[petsc-users] Unique number in each element of a DMPlex mesh
Berend van Wachem berend.vanwachem at ovgu.de
Mon Jan 22 13:27:42 CST 2024
Dear Matt,
The problem is that I haven't figured out how to write a polyhedral DMplex in parallel. So, currently, I can write the Vec data
in parallel, but the cones for the cells/faces/edges/nodes for the mesh from just one process to a file (after gathering the
DMplex to a single process).
 From the restart, I can then read the cone information from one process from the file, recreate the DMPlex, and then
redistribute it. In this scenario, the Vec data I read in (in parallel) will not match the correct cells of the DMplex. Hence, I
need to put it in the right place afterwards.
Best, Berend.
On 1/22/24 20:03, Matthew Knepley wrote:
> On Mon, Jan 22, 2024 at 1:57 PM Berend van Wachem <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>> wrote:
>     Dear Matt,
>     Thanks for your quick response.
>     I have a DMPlex with a polyhedral mesh, and have defined a number of vectors with data at the cell center. I have generated
>     data
>     for a number of timesteps, and I write the data for each point to a file together with the (x,y,z) co-ordinate of the cell
>     center.
>     When I want to do a restart from the DMPlex, I recreate the DMplex with the polyhedral mesh, redistribute it, and for each cell
>     center find the corresponding (x,y,z) co-ordinate and insert the data that corresponds to it. This is quite expensive, as it
>     means I need to compare doubles very often.
>     But reading your response, this may not be a bad way of doing it?
> It always seems to be a game of "what do you want to assume?". I tend to assume that I wrote the DM and Vec in the same order,
> so when I load them they match. This is how Firedrake I/O works, so that you can load up on a different number of processes
> (https://arxiv.org/abs/2401.05868 <https://arxiv.org/abs/2401.05868>).
> So, are you writing a Vec, and then redistributing and writing another Vec? In the scheme above, you would have to write both
> DMs. Are you trying to avoid this?
>    Thanks,
>       Matt
>     Thanks,
>     Berend.
>     On 1/22/24 18:58, Matthew Knepley wrote:
>      > On Mon, Jan 22, 2024 at 10:49 AM Berend van Wachem <berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>
>     <mailto:berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>>> wrote:
>      >     Dear Petsc-Team,
>      >     Is there a good way to define a unique integer number in each element
>      >     (e.g. a cell) of a DMPlex mesh, which is in the same location,
>      >     regardless of the number of processors or the distribution of the mesh
>      >     over the processors?
>      >     So, for instance, if I have a DMPlex box mesh, the top-right-front
>      >     corner element (e.g. cell) will always have the same unique number,
>      >     regardless of the number of processors the mesh is distributed over?
>      >     I want to be able to link the results I have achieved with a mesh from
>      >     DMPlex on a certain number of cores to the same mesh from a DMPlex on a
>      >     different number of cores.
>      >     Of course, I could make a tree based on the distance of each element to
>      >     a certain point (based on the X,Y,Z co-ordinates of the element), and go
>      >     through this tree in the same way and define an integer based on this,
>      >     but that seems rather cumbersome.
>      > I think this is harder than it sounds. The distance will not work because it can be very degenerate.
>      > You could lexicographically sort the coordinates, but this is hard in parallel. It is fine if you are willing
>      > to gather everything on one process. You could put down a p4est, use the Morton order to number them since this is stable
>     for a
>      > given refinement. And then within each box lexicographically sort the centroids. This is definitely cumbersome, but I cannot
>      > think of anything else. This also might have parallel problems since you need to know how much overlap you need to fill
>     each box.
>      >    Thanks,
>      >        Matt
>      >     Thanks and best regards, Berend.
>      > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any
>     results to
>      > which their experiments lead.
>      > -- Norbert Wiener
>      > https://www.cse.buffalo.edu/~knepley/ <https://www.cse.buffalo.edu/~knepley/> <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>>
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
