lazy.errors=false
+EOF
+localhost )
+<config>
+<pool handle="localhost">
+  <execution provider="coaster" jobmanager="local:local"/>
+  <!--<workdirectory>/home/kcm92/powergridapps/swiftscripts/swift.work</workdirectory>-->
+  <profile namespace="karajan" key="jobThrottle">0.31</profile>
+</pool>
+</config>
+EOF
+localhost echo echo
+localhost cat cat
+EOF
+use.provider.staging=false
+sitedir.keep=true
+lazy.errors=false
+EOF
+echo "defaulting to localhost"
+<config>
+  </pool>
+</config>
+EOF
+localhost cat cat
+EOF
+sitedir.keep=true
+lazy.errors=false
+EOF
+esac
+$swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/2stage.swift -n=$n -data=$data 2> std.err
+EXITCODE=$?
+swiftlog=`\ls -t *.log | head -1`
+#/tmp/plotswiftlogs $logfile 2>gnuplot.err
+cat << 'EOF' > /tmp/plotswiftlogs
+#!/bin/bash
+#usage: ./extract4plots <swift.logfile>
+SWIFTLOGFILE=$1
+#TMPDIR=`mktemp -d plotlog.XXX`
+grep -i ProgressTicker $SWIFTLOGFILE > swiftoutfile.out
+SWIFTOUTFILE=swiftoutfile.out
+#extract start time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | head -n 1 | cut -f1-2 -d ' '`
+START_TIME=`date +%s -d "$TMPDATE"`
+#extract end time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | tail -n 1 | cut -f1-2 -d ' '`
+END_TIME=`date +%s -d "$TMPDATE"`
+#duration
+DIFFTIME=$((END_TIME - START_TIME))
+#echo 0 > active.txt
+#echo 0 > cumulative.txt
+#extract active runs in a file
+(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' >> active.txt)
+#extract successful completions in a file
+(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' >> cumulative.txt)
+#prepare tics
+activelines=`wc -l active.txt | awk '{print $1}'`
+cumulines=`wc -l cumulative.txt | awk '{print $1}'`
+if [ $activelines -ne 0 ]
+then
+  activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
+fi
+seq 0 $activelinespertic $DIFFTIME > activetics.txt
+if [ $cumulines -ne 0 ]
+then
+    cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
+fi
+seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
+#final plot data
+paste activetics.txt active.txt > plot_active.txt
+paste cumultics.txt cumulative.txt > plot_cumulative.txt
+cat << EOF1 > plotit.gp
+set terminal png enhanced
+set output "activeplot.png"
+set nokey
+set xlabel "Time in sec"
+set ylabel "number of active jobs"
+set title "Active jobs"
+plot "plot_active.txt" using 1:2 with line
+set output "cumulativeplot.png"
+set ylabel "number of completed jobs"
+set title "Cumulative jobs"
+plot "plot_cumulative.txt" using 1:2 with lines
+EOF1
+gnuplot plotit.gp 2>/dev/null
+#cp *.png ../
+echo `pwd`>/tmp/curdir
+echo `ls`>/tmp/dirlist
+#cd ..
