[Swift-commit] r6059 - in trunk/src/org/griphyn/vdl: karajan karajan/lib mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Nov 18 04:50:47 CST 2012
Author: hategan
Date: 2012-11-18 04:50:43 -0600 (Sun, 18 Nov 2012)
New Revision: 6059
Modified:
   trunk/src/org/griphyn/vdl/karajan/VDL2ExecutionContext.java
   trunk/src/org/griphyn/vdl/karajan/lib/New.java
   trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
   trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
   trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
added duplicate mapping checker
Modified: trunk/src/org/griphyn/vdl/karajan/VDL2ExecutionContext.java
--- trunk/src/org/griphyn/vdl/karajan/VDL2ExecutionContext.java	2012-11-18 08:48:48 UTC (rev 6058)
+++ trunk/src/org/griphyn/vdl/karajan/VDL2ExecutionContext.java	2012-11-18 10:50:43 UTC (rev 6059)
@@ -29,12 +29,14 @@
 import org.globus.cog.karajan.workflow.ExecutionContext;
 import org.globus.cog.karajan.workflow.ExecutionException;
 import org.griphyn.vdl.karajan.functions.ProcessBulkErrors;
+import org.griphyn.vdl.mapping.DuplicateMappingChecker;
 public class VDL2ExecutionContext extends ExecutionContext {
 	public static final Logger logger = Logger.getLogger(VDL2ExecutionContext.class);
 	public static final String RUN_ID = "vdl:runid";
 	public static final String SCRIPT_NAME = "vdl:scriptname";
+	public static final String DM_CHECKER = "vdl:dpmchecker";
 	private String runID;
 	private final String scriptName;
@@ -98,6 +100,7 @@
 		super.setGlobals(stack);
 		stack.setGlobal(RUN_ID, runID);
 		stack.setGlobal(SCRIPT_NAME, scriptName);
+		stack.setGlobal(DM_CHECKER, new DuplicateMappingChecker());
 	public String getRunID() {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/New.java
--- trunk/src/org/griphyn/vdl/karajan/lib/New.java	2012-11-18 08:48:48 UTC (rev 6058)
+++ trunk/src/org/griphyn/vdl/karajan/lib/New.java	2012-11-18 10:50:43 UTC (rev 6059)
@@ -29,8 +29,10 @@
 import org.globus.cog.karajan.stack.VariableStack;
 import org.globus.cog.karajan.util.TypeUtil;
+import org.griphyn.vdl.karajan.VDL2ExecutionContext;
 import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.ExternalDataNode;
 import org.griphyn.vdl.mapping.MappingParam;
 import org.griphyn.vdl.mapping.MappingParamSet;
@@ -120,7 +122,8 @@
 			else if (type.isArray()) {
 				// dealing with array variable
-				handle = new RootArrayDataNode(type);
+				handle = new RootArrayDataNode(type,
+				    (DuplicateMappingChecker) stack.getGlobal(VDL2ExecutionContext.DM_CHECKER));
 				if (value != null) {
 					if (value instanceof RootArrayDataNode) {
 					    if (tracer.isEnabled()) {
@@ -169,7 +172,8 @@
 				handle = (DSHandle) value;
 			else {
-				handle = new RootDataNode(type);
+				handle = new RootDataNode(type,
 				handle.init(mps);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2012-11-18 08:48:48 UTC (rev 6058)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2012-11-18 10:50:43 UTC (rev 6059)
@@ -28,13 +28,9 @@
 import org.globus.cog.karajan.arguments.Arg;
 import org.globus.cog.karajan.stack.VariableNotFoundException;
-import org.globus.cog.karajan.util.ThreadingContext;
-import org.globus.cog.karajan.workflow.futures.Future;
 import org.globus.cog.karajan.workflow.futures.FutureFault;
 import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
-import org.griphyn.vdl.karajan.DSHandleFutureWrapper;
-import org.griphyn.vdl.karajan.FutureWrapper;
 import org.griphyn.vdl.karajan.Pair;
 import org.griphyn.vdl.karajan.PairIterator;
 import org.griphyn.vdl.karajan.WaitingThreadsMonitor;
Modified: trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java	2012-11-18 08:48:48 UTC (rev 6058)
+++ trunk/src/org/griphyn/vdl/mapping/RootArrayDataNode.java	2012-11-18 10:50:43 UTC (rev 6059)
@@ -34,6 +34,7 @@
 	private Mapper mapper;
 	private MappingParamSet params;
 	private AbstractDataNode waitingMapperParam;
+	private DuplicateMappingChecker dmc;
 	private static final Tracer tracer = Tracer.getTracer("VARIABLE");
@@ -42,6 +43,11 @@
 	public RootArrayDataNode(Type type) {
 		super(Field.Factory.createField(null, type), null, null);
+	public RootArrayDataNode(Type type, DuplicateMappingChecker dmc) {
+	    this(type);
+	    this.dmc = dmc;
 	public void init(MappingParamSet params) {
@@ -90,7 +96,7 @@
 	private void checkInputs() {
 		try {
-			RootDataNode.checkInputs(params, mapper, this);
+			RootDataNode.checkInputs(params, mapper, this, dmc);
 		catch (DependentException e) {
 			setValue(new MappingDependentException(this, e));
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2012-11-18 08:48:48 UTC (rev 6058)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2012-11-18 10:50:43 UTC (rev 6059)
@@ -38,13 +38,19 @@
-	public RootDataNode(Type type) {
+	public RootDataNode(Type type, DuplicateMappingChecker dmc) {
 		super(Field.Factory.createField(null, type));
+		this.dmc = dmc;
+	public RootDataNode(Type type) {
+	    this(type, null);
 	public RootDataNode(Type type, Object value) {
 	    this(type);
 	    initialized();
@@ -99,7 +105,7 @@
 		try {
-			checkInputs(params, mapper, this);
+			checkInputs(params, mapper, this, dmc);
@@ -113,10 +119,11 @@
-	static protected void checkInputs(MappingParamSet params, Mapper mapper, AbstractDataNode root) {
+	static protected void checkInputs(MappingParamSet params, Mapper mapper, AbstractDataNode root,
+	        DuplicateMappingChecker dmc) {
 		String input = (String) params.get(MappingParam.SWIFT_INPUT);
 		if (input != null && Boolean.valueOf(input.trim()).booleanValue()) {
-			addExisting(mapper, root);
+			addExisting(mapper, root, dmc);
 			checkConsistency(root);
 		else if (mapper.isStatic()) {
@@ -131,10 +138,12 @@
 		        logger.debug("mapper: " + mapper);
 			for (Path p : mapper.existing()) {
+			    PhysicalFormat f = mapper.map(p);
 				try {
 					// Try to get the path in order to check that the
 				    // path is valid - we'll get an exception if not
-					root.getField(p);
+					DSHandle h = root.getField(p);
+					dmc.addWrite(f, h);
 					    tracer.trace(root.getThread(), root.getDeclarationLine(),
 					        root.getDisplayableName() + " MAPPING " + p + ", " + mapper.map(p));
@@ -154,12 +163,14 @@
-	private static void addExisting(Mapper mapper, AbstractDataNode root) {
+	private static void addExisting(Mapper mapper, AbstractDataNode root, DuplicateMappingChecker dmc) {
 	    boolean any = false;
             try {
                 DSHandle field = root.getField(p);
                 field.closeShallow();
+                dmc.addRead(f, field);
