[Swift-commit] r7590 - branches/release-0.94/docs/userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Fri Feb 14 16:33:46 CST 2014
Author: ketan
Date: 2014-02-14 16:33:46 -0600 (Fri, 14 Feb 2014)
New Revision: 7590
Modified:
   branches/release-0.94/docs/userguide/log-processing
Log:
uncommenting log meaning
Modified: branches/release-0.94/docs/userguide/log-processing
--- branches/release-0.94/docs/userguide/log-processing	2014-02-14 20:30:07 UTC (rev 7589)
+++ branches/release-0.94/docs/userguide/log-processing	2014-02-14 22:33:46 UTC (rev 7590)
@@ -117,7 +117,6 @@
 message itself. The types of log messages follows the java log4j standard types
 of TRACE, DEBUG, INFO, WARN, ERROR and FATAL.
 This section lists the various Swift log messages and explains the meaning and
 likely interpretation of those messages. Note that the list is not
 comprehensive at this time. Also note that we will ignore the timestamps here.
@@ -151,4 +150,3 @@
 The job ended successfully
 . _INFO  WeightedHostScoreScheduler CONTACT_SELECTED host=localhost, score=99.854_
 . _
