[Swift-commit] r3166 - trunk/src/org/griphyn/vdl/karajan
Fri Oct 16 15:14:48 CDT 2009
Author: hategan
Date: 2009-10-16 15:14:48 -0500 (Fri, 16 Oct 2009)
New Revision: 3166
Modified:
   trunk/src/org/griphyn/vdl/karajan/Loader.java
Log:
added reduced logging flag
Modified: trunk/src/org/griphyn/vdl/karajan/Loader.java
--- trunk/src/org/griphyn/vdl/karajan/Loader.java	2009-10-16 20:14:19 UTC (rev 3165)
+++ trunk/src/org/griphyn/vdl/karajan/Loader.java	2009-10-16 20:14:48 UTC (rev 3166)
@@ -35,13 +35,16 @@
 import org.globus.cog.karajan.workflow.PrintStreamChannel;
 import org.globus.cog.karajan.workflow.nodes.FlowElement;
 import org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode;
+import org.globus.cog.karajan.workflow.service.channels.AbstractKarajanChannel;
 import org.globus.cog.util.ArgumentParser;
 import org.globus.cog.util.ArgumentParserException;
 import org.griphyn.vdl.engine.Karajan;
 import org.griphyn.vdl.karajan.functions.ConfigProperty;
 import org.griphyn.vdl.karajan.lib.Execute;
 import org.griphyn.vdl.karajan.lib.Log;
+import org.griphyn.vdl.karajan.lib.New;
 import org.griphyn.vdl.karajan.monitor.MonitorAppender;
+import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.toolkit.VDLt2VDLx;
 import org.griphyn.vdl.toolkit.VDLt2VDLx.IncorrectInvocationException;
 import org.griphyn.vdl.toolkit.VDLt2VDLx.ParsingException;
@@ -64,6 +67,7 @@
     public static final String ARG_RUNID = "runid";
     public static final String ARG_TUI = "tui";
     public static final String ARG_RECOMPILE = "recompile";
+    public static final String ARG_REDUCED_LOGGING = "reduced.logging";
     public static final String CONST_VDL_OPERATION = "vdl:operation";
     public static final String VDL_OPERATION_RUN = "run";
@@ -397,6 +401,8 @@
                 "Specifies the run identifier. This must be unique for every invocation of a workflow and is used in several places to keep files from different executions cleanly separated. By default, a datestamp and random number are used to generate a run identifier.",
                 "string", ArgumentParser.OPTIONAL);
         ap.addFlag(ARG_TUI);
+        ap.addFlag(ARG_REDUCED_LOGGING, "Makes logging more terse by disabling provenance " +
+        		"information and low-level task messages");
         Map desc = VDL2ConfigProperties.getPropertyDescriptions();
         Iterator i = desc.entrySet().iterator();
@@ -457,6 +463,11 @@
                 Level.INFO);
             ca.setThreshold(Level.FATAL);
+        else if (ap.isPresent(ARG_REDUCED_LOGGING)) {
+            Logger.getLogger(AbstractDataNode.class).setLevel(Level.WARN);
+            Logger.getLogger(New.class).setLevel(Level.WARN);
+            Logger.getLogger("org.globus.cog.karajan.workflow.service").setLevel(Level.WARN);
     protected static Appender getAppender(Class cls) {