+EOF
+sh /tmp/plotswiftlogs $swiftlog
+cp *.png $outdir/
+cat << EOF > $htmlfile
+<!DOCTYPE HTML>
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+  <title>2stage workflow output</title>
+</head>
+<body>
+<h2>Swift run trace plots</h2>
+<a href="activeplot.png" alt="active plot">active plot</a>
+<a href="cumulativeplot.png" alt="cumulative plot">cumulative plot</a>
+<h2>Browse output of 2stage application</h2>
+`for i in \`find $outdir -type f\`; do echo "<a href=\`basename $i\`>Output: \`basename $i\`</a><br/>"; done`
+</body>
+</html>
+EOF
+if [ "$EXITCODE" -ne "0" ]; then
+       cat std.err >&2
+fi
+cp std.err $logfile
+rm std.err
+exit $EXITCODE
Copied: SwiftApps/swift-galaxy/swift/old/swift-3stage (from rev 7862, SwiftApps/swift-galaxy/swift/swift-3stage)
--- SwiftApps/swift-galaxy/swift/old/swift-3stage	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/swift-3stage	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,325 @@
+#!/bin/bash
+site=$1
+data=$2
+n=$3
+outdir=$4
+logfile=$5
+htmlfile=$6
+mkdir -p $outdir
+type file;
+type script;
+  cat @i stdout=@o;
+EOF
+case "$site" in
+midway )
+<config>
+  </pool>
+</config>
+EOF
+midway echo  echo
+midway cat   cat
+EOF
+sitedir.keep=true
+lazy.errors=false
+EOF
+uc3 )
+<config>
+  </pool>
+</config>
+EOF
+uc3 echo  /bin/echo
+uc3 cat   /bin/cat
+EOF
+sitedir.keep=true
+lazy.errors=false
+EOF
+stampede )
+<config>
+</pool>
+</config>
+EOF
+stampede echo echo
+stampede cat cat
+EOF
+sitedir.keep=true
+lazy.errors=false
+EOF
+localhost )
+<config>
+</pool>
+</config>
+EOF
+localhost cat cat
+EOF
+sitedir.keep=true
+lazy.errors=false
+EOF
+<config>
+  </pool>
+</config>
+EOF
+localhost cat cat
+EOF
+sitedir.keep=true
+lazy.errors=false
+EOF
+esac
+EXITCODE=$?
+#!/bin/bash
+SWIFTLOGFILE=$1
+#extract end time
+#duration
+(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > active.txt)
+(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > cumulative.txt)
+#prepare tics
+then
+fi
+then
+fi
+#final plot data
+set nokey
+EOF1
+#cp *.png ../
+#cd ..
+EOF
+cp *.png $outdir/
+#for i in `find $outdir`
+#do
+#  lastfile=$i
+#done
+#bname=`basename $lastfile`
+<!DOCTYPE HTML>
+<head>
+</head>
+<body>
+</body>
+</html>
+EOF
+       cat std.err >&2
+fi
+rm std.err
+exit $EXITCODE
Copied: SwiftApps/swift-galaxy/swift/old/swift-skeleton.sh (from rev 7862, SwiftApps/swift-galaxy/swift/swift-skeleton.sh)
--- SwiftApps/swift-galaxy/swift/old/swift-skeleton.sh	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/swift-skeleton.sh	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,187 @@
+#!/bin/bash
+#set -x
+set -e
+site=$1
+data=$2
+n=$3
+outdir=$4
+logfile=$5
+htmlfile=$6
+mkdir -p $outdir
+swift=`which swift`
+cat << EOF > /tmp/script.swift
+# Place your Swift script here
+# Make sure all data references are full-path
+EOF
+case "$site" in
+midway )
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+  <execution provider="coaster" url="swift.rcc.uchicago.edu" jobmanager="ssh-cl:slurm"/>
+ </pool>
+</config>
+EOF
+uc3 )
+ </pool>
+</config>
+EOF
+stampede )
+  <execution provider="coaster" jobmanager="ssh-cl:slurm" url="stampede.tacc.utexas.edu"/>
+</pool>
+</config>
+EOF
+localhost )
+  <execution provider="local" jobmanager="local:local"/>
+</pool>
+</config>
+EOF
+</pool>
+</config>
+EOF
+esac
+sitedir.keep=true
+lazy.errors=false
+EOF
+localhost cat cat
+stampede echo echo
+stampede cat cat
+uc3 echo echo
+uc3 cat cat
+midway echo echo
+midway cat cat
+EOF
+$swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/catsn.swift -n=$n -data=$data 2> $logfile
+EXITCODE=$?
