[Swift-commit] r3168 - trunk/src/org/griphyn/vdl/mapping
Fri Oct 16 16:53:39 CDT 2009
Author: hategan
Date: 2009-10-16 16:53:38 -0500 (Fri, 16 Oct 2009)
New Revision: 3168
Modified:
   trunk/src/org/griphyn/vdl/mapping/Path.java
Log:
cache toString()
Modified: trunk/src/org/griphyn/vdl/mapping/Path.java
--- trunk/src/org/griphyn/vdl/mapping/Path.java	2009-10-16 21:53:10 UTC (rev 3167)
+++ trunk/src/org/griphyn/vdl/mapping/Path.java	2009-10-16 21:53:38 UTC (rev 3168)
@@ -19,6 +19,8 @@
 	/** True if any element of the Path contains a wildcard. */
 	private boolean wildcard;
+	private String tostrcached;
 	public static class EmptyPath extends Path {
 		public EmptyPath() {
@@ -245,7 +247,10 @@
 	 * made that <code>Path.parse(somePath.stringForm()).equals(somePath)</code>.
 	 * For a consistent such representation of this path use {@link stringForm}.
-	public String toString() {
+	public synchronized String toString() {
+	    if (tostrcached != null) {
+	        return tostrcached;
 		StringBuffer sb = new StringBuffer();
 		Iterator i = iterator();
 		while (i.hasNext()) {
@@ -260,7 +265,7 @@
 				sb.append(e.getName());
-		return sb.toString();
+		return tostrcached = sb.toString();
 	public Iterator iterator() {
