[Swift-commit] r3167 - in trunk/src/org/griphyn/vdl/type: . impl
Fri Oct 16 16:53:10 CDT 2009
Author: hategan
Date: 2009-10-16 16:53:10 -0500 (Fri, 16 Oct 2009)
New Revision: 3167
Modified:
   trunk/src/org/griphyn/vdl/type/Type.java
   trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java
   trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java
Log:
added isComposite() to distinguish between array or struct and non-array and non-struct types
Modified: trunk/src/org/griphyn/vdl/type/Type.java
--- trunk/src/org/griphyn/vdl/type/Type.java	2009-10-16 20:14:48 UTC (rev 3166)
+++ trunk/src/org/griphyn/vdl/type/Type.java	2009-10-16 21:53:10 UTC (rev 3167)
@@ -52,6 +52,11 @@
 	public URI getNamespaceURI();
 	boolean isArray();
+	 * Returns true if this type is a composite type (array or struct).
+	boolean isComposite();
 	 * set the full name as a QName
Modified: trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java
--- trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java	2009-10-16 20:14:48 UTC (rev 3166)
+++ trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java	2009-10-16 21:53:10 UTC (rev 3167)
@@ -107,8 +107,13 @@
 	public void setPrimitive() {
 		primitive = true;
-	private static class Array extends TypeImpl {
+    public boolean isComposite() {
+        return isArray() || !fields.isEmpty();
+    private static class Array extends TypeImpl {
 		private Field field;
 		/** Constructs an array that will contain elements of the
Modified: trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java
--- trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java	2009-10-16 20:14:48 UTC (rev 3166)
+++ trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java	2009-10-16 21:53:10 UTC (rev 3167)
@@ -86,8 +86,12 @@
 	public boolean isArray() {
 		return this.name.endsWith("[]");
+        return isArray();
-	public void setBaseType(Type base) {
+    public void setBaseType(Type base) {
 		throw new UnsupportedOperationException();