+#do
+#  lastfile=$i
+#done
+<!DOCTYPE HTML>
+<head>
+  <title>Catsn output</title>
+</head>
+<body>
+<h2>Browse output of catsn application</h2>
+</body>
+</html>
+EOF
+       cat $logfile >&2
+fi
+exit $EXITCODE
Copied: SwiftApps/swift-galaxy/swift/old/swift-skeleton.xml (from rev 7862, SwiftApps/swift-galaxy/swift/swift-skeleton.xml)
--- SwiftApps/swift-galaxy/swift/old/swift-skeleton.xml	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/swift-skeleton.xml	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,22 @@
+<tool id="skeleton(replace with an id)" name="Swift Skeleton (replace with a name)">
+  <description>A description here</description>
+  swift-skeleton.sh "$site" "$data" "$n" "$html_file.files_path" "$log_file" "$html_file"
+  </command>
+  <inputs>
+    </param>
+    <param name="n" type="text" value="1" label="Number of tasks to run "/>
+  </inputs>
+  <outputs>
+     <data format="txt" name="log_file" type="data" label="Standard out" />
+     <data format="html" name="html_file" label="catsnoutput.html" />
+  </outputs>
+</tool>
Copied: SwiftApps/swift-galaxy/swift/old/tc (from rev 7862, SwiftApps/swift-galaxy/swift/tc)
--- SwiftApps/swift-galaxy/swift/old/tc	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/old/tc	2014-05-12 19:44:03 UTC (rev 7865)
@@ -0,0 +1,7 @@
+localhost cat cat
+localhost gensample   /home/maheshwari/powergridapps/bin/gensample.py
+localhost runampl   /home/maheshwari/powergridapps/bin/run_ampl.py
+localhost runampl_l /home/maheshwari/powergridapps/bin/run_ampl_l.py
+localhost runampl_u /home/maheshwari/powergridapps/bin/run_ampl_u.py
+localhost stage /scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/dogftp.sh
Deleted: SwiftApps/swift-galaxy/swift/swift-2stage
--- SwiftApps/swift-galaxy/swift/swift-2stage	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/swift-2stage	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,319 +0,0 @@
-#!/bin/bash
-site=$1
-data=$2
-n=$3
-outdir=$4
-logfile=$5
-htmlfile=$6
-mkdir -p $outdir
-echo $@ >> /tmp/args.txt
-swift=/home/maheshwari/swift-0.94/cog/modules/swift/dist/swift-svn/bin/swift
-# use "here" document for configs
-cat << EOF > /tmp/2stage.swift
-type file;
-type script;
-app (file o) s (file i) {
-  cat @i stdout=@o;
-file out1[]<simple_mapper; location="$outdir", prefix="f1.",suffix=".txt">;
-file out2[]<simple_mapper; location="$outdir", prefix="f2.",suffix=".txt">;
-string d=@arg("data");
-foreach j in [1:@toInt(@arg("n","1"))] {
- file data<single_file_mapper; file=d>;
- out1[j] = s(data);
- out2[j] = s(out1[j]);
-EOF
-case "$site" in
-midway )
-cat << 'EOF' > /tmp/sites.xml
-<config>
-  <pool handle="midway">
-    <execution provider="coaster" jobmanager="local:slurm"/>
-    <profile namespace="globus" key="queue">sandyb</profile>
-    <profile namespace="globus" key="jobsPerNode">16</profile>
-    <profile namespace="globus" key="maxWalltime">02:00:00</profile>
-    <profile namespace="globus" key="maxTime">7500</profile>
-    <profile namespace="globus" key="highOverAllocation">100</profile>
-    <profile namespace="globus" key="lowOverAllocation">100</profile>
-    <profile namespace="globus" key="slots">2</profile>
