[Swift-commit] r7588 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Feb 11 16:16:07 CST 2014
Author: wozniak
Date: 2014-02-11 16:16:06 -0600 (Tue, 11 Feb 2014)
New Revision: 7588
Added:
   usertools/plotter/src/plotter/LineReaderException.java
Modified:
   usertools/plotter/src/plotter/LineReader.java
   usertools/plotter/src/plotter/Lines.java
Log:
Better error handling
Modified: usertools/plotter/src/plotter/LineReader.java
--- usertools/plotter/src/plotter/LineReader.java	2014-02-11 22:02:39 UTC (rev 7587)
+++ usertools/plotter/src/plotter/LineReader.java	2014-02-11 22:16:06 UTC (rev 7588)
@@ -88,14 +88,21 @@
        Take line-oriented data and produce an array of doubles.
+   * @throws LineReaderException
   public static double[][] array(List<String> lines)
+  throws LineReaderException
     List<String[]> tokens = tokens(lines);
     int columns = maxTokens(tokens);
     int rows = lines.size();
     double[][] result = new double[rows][columns];
     for (int i = 0; i < rows; i++)
+      String[] row = tokens.get(i);
+      if (row.length < columns)
+        throw new LineReaderException("Short row: " + i);
       for (int j = 0; j < columns; j++)
         try
@@ -108,9 +115,10 @@
         catch (NumberFormatException e)
-          throw new RuntimeException("Problem in row: " + i);
+          throw new LineReaderException("Bad number in row: " + i);
     return result;
Added: usertools/plotter/src/plotter/LineReaderException.java
--- usertools/plotter/src/plotter/LineReaderException.java	                        (rev 0)
+++ usertools/plotter/src/plotter/LineReaderException.java	2014-02-11 22:16:06 UTC (rev 7588)
@@ -0,0 +1,10 @@
+package plotter;
+public class LineReaderException extends Exception
+  public LineReaderException(String msg)
+    super(msg);
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java	2014-02-11 22:02:39 UTC (rev 7587)
+++ usertools/plotter/src/plotter/Lines.java	2014-02-11 22:16:06 UTC (rev 7588)
@@ -103,11 +103,25 @@
     scanProperties();
+    readDataFiles(names, data, labels);
+    XYSeriesCollection collection =
+        collection(data, labels, names);
+    plot(collection, title, xlabel, ylabel, output);
+  static void readDataFiles(List<String> names,
+                            List<double[][]> data,
+                            List<String> labels)
+  throws UserInputException
     for (String name : names)
       File file = new File(name);
       Util.verbose("open: " + file);
       List<String> lines = null;
+      double[][] array;
       try
         lines = LineReader.read(file);
@@ -116,26 +130,28 @@
           System.err.println("Problem when reading: "+file);
+        array = LineReader.array(lines);
       catch (FileNotFoundException e)
-        System.err.println("not found: " + file);
-        System.exit(1);
+        throw new UserInputException("not found: " + file);
-      double[][] array = LineReader.array(lines);
+      catch (LineReaderException e)
+        (e.getMessage() + "\n" + "In file: " + file);
       if (array.length == 0)
-        throw new UserInputException("file has no data: " + name);
+        ("file has no data: " + name);
       if (array[0].length != 2)
-        throw new UserInputException("file is not two-column: " + name);
+        ("file is not two-column: " + name);
       data.add(array);
       addLabel(name, labels);
       Util.verbose("array:\n" + toString(array));
-    XYSeriesCollection collection = collection(data, labels,
-                                               names);
-    plot(collection, title, xlabel, ylabel, output);
