[Swift-commit] r7587 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Feb 11 16:02:39 CST 2014
Author: wozniak
Date: 2014-02-11 16:02:39 -0600 (Tue, 11 Feb 2014)
New Revision: 7587
Modified:
   usertools/plotter/src/plotter/LineReader.java
Log:
Restore tab indent 2
Modified: usertools/plotter/src/plotter/LineReader.java
--- usertools/plotter/src/plotter/LineReader.java	2014-02-11 21:54:47 UTC (rev 7586)
+++ usertools/plotter/src/plotter/LineReader.java	2014-02-11 22:02:39 UTC (rev 7587)
@@ -13,140 +13,140 @@
 public class LineReader
-    public static List<String> read(File file)
-        throws FileNotFoundException
-        BufferedReader reader =
-            new BufferedReader(new FileReader(file));
-        return read(reader);
+  public static List<String> read(File file)
+      throws FileNotFoundException
+    BufferedReader reader =
+        new BufferedReader(new FileReader(file));
+    return read(reader);
-    public static List<String> read(String s)
-            new BufferedReader(new StringReader(s));
+  public static List<String> read(String s)
+        new BufferedReader(new StringReader(s));
-    public static List<String> read(BufferedReader reader)
+  public static List<String> read(BufferedReader reader)
+    List<String> result = new ArrayList<String>();
+    try
-        List<String> result = new ArrayList<String>();
-        try
+      String prevline = "";
+      String line = "";
+      while ((line = reader.readLine()) != null)
+        int hash = line.indexOf("#");
+        if (hash >= 0)
+          line = line.substring(0,hash);
+        line = spaces(line);
+        line = (prevline + " " + line).trim();
+        if (line.endsWith("\\"))
-            String prevline = "";
-            String line = "";
-            while ((line = reader.readLine()) != null)
-                int hash = line.indexOf("#");
-                if (hash >= 0)
-                    line = line.substring(0,hash);
-                line = spaces(line);
-                line = (prevline + " " + line).trim();
-                if (line.endsWith("\\"))
-                    line = line.substring(0, line.length()-2);
-                    prevline = line;
-                    continue;
-                else
-                    prevline = "";
-                    line = line.trim();
-                    if (line.length() > 0)
-                        result.add(line);
-            reader.close();
+          line = line.substring(0, line.length()-2);
+          prevline = line;
+          continue;
-        catch (IOException e)
+        else
-            System.err.println("LineReader: I/O problem.");
-            return null;
+          prevline = "";
+          line = line.trim();
+          if (line.length() > 0)
+            result.add(line);
-        return result;
+      reader.close();
-    public static List<String[]> tokens(List<String> lines)
+    catch (IOException e)
-        List<String[]> result = new ArrayList<String[]>(lines.size());
-        for (String line : lines)
-            String[] tokens = tokenize(line);
-            result.add(tokens);
-        return result;
+      System.err.println("LineReader: I/O problem.");
+      return null;
+    return result;
-    public static int maxTokens(List<String[]> tokens)
+  public static List<String[]> tokens(List<String> lines)
+    List<String[]> result = new ArrayList<String[]>(lines.size());
+    for (String line : lines)
-        int result = 0;
-        for (String[] t : tokens)
-            if (t.length > result)
-                result = t.length;
-        return result;
+      String[] tokens = tokenize(line);
+      result.add(tokens);
+    return result;
+  public static int maxTokens(List<String[]> tokens)
+    int result = 0;
+    for (String[] t : tokens)
+      if (t.length > result)
+        result = t.length;
+    return result;
        Take line-oriented data and produce an array of doubles.
-    public static double[][] array(List<String> lines)
-        List<String[]> tokens = tokens(lines);
-        int columns = maxTokens(tokens);
-        int rows = lines.size();
-        double[][] result = new double[rows][columns];
-        for (int i = 0; i < rows; i++)
-            for (int j = 0; j < columns; j++)
-                try
-                    String v = tokens.get(i)[j];
-                    v = v.replaceAll(",", "");
-                    v = v.replaceAll("%", "");
-                    double d = Double.parseDouble(v);
-                    result[i][j] = d;
-                catch (NumberFormatException e)
-                    throw new RuntimeException("Problem in row: " + i);
-        return result;
-    public static String spaces(String line)
-        String result = "";
-        for (int i = 0; i < line.length(); i++)
+  public static double[][] array(List<String> lines)
+    List<String[]> tokens = tokens(lines);
+    int columns = maxTokens(tokens);
+    int rows = lines.size();
+    double[][] result = new double[rows][columns];
+    for (int i = 0; i < rows; i++)
+      for (int j = 0; j < columns; j++)
+        try
-            if (line.charAt(i)   == '=' &&
-                line.charAt(i+1) != '=' &&
-                line.charAt(i-1) != '=')
-                result += " = ";
-            else
-                result += line.substring(i,i+1);
+          String v = tokens.get(i)[j];
+          v = v.replaceAll(",", "");
+          v = v.replaceAll("%", "");
+          double d = Double.parseDouble(v);
+          result[i][j] = d;
-        return result;
+        catch (NumberFormatException e)
+          throw new RuntimeException("Problem in row: " + i);
+    return result;
-    public static String[] tokenize(String line)
+  public static String spaces(String line)
+    String result = "";
+    for (int i = 0; i < line.length(); i++)
-        if (line == null)
-            return null;
-        List<String> words = new ArrayList<String>();
-        String[] ws = line.split("\\s");
-        for (int i = 0; i < ws.length; i++)
-            if (ws[i].length() > 0)
-                words.add(ws[i]);
-        String[] result = new String[words.size()];
-        for (int i = 0; i < words.size(); i++)
-            result[i] = words.get(i);
-        return result;
+      if (line.charAt(i)   == '=' &&
+          line.charAt(i+1) != '=' &&
+          line.charAt(i-1) != '=')
+        result += " = ";
+      else
+        result += line.substring(i,i+1);
+    return result;
+  public static String[] tokenize(String line)
+    if (line == null)
+      return null;
+    List<String> words = new ArrayList<String>();
+    String[] ws = line.split("\\s");
+    for (int i = 0; i < ws.length; i++)
+      if (ws[i].length() > 0)
+        words.add(ws[i]);
+    String[] result = new String[words.size()];
+    for (int i = 0; i < words.size(); i++)
+      result[i] = words.get(i);
+    return result;
       public static List<String> list(String line)
@@ -155,5 +155,5 @@
       result.add(tokens[i]);
       return result;