-    <profile namespace="globus" key="maxNodes">1</profile>
-    <profile namespace="globus" key="nodeGranularity">1</profile>
-    <profile namespace="karajan" key="jobThrottle">.31</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-    <workdirectory>/tmp/swift.work</workdirectory>
-  </pool>
-</config>
-EOF
-cat << 'EOF' > /tmp/tc
-midway echo  echo
-midway cat   cat
-EOF
-cat << 'EOF' > /tmp/cf
-use.provider.staging=true
-wrapperlog.always.transfer=true
-execution.retries=1
-provider.staging.pin.swiftfiles=false
-sitedir.keep=true
-lazy.errors=false
-EOF
-uc3 )
-<config>
-  <pool handle="uc3">
-    <execution provider="coaster" url="uc3-sub.uchicago.edu" jobmanager="ssh-cl:condor"/>
-    <!--<execution provider="coaster" jobmanager="local:condor"/>-->
-    <profile namespace="karajan" key="jobThrottle">.09</profile>
-    <profile namespace="karajan" key="initialScore">1000</profile>
-    <profile namespace="globus"  key="jobsPerNode">1</profile>
-    <profile namespace="globus"  key="maxWalltime">3600</profile>
-    <profile namespace="globus"  key="slots">1</profile>
-    <profile namespace="globus"  key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile>
-    <profile namespace="globus"  key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
-    <profile namespace="globus"  key="jobType">nonshared</profile>
-    <filesystem provider="local" url="none" />
-    <!--<workdirectory>/home/maheshwari/test/catsn/swift.work</workdirectory>-->
-  </pool>
-</config>
-EOF
-uc3 echo  /bin/echo
-uc3 cat   /bin/cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-stampede )
-<config>
-<pool handle="stampede">
-  <execution provider="coaster" jobmanager="gt2:gt2:slurm" url="login5.stampede.tacc.utexas.edu:2119/jobmanager-slurm"/>
-  <!--<execution provider="coaster" jobmanager="ssh-cl:slurm" url="stampede.tacc.utexas.edu"/>-->
-  <!--<filesystem provider="gsiftp" url="gsiftp://gridftp.stampede.tacc.utexas.edu:2811"/>-->
-  <filesystem provider="local"/>
-  <profile namespace="globus" key="ppn">16</profile>
-  <profile namespace="globus" key="project">TG-STA110005S</profile>
-  <profile namespace="globus" key="queue">normal</profile>
-  <profile namespace="globus" key="slurm.mail-user">ketancmaheshwari at gmail.com</profile>
-  <profile namespace="globus" key="slurm.mail-type">ALL</profile>
-  <profile namespace="globus" key="maxTime">8000</profile>
-  <profile namespace="karajan" key="jobThrottle">.15</profile>
-</pool>
-</config>
-EOF
-stampede echo echo
-stampede cat cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-localhost )
-<config>
-<pool handle="localhost">
-  <execution provider="coaster" jobmanager="local:local"/>
-  <!--<workdirectory>/home/kcm92/powergridapps/swiftscripts/swift.work</workdirectory>-->
-  <profile namespace="karajan" key="jobThrottle">0.31</profile>
-</pool>
-</config>
-EOF
-localhost echo echo
-localhost cat cat
-EOF
-use.provider.staging=false
-sitedir.keep=true
-lazy.errors=false
-EOF
-echo "defaulting to localhost"
-<config>
-  </pool>
-</config>
-EOF
-localhost cat cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-esac
-$swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/2stage.swift -n=$n -data=$data 2> std.err
-EXITCODE=$?
