[Swift-commit] r6058 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Nov 18 02:48:51 CST 2012
Author: hategan
Date: 2012-11-18 02:48:48 -0600 (Sun, 18 Nov 2012)
New Revision: 6058
Modified:
   trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
more tracing of existing fields and also mention whether no files are found
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2012-11-18 08:44:46 UTC (rev 6057)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2012-11-18 08:48:48 UTC (rev 6058)
@@ -155,13 +155,16 @@
 	private static void addExisting(Mapper mapper, AbstractDataNode root) {
+	    boolean any = false;
 		for (Path p : mapper.existing()) {
             try {
                 DSHandle field = root.getField(p);
                 field.closeShallow();
-                if (logger.isInfoEnabled()) {
-                    logger.info("Found data " + root + "." + p);
+                if (tracer.isEnabled()) {
+                    tracer.trace(root.getThread(), root.getDeclarationLine(),
+                        root.getDisplayableName() + " MAPPING " + p + ", " + mapper.map(p));
+                any = true;
             catch (InvalidPathException e) {
                 throw new IllegalStateException("Structure of mapped data is " +
@@ -169,6 +172,10 @@
         root.closeDeep();
+        if (!any && tracer.isEnabled()) {
+                root.getDisplayableName() + " MAPPING no files found");
     public static void checkConsistency(DSHandle handle) {
