[Swift-commit] r7589 - branches/release-0.95/src/org/griphyn/vdl/mapping/file
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Fri Feb 14 14:30:08 CST 2014
Author: davidk
Date: 2014-02-14 14:30:07 -0600 (Fri, 14 Feb 2014)
New Revision: 7589
Modified:
   branches/release-0.95/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
Log:
Bug 1171 fix from trunk
Modified: branches/release-0.95/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
--- branches/release-0.95/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java	2014-02-11 22:16:06 UTC (rev 7588)
+++ branches/release-0.95/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java	2014-02-14 20:30:07 UTC (rev 7589)
@@ -15,8 +15,8 @@
-package org.griphyn.vdl.mapping.file;
+package org.griphyn.vdl.mapping.file;
 import java.util.ArrayList;
 import java.util.Collection;
 import java.util.Collections;
@@ -27,27 +27,28 @@
 import org.apache.log4j.Logger;
 import org.griphyn.vdl.mapping.AbsFile;
+import org.griphyn.vdl.mapping.AbstractMapper;
 import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.HandleOpenException;
 import org.griphyn.vdl.mapping.InvalidPathException;
 import org.griphyn.vdl.mapping.MappingParamSet;
 import org.griphyn.vdl.mapping.Path;
 import org.griphyn.vdl.mapping.PhysicalFormat;
-public class StructuredRegularExpressionMapper extends AbstractFileMapper {
-        public static final Logger logger =
-            Logger.getLogger(StructuredRegularExpressionMapper.class);
+public class StructuredRegularExpressionMapper extends AbstractMapper {
+        public static final Logger logger =
+            Logger.getLogger(StructuredRegularExpressionMapper.class);
 	@Override
     protected void getValidMappingParams(Set<String> s) {
 	    s.addAll(StructuredRegularExpressionMapperParams.NAMES);
         super.getValidMappingParams(s);
-	public StructuredRegularExpressionMapper() {
+	public StructuredRegularExpressionMapper() {
 	@Override
     public String getName() {
         return "StructuredRegexpMapper";
@@ -58,80 +59,80 @@
         return new StructuredRegularExpressionMapperParams();
-    @Override
+    @Override
 	public Collection<Path> existing() {
-	    StructuredRegularExpressionMapperParams cp = getParams();
-		DSHandle sourceHandle = cp.getSource();
-		Collection<Path> output = new ArrayList<Path>();
-		Collection<DSHandle> sourceFields;
-		try {
-			sourceFields = sourceHandle.getFields(Path.CHILDREN);
-		catch (InvalidPathException ipe) {
-			return Collections.emptyList();
-		catch (HandleOpenException hoe) {
-			throw new RuntimeException(
-					"Handle open. Throwing this exception may not be the right thing to do. TODO");
-		Iterator<DSHandle> i = sourceFields.iterator();
-		while (i.hasNext()) {
-			DSHandle f = i.next();
-			output.add(f.getPathFromRoot());
-		return output;
+	    StructuredRegularExpressionMapperParams cp = getParams();
-	@Override
+		DSHandle sourceHandle = cp.getSource();
+		Collection<Path> output = new ArrayList<Path>();
+		Collection<DSHandle> sourceFields;
+		try {
+			sourceFields = sourceHandle.getFields(Path.CHILDREN);
+		catch (InvalidPathException ipe) {
+			return Collections.emptyList();
+		catch (HandleOpenException hoe) {
+			throw new RuntimeException(
+					"Handle open. Throwing this exception may not be the right thing to do. TODO");
+		Iterator<DSHandle> i = sourceFields.iterator();
+		while (i.hasNext()) {
+			DSHandle f = i.next();
+			output.add(f.getPathFromRoot());
+		return output;
+	@Override
 	public PhysicalFormat map(Path path) {
-	    if (logger.isDebugEnabled()) {
+	    if (logger.isDebugEnabled()) {
 	        logger.debug("map(): path: " + path);
-		DSHandle hereHandle;
-		try {
-			hereHandle = sourceHandle.getField(path);
-			throw new RuntimeException("Cannot get requested path " + path
-					+ " from source data structure");
+		DSHandle hereHandle;
+		try {
+			hereHandle = sourceHandle.getField(path);
+			throw new RuntimeException("Cannot get requested path " + path
+					+ " from source data structure");
-		PhysicalFormat source = hereHandle.getMapper().map(hereHandle.getPathFromRoot());
-		if (!source.getType().equals("file")) {
-					"Cannot use the regular expression mapper with a source that has a mapper that is not file-based");
-		Pattern p = Pattern.compile(cp.getMatch());
-		Matcher m = p.matcher(((AbsFile) source).getPath());
-		if (!m.find()) {
-			throw new RuntimeException("No match found! source='" + source + "' match = '" + cp.getMatch()
-		// find group number to replace
-		Pattern p2 = Pattern.compile("(\\\\\\d)");
-		Matcher m2 = p2.matcher(cp.getTransform());
-		StringBuffer sb = new StringBuffer();
-		while (m2.find()) {
-			String group = m2.group(1);
-			int g = Integer.parseInt(group.substring(1));
-			m2.appendReplacement(sb, m.group(g));
-		m2.appendTail(sb);
-		return new AbsFile(sb.toString());
-	public Path rmap(String name) {
-		return Path.EMPTY_PATH;
-	public boolean isStatic() {
-		return true;
+		PhysicalFormat source = hereHandle.getMapper().map(hereHandle.getPathFromRoot());
+		if (!source.getType().equals("file")) {
+					"Cannot use the regular expression mapper with a source that has a mapper that is not file-based");
+		Pattern p = Pattern.compile(cp.getMatch());
+		Matcher m = p.matcher(((AbsFile) source).getPath());
+		if (!m.find()) {
+			throw new RuntimeException("No match found! source='" + source + "' match = '" + cp.getMatch()
+		// find group number to replace
+		Pattern p2 = Pattern.compile("(\\\\\\d)");
+		Matcher m2 = p2.matcher(cp.getTransform());
+		StringBuffer sb = new StringBuffer();
+		while (m2.find()) {
+			String group = m2.group(1);
+			int g = Integer.parseInt(group.substring(1));
+			m2.appendReplacement(sb, m.group(g));
+		m2.appendTail(sb);
+		return new AbsFile(sb.toString());
+	public Path rmap(String name) {
+		return Path.EMPTY_PATH;
+	public boolean isStatic() {
+		return true;