-swiftlog=`\ls -t *.log | head -1`
-#/tmp/plotswiftlogs $logfile 2>gnuplot.err
-cat << 'EOF' > /tmp/plotswiftlogs
-#!/bin/bash
-#usage: ./extract4plots <swift.logfile>
-SWIFTLOGFILE=$1
-#TMPDIR=`mktemp -d plotlog.XXX`
-grep -i ProgressTicker $SWIFTLOGFILE > swiftoutfile.out
-SWIFTOUTFILE=swiftoutfile.out
-#extract start time
-TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | head -n 1 | cut -f1-2 -d ' '`
-START_TIME=`date +%s -d "$TMPDATE"`
-#extract end time
-TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | tail -n 1 | cut -f1-2 -d ' '`
-END_TIME=`date +%s -d "$TMPDATE"`
-#duration
-DIFFTIME=$((END_TIME - START_TIME))
-#echo 0 > active.txt
-#echo 0 > cumulative.txt
-#extract active runs in a file
-(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' >> active.txt)
-#extract successful completions in a file
-(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' >> cumulative.txt)
-#prepare tics
-activelines=`wc -l active.txt | awk '{print $1}'`
-cumulines=`wc -l cumulative.txt | awk '{print $1}'`
-if [ $activelines -ne 0 ]
-then
-  activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
-fi
-seq 0 $activelinespertic $DIFFTIME > activetics.txt
-if [ $cumulines -ne 0 ]
-then
-    cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
-fi
-seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
-#final plot data
-paste activetics.txt active.txt > plot_active.txt
-paste cumultics.txt cumulative.txt > plot_cumulative.txt
-cat << EOF1 > plotit.gp
-set terminal png enhanced
-set output "activeplot.png"
-set nokey
-set xlabel "Time in sec"
-set ylabel "number of active jobs"
-set title "Active jobs"
-plot "plot_active.txt" using 1:2 with line
-set output "cumulativeplot.png"
-set ylabel "number of completed jobs"
-set title "Cumulative jobs"
-plot "plot_cumulative.txt" using 1:2 with lines
-EOF1
-gnuplot plotit.gp 2>/dev/null
-#cp *.png ../
-echo `pwd`>/tmp/curdir
-echo `ls`>/tmp/dirlist
-#cd ..
-EOF
-sh /tmp/plotswiftlogs $swiftlog
-cp *.png $outdir/
-cat << EOF > $htmlfile
-<!DOCTYPE HTML>
-<html xmlns="http://www.w3.org/1999/xhtml">
-<head>
-  <title>2stage workflow output</title>
-</head>
-<body>
-<h2>Swift run trace plots</h2>
-<a href="activeplot.png" alt="active plot">active plot</a>
-<a href="cumulativeplot.png" alt="cumulative plot">cumulative plot</a>
-<h2>Browse output of 2stage application</h2>
-`for i in \`find $outdir -type f\`; do echo "<a href=\`basename $i\`>Output: \`basename $i\`</a><br/>"; done`
-</body>
-</html>
-EOF
-if [ "$EXITCODE" -ne "0" ]; then
-       cat std.err >&2
-fi
-cp std.err $logfile
-rm std.err
-exit $EXITCODE
Deleted: SwiftApps/swift-galaxy/swift/swift-3stage
--- SwiftApps/swift-galaxy/swift/swift-3stage	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/swift-3stage	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,325 +0,0 @@
-#!/bin/bash
-site=$1
-data=$2
-n=$3
-outdir=$4
-logfile=$5
-htmlfile=$6
-mkdir -p $outdir
-type file;
-type script;
-  cat @i stdout=@o;
-EOF
-case "$site" in
-midway )
-<config>
-  </pool>
-</config>
-EOF
-midway echo  echo
-midway cat   cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-uc3 )
-<config>
-  </pool>
-</config>
-EOF
-uc3 echo  /bin/echo
-uc3 cat   /bin/cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-stampede )
-<config>
-</pool>
-</config>
-EOF
-stampede echo echo
-stampede cat cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-localhost )
-<config>
-</pool>
-</config>
-EOF
-localhost cat cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-<config>
-  </pool>
-</config>
-EOF
-localhost cat cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-esac
-EXITCODE=$?
-#!/bin/bash
-SWIFTLOGFILE=$1
-#extract end time
-#duration
-(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > active.txt)
-(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > cumulative.txt)
-#prepare tics
-then
-fi
-then
-fi
-#final plot data
-set nokey
-EOF1
-#cp *.png ../
-#cd ..
