[petsc-users] Unique number in each element of a DMPlex mesh
Mon Jan 22 13:30:32 CST 2024
On Mon, Jan 22, 2024 at 2:26 PM Berend van Wachem <berend.vanwachem at ovgu.de>
wrote:
> Dear Matt,
> The problem is that I haven't figured out how to write a polyhedral DMplex
> in parallel. So, currently, I can write the Vec data
> in parallel, but the cones for the cells/faces/edges/nodes for the mesh
> from just one process to a file (after gathering the
> DMplex to a single process).
Ah shoot. Can you send me a polyhedral mesh (or code to generate one) so I
can fix the parallel write problem? Or maybe it is already an issue and I
forgot?
>  From the restart, I can then read the cone information from one process
> from the file, recreate the DMPlex, and then
> redistribute it. In this scenario, the Vec data I read in (in parallel)
> will not match the correct cells of the DMplex. Hence, I
> need to put it in the right place afterwards.
Yes, then searching makes sense. You could call DMLocatePoints(), but maybe
you are doing that.
     Matt
> Best, Berend.
> On 1/22/24 20:03, Matthew Knepley wrote:
> > On Mon, Jan 22, 2024 at 1:57 PM Berend van Wachem <
> berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>> wrote:
> >     Dear Matt,
> >     Thanks for your quick response.
> >     I have a DMPlex with a polyhedral mesh, and have defined a number of
> vectors with data at the cell center. I have generated
> >     data
> >     for a number of timesteps, and I write the data for each point to a
> file together with the (x,y,z) co-ordinate of the cell
> >     center.
> >     When I want to do a restart from the DMPlex, I recreate the DMplex
> with the polyhedral mesh, redistribute it, and for each cell
> >     center find the corresponding (x,y,z) co-ordinate and insert the
> data that corresponds to it. This is quite expensive, as it
> >     means I need to compare doubles very often.
> >     But reading your response, this may not be a bad way of doing it?
> > It always seems to be a game of "what do you want to assume?". I tend to
> assume that I wrote the DM and Vec in the same order,
> > so when I load them they match. This is how Firedrake I/O works, so that
> you can load up on a different number of processes
> > (https://arxiv.org/abs/2401.05868 <https://arxiv.org/abs/2401.05868>).
> > So, are you writing a Vec, and then redistributing and writing another
> Vec? In the scheme above, you would have to write both
> > DMs. Are you trying to avoid this?
> >    Thanks,
> >       Matt
> >     Thanks,
> >     Berend.
> >     On 1/22/24 18:58, Matthew Knepley wrote:
> >      > On Mon, Jan 22, 2024 at 10:49 AM Berend van Wachem <
> >     <mailto:berend.vanwachem at ovgu.de <mailto:berend.vanwachem at ovgu.de>>>
> wrote:
> >      >     Dear Petsc-Team,
> >      >     Is there a good way to define a unique integer number in each
> element
> >      >     (e.g. a cell) of a DMPlex mesh, which is in the same location,
> >      >     regardless of the number of processors or the distribution of
> the mesh
> >      >     over the processors?
> >      >     So, for instance, if I have a DMPlex box mesh, the
> top-right-front
> >      >     corner element (e.g. cell) will always have the same unique
> number,
> >      >     regardless of the number of processors the mesh is
> distributed over?
> >      >     I want to be able to link the results I have achieved with a
> mesh from
> >      >     DMPlex on a certain number of cores to the same mesh from a
> DMPlex on a
> >      >     different number of cores.
> >      >     Of course, I could make a tree based on the distance of each
> element to
> >      >     a certain point (based on the X,Y,Z co-ordinates of the
> element), and go
> >      >     through this tree in the same way and define an integer based
> on this,
> >      >     but that seems rather cumbersome.
> >      > I think this is harder than it sounds. The distance will not work
> because it can be very degenerate.
> >      > You could lexicographically sort the coordinates, but this is
> hard in parallel. It is fine if you are willing
> >      > to gather everything on one process. You could put down a p4est,
> use the Morton order to number them since this is stable
> >     for a
> >      > given refinement. And then within each box lexicographically sort
> the centroids. This is definitely cumbersome, but I cannot
> >      > think of anything else. This also might have parallel problems
> since you need to know how much overlap you need to fill
> >     each box.
> >      >    Thanks,
> >      >        Matt
> >      >     Thanks and best regards, Berend.
> >      > What most experimenters take for granted before they begin their
> experiments is infinitely more interesting than any
> >     results to
> >      > which their experiments lead.
> >      > -- Norbert Wiener
> >      > https://www.cse.buffalo.edu/~knepley/ <
> https://www.cse.buffalo.edu/~knepley/> <
> http://www.cse.buffalo.edu/~knepley/
> >     <http://www.cse.buffalo.edu/~knepley/>>
> experiments is infinitely more interesting than any results to
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240122/8f7db76f/attachment.html>
