[Swift-commit] r6060 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Nov 18 05:07:46 CST 2012
Author: hategan
Date: 2012-11-18 05:07:46 -0600 (Sun, 18 Nov 2012)
New Revision: 6060
Added:
   trunk/src/org/griphyn/vdl/mapping/DuplicateMappingChecker.java
Log:
added the actual duplicate mapping check class
Added: trunk/src/org/griphyn/vdl/mapping/DuplicateMappingChecker.java
--- trunk/src/org/griphyn/vdl/mapping/DuplicateMappingChecker.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/DuplicateMappingChecker.java	2012-11-18 11:07:46 UTC (rev 6060)
@@ -0,0 +1,95 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Nov 18, 2012
+package org.griphyn.vdl.mapping;
+import java.util.HashMap;
+import java.util.LinkedList;
+import java.util.List;
+import java.util.Map;
+import org.apache.log4j.Logger;
+public class DuplicateMappingChecker {
+    public static final Logger logger = Logger.getLogger(DuplicateMappingChecker.class);
+    private final Map<PhysicalFormat, Entry> map;
+    public DuplicateMappingChecker() {
+        map = new HashMap<PhysicalFormat, Entry>();
+    private static class Entry {
+        private DSHandle write;
+        private List<DSHandle> read;
+    private Entry getEntry(PhysicalFormat f) {
+        Entry e = map.get(f);
+        if (e == null) {
+            e = new Entry();
+            map.put(f, e);
+        return e;
+    public synchronized void addRead(PhysicalFormat f, DSHandle h) {
+        Entry e = getEntry(f);
+        if (e.write != null) {
+            warn("Duplicate mapping found:\n\t" +
+                getVarInfo(h) + " is used to read from " + f + "\n\t" +
+                getVarInfo(e.write) + " is used to write to " + f);
+        if (e.read == null) {
+            e.read = new LinkedList<DSHandle>();
+        e.read.add(h);
+    public synchronized void addWrite(PhysicalFormat f, DSHandle h) {
+                getVarInfo(h) + " and " + getVarInfo(e.write) + " are both used to write to " + f);
+        if (e.read != null) {
+                getVarInfo(e.write) + " is used to write to " + f + "\n\t" +
+                "The following variables(s) are also used to read from " + f + ":" + getVarInfos(e.read));
+        e.write = h;
+    private void warn(String s) {
+        if (logger.isInfoEnabled()) {
+            logger.info(s);
+        System.err.println(s);
+    private String getVarInfos(List<DSHandle> l) {
+        StringBuilder sb = new StringBuilder();
+        for (DSHandle h : l) {
+            sb.append("\n\t\t");
+            sb.append(getVarInfo(h));
+        return sb.toString();
+    private String getVarInfo(DSHandle h) {
+        if (h instanceof AbstractDataNode) {
+            AbstractDataNode a = (AbstractDataNode) h;
+            return a.getDisplayableName() + " (line " + a.getDeclarationLine() + ")";
+        else {
+            return String.valueOf(h);