-EOF
-cp *.png $outdir/
-#for i in `find $outdir`
-#do
-#  lastfile=$i
-#done
-#bname=`basename $lastfile`
-<!DOCTYPE HTML>
-<head>
-</head>
-<body>
-</body>
-</html>
-EOF
-       cat std.err >&2
-fi
-rm std.err
-exit $EXITCODE
Deleted: SwiftApps/swift-galaxy/swift/swift-skeleton.sh
--- SwiftApps/swift-galaxy/swift/swift-skeleton.sh	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/swift-skeleton.sh	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,187 +0,0 @@
-#!/bin/bash
-#set -x
-set -e
-site=$1
-data=$2
-n=$3
-outdir=$4
-logfile=$5
-htmlfile=$6
-mkdir -p $outdir
-swift=`which swift`
-cat << EOF > /tmp/script.swift
-# Place your Swift script here
-# Make sure all data references are full-path
-EOF
-case "$site" in
-midway )
-<?xml version="1.0" encoding="UTF-8"?>
-<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
-  <execution provider="coaster" url="swift.rcc.uchicago.edu" jobmanager="ssh-cl:slurm"/>
- </pool>
-</config>
-EOF
-uc3 )
- </pool>
-</config>
-EOF
-stampede )
-  <execution provider="coaster" jobmanager="ssh-cl:slurm" url="stampede.tacc.utexas.edu"/>
-</pool>
-</config>
-EOF
-localhost )
-  <execution provider="local" jobmanager="local:local"/>
-</pool>
-</config>
-EOF
-</pool>
-</config>
-EOF
-esac
-sitedir.keep=true
-lazy.errors=false
-EOF
-localhost cat cat
-stampede echo echo
-stampede cat cat
-uc3 echo echo
-uc3 cat cat
-midway echo echo
-midway cat cat
-EOF
-$swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/catsn.swift -n=$n -data=$data 2> $logfile
-EXITCODE=$?
-#do
-#  lastfile=$i
-#done
-<!DOCTYPE HTML>
-<head>
-  <title>Catsn output</title>
-</head>
-<body>
-<h2>Browse output of catsn application</h2>
-</body>
-</html>
-EOF
-       cat $logfile >&2
-fi
-exit $EXITCODE
Deleted: SwiftApps/swift-galaxy/swift/swift-skeleton.xml
--- SwiftApps/swift-galaxy/swift/swift-skeleton.xml	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/swift-skeleton.xml	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,22 +0,0 @@
-<tool id="skeleton(replace with an id)" name="Swift Skeleton (replace with a name)">
-  <description>A description here</description>
-  swift-skeleton.sh "$site" "$data" "$n" "$html_file.files_path" "$log_file" "$html_file"
-  </command>
-  <inputs>
-    </param>
-    <param name="n" type="text" value="1" label="Number of tasks to run "/>
-  </inputs>
-  <outputs>
-     <data format="txt" name="log_file" type="data" label="Standard out" />
-     <data format="html" name="html_file" label="catsnoutput.html" />
-  </outputs>
-</tool>
Deleted: SwiftApps/swift-galaxy/swift/tc
--- SwiftApps/swift-galaxy/swift/tc	2014-05-12 19:42:49 UTC (rev 7864)
+++ SwiftApps/swift-galaxy/swift/tc	2014-05-12 19:44:03 UTC (rev 7865)
@@ -1,7 +0,0 @@
-localhost cat cat
-localhost gensample   /home/maheshwari/powergridapps/bin/gensample.py
-localhost runampl   /home/maheshwari/powergridapps/bin/run_ampl.py
-localhost runampl_l /home/maheshwari/powergridapps/bin/run_ampl_l.py
-localhost runampl_u /home/maheshwari/powergridapps/bin/run_ampl_u.py
-localhost stage /scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/dogftp.sh
