[Swift-commit] r7867 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon May 12 16:00:07 CDT 2014
Author: ketan
Date: 2014-05-12 16:00:06 -0500 (Mon, 12 May 2014)
New Revision: 7867
Modified:
   SwiftApps/swift-galaxy/swift/swiftforeach.py
   SwiftApps/swift-galaxy/swift/swiftforeach.xml
Log:
clean up in code and some notes
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.py
--- SwiftApps/swift-galaxy/swift/swiftforeach.py	2014-05-12 19:45:46 UTC (rev 7866)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.py	2014-05-12 21:00:06 UTC (rev 7867)
@@ -37,19 +37,12 @@
     try:
         this=next(myargs)
         range_or_list = next(myargs)
-        #print "range or list=> "+ range_or_list
         k_or_t = next(myargs)
-        #print "k or t=> "+ k_or_t
         sites = next(myargs)
-        #print "sites=> " + sites
         swiftargs = next(myargs)
-        #print "swiftargs=> " + swiftargs
         interpreter = next(myargs)
-        #print "interpreter=> " + interpreter
         executable = next(myargs)
-        #print "executable=> " + executable
         stdin = next(myargs)
-        #print "stdin => " + stdin
         if range_or_list == "list":
             #list of items
@@ -64,7 +57,6 @@
         outloc = next(myargs)
         outlistfile = next(myargs)
-        #print "outlistfile=>"+outlistfile
         logfile = next(myargs)
         stringargs = next(myargs)
     except:
@@ -105,10 +97,8 @@
     #workout standard input file
     if stdin != "None":
         if k_or_t == "swiftK":
-            #print "stdinK"
             stdinfilexpr = "file stdinfile<\""+stdin+"\">;\n"
         else:
-            #print "stdinT"
             stdinfilexpr = "file stdinfile = input(\""+stdin+"\");\n"
     else:
         #print "no stdin"
@@ -137,8 +127,8 @@
             f.write("file listfile<\""+listfile+"\">;\n")
             f.write("string list[] = readData(listfile);\n");
             f.write("foreach l, i in list{\n")
-            f.write("file out <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".out\")>;\n")
-            f.write("file err <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".err\")>;\n")
+            f.write("    file out <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".out\")>;\n")
+            f.write("    file err <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".err\")>;\n")
         else:
@@ -157,15 +147,13 @@
         #print "%s %s %s" %(basedir, sites, wdir)
         subprocess.call([basedir+"/buildsite.sh", sites, wdir])
-        #build config
+        #build config file
         buildcfg(wdir)
-        #build tc
-        tc=open(wdir+"/tc", 'w');
-        for site in sites.split():
-            tc.write(site+' '+interpreter+' '+interpreter)
-        tc.close()
+        #build tc file
+        with open(wdir+"/tc", 'w') as tc:
+            for site in sites.split():
+                tc.write(site+' '+interpreter+' '+interpreter)
     else: # T
@@ -174,7 +162,7 @@
         f.write("import io;\n");
         f.write("\n");
         f.write(" app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){\n");
-        f.write(" \"" +interpreter+"\"  _exec _i _stringargs _fileargs @stdin=_stdin @stdout=_out @stderr=_err; \n");
+        f.write("  \"" +interpreter+"\"  _exec _i _stringargs _fileargs @stdin=_stdin @stdout=_out @stderr=_err; \n");
         f.write("}\n");
         f.write("main{\n");
         f.write(stringarrayexpr + " \n");
@@ -203,12 +191,10 @@
         f.write("}\n");
     f.close()
     #Invocation
-        #$swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
         with open(logfile,"wb") as errfile:
             exitcode=subprocess.check_call([swift, "-sites.file", wdir+"/sites.xml", "-tc.file", wdir+"/tc", "-config", wdir+"/cf", wdir+"/script.swift", swiftargs],stderr=errfile)
         print exitcode
@@ -216,7 +202,6 @@
     else:
         #print "Invoking T"
-        #EXITCODE=0
         stc=distutils.spawn.find_executable("stc")
         java=distutils.spawn.find_executable("java")
         turbine= distutils.spawn.find_executable("turbine")
@@ -246,24 +231,19 @@
         elif sites == "Mira":
             print "mira"
+            pwd=os.path.getcwd()
+            turbine_home="/home/wozniak/Public/sfw/ppc64/turbine"
+            stc="/home/wozniak/Public/sfw/ppc64/stc/bin/stc"
+            with open(logfile, "wb") as errfile:
+                exitcode=subprocess.check_call([stc, "-t", "checkpointing", "-r", pwd, "-j", java, wdir+"/script.swift"], stderr=errfile)
+            if exitcode == 0:
+                with open(logfile, "wb") as errfile, open("/dev/null", "r") as infile:
+                    exitcode=subprocess.check_call([turbine_home+"/scripts/submit/cobalt/turbine-cobalt-run.zsh", "-n", str(n), wdir+"/script.tcl"], stdin=infile, stderr=errfile)
         else:
-            print "site not recognized"
-        #"Vesta" )
-        #STC=/home/wozniak/Public/sfw/stc/bin/stc
-        #$STC -j $(\which java) -t checkpointing -r ${PWD} $wdir/script.swift 2>$logfile
-        #$TURBINE_HOME/scripts/submit/cobalt/turbine-cobalt-run.zsh -n $n -s $HOME/cf $wdir/script.tcl
-        #EXITCODE=$?
-        #"Mira" )
-        #TURBINE_HOME=/home/wozniak/Public/sfw/ppc64/turbine
-        #STC=/home/wozniak/Public/sfw/ppc64/stc/bin/stc
-        #$TURBINE_HOME/scripts/submit/cobalt/turbine-cobalt-run.zsh -n $n -i $HOME/prerun.sh -s $HOME/cf $wdir/script.tcl
-        #EXITCODE=$?
-        #esac
+            print "Site not recognized."
     #Populate output file
     outlist=subprocess.check_output(["find", outloc, "-type", "f", "-iname", "*.out"])
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.xml
--- SwiftApps/swift-galaxy/swift/swiftforeach.xml	2014-05-12 19:45:46 UTC (rev 7866)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.xml	2014-05-12 21:00:06 UTC (rev 7867)
@@ -82,7 +82,7 @@
             <option value="swiftT" >Swift/T</option>
         </param>
-        <param name="site" type="select" multiple="true" label="Execution Location" help="Multi-select list - hold the appropriate key while clicking to select multiple items">
+        <param name="site" type="select" multiple="true" label="Execution Location" help="Multi-select list - NOTE: Swift/T option currently supports one site">
             <option value="localhost" selected="true">Localhost</option>
             <option value="midway">Midway</option>
             <option value="uc3">UC3</option>
@@ -130,26 +130,7 @@
         </when>
         </conditional>
-        <conditional name="fileorstringarg">
-            <param name="fs" type="select" label="select weather to add file or string arg">
-                <option value="str" selected="true">string arg</option>
-                <option value="file">file arg</option>
-            </param>
-            <when value="str">
-                <repeat name="strarg1" title="strarg">
-                    <param name="str" size="60" type="text" label="stringargs1" />
-                </repeat>
-            </when>
-            <when value="file">
-                <repeat name="farg1" title="farg">
-                    <param name="str" type="data" label="fileargs1" />
-                </repeat>
-            </when>
-        </conditional>
         <param name="stringargs" size="60" type="text" label="stringargs" help="Add application call commandline arguments here" />
         <repeat name="filearg" title="file arg">
