[petsc-users] How to find the map between the high order coordinates of DMPlex and vertex numbering?
Mon May 15 10:28:31 CDT 2023
On Mon, May 15, 2023 at 9:55 AM Zongze Yang <yangzongze at gmail.com> wrote:
> On Mon, 15 May 2023 at 17:24, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, May 14, 2023 at 7:23 PM Zongze Yang <yangzongze at gmail.com> wrote:
>>> Could you try to project the coordinates into the continuity space by
>>> enabling the option
>>> `-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true`?
>> There is a comment in the code about that:
>>   /* XXX FIXME Requires DMPlexSetClosurePermutationLexicographic() */
>> So what is currently done is you project into the discontinuous space
>> from the GMsh coordinates,
>> and then we get the continuous coordinates from those later. This is why
>> we get the right answer.
> Sorry, I'm having difficulty understanding the comment and fully
> understanding your intended meaning. Are you saying that we can only
> project the space to a discontinuous space?
For higher order simplices, because we do not have the mapping to the GMsh
order yet.
> Additionally, should we always set
> `dm_plex_gmsh_project_petscdualspace_lagrange_continuity` to false for
> high-order gmsh files?
This is done automatically if you do not override it.
> With the option set to `true`, I got the following error:
Yes, do not do that.
     Matt
> $ $PETSC_DIR/$PETSC_ARCH/tests/dm/impls/plex/tests/runex33_gmsh_3d_q2.sh
> -e "-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true"
> not ok dm_impls_plex_tests-ex33_gmsh_3d_q2 # Error code: 77
> #       Volume: 0.46875
> #       [0]PETSC ERROR: --------------------- Error Message
> #       [0]PETSC ERROR: Petsc has generated inconsistent data
> #       [0]PETSC ERROR: Calculated volume 0.46875 != 1. actual volume
> (error 0.53125 > 1e-06 tol)
> #       [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
> shooting.
> #       [0]PETSC ERROR: Petsc Development GIT revision:
> v3.19.1-294-g9cc24bc9b93  GIT Date: 2023-05-15 12:07:10 +0000
> #       [0]PETSC ERROR: ../ex33 on a arch-linux-c-debug named AMA-PC-RA18
> by yzz Mon May 15 21:53:43 2023
> #       [0]PETSC ERROR: Configure options
> --CFLAGS=-I/opt/intel/oneapi/mkl/latest/include
> --CXXFLAGS=-I/opt/intel/oneapi/mkl/latest/include
> --LDFLAGS="-Wl,-rpath,/opt/intel/oneapi/mkl/latest/lib/intel64
> -L/opt/intel/oneapi/mkl/latest/lib/intel64" --download-bison
> --download-chaco --download-cmake
> --download-eigen="/home/yzz/firedrake/complex-int32-mkl-X-debug/src/eigen-3.3.3.tgz
> " --download-fftw --download-hdf5 --download-hpddm --download-hwloc
> --download-libpng --download-metis --download-mmg --download-mpich
> --download-mumps --download-netcdf --download-p4est --download-parmmg
> --download-pastix --download-pnetcdf --download-ptscotch
> --download-scalapack --download-slepc --download-suitesparse
> --download-superlu_dist --download-tetgen --download-triangle
> --with-blaslapack-dir=/opt/intel/oneapi/mkl/latest --with-c2html=0
> --with-debugging=1 --with-fortran-bindings=0
> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/latest
> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/latest
> --with-scalar-type=complex --with-shared-libraries=1 --with-x=1 --with-zlib
> PETSC_ARCH=arch-linux-c-debug
> #       [0]PETSC ERROR: #1 CheckVolume() at
> /home/yzz/opt/petsc/src/dm/impls/plex/tests/ex33.c:246
> #       [0]PETSC ERROR: #2 main() at
> /home/yzz/opt/petsc/src/dm/impls/plex/tests/ex33.c:261
> #       [0]PETSC ERROR: PETSc Option Table entries:
> #       [0]PETSC ERROR: -coord_space 0 (source: command line)
> #       [0]PETSC ERROR: -dm_plex_filename
> /home/yzz/opt/petsc/share/petsc/datafiles/meshes/cube_q2.msh (source:
> command line)
> #       [0]PETSC ERROR: -dm_plex_gmsh_project (source: command line)
> #       [0]PETSC ERROR:
> -dm_plex_gmsh_project_petscdualspace_lagrange_continuity true (source:
> command line)
> #       [0]PETSC ERROR: -tol 1e-6 (source: command line)
> #       [0]PETSC ERROR: -volume 1.0 (source: command line)
> #       [0]PETSC ERROR: ----------------End of Error Message -------send
> entire error message to petsc-maint at mcs.anl.gov----------
> #       application called MPI_Abort(MPI_COMM_SELF, 77) - process 0
>  ok dm_impls_plex_tests-ex33_gmsh_3d_q2 # SKIP Command failed so no diff
> Best wishes,
> Zongze
>   Thanks,
>>      Matt
>>> Best wishes,
>>> Zongze
>>> On Mon, 15 May 2023 at 04:24, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Sun, May 14, 2023 at 12:27 PM Zongze Yang <yangzongze at gmail.com>
>>>> wrote:
>>>>> On Sun, 14 May 2023 at 23:54, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Sun, May 14, 2023 at 9:21 AM Zongze Yang <yangzongze at gmail.com>
>>>>>> wrote:
>>>>>>> Hi, Matt,
>>>>>>> The issue has been resolved while testing on the latest version of
>>>>>>> PETSc. It seems that the problem has been fixed in the following merge
>>>>>>> request:  https://gitlab.com/petsc/petsc/-/merge_requests/5970
>>>>>> No problem. Glad it is working.
>>>>>>> I sincerely apologize for any inconvenience caused by my previous
>>>>>>> message. However, I would like to provide you with additional information
>>>>>>> regarding the test files. Attached to this email, you will find two Gmsh
>>>>>>> files: "square_2rd.msh" and "square_3rd.msh." These files contain
>>>>>>> high-order triangulated mesh data for the unit square.
>>>>>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_2rd.msh
>>>>>>> -dm_plex_gmsh_project_fe_view -volume 1
>>>>>>> PetscFE Object: P2 1 MPI process
>>>>>>>   type: basic
>>>>>>>   Basic Finite Element in 2 dimensions with 2 components
>>>>>>>   PetscSpace Object: P2 1 MPI process
>>>>>>>     type: sum
>>>>>>>     Space in 2 variables with 2 components, size 12
>>>>>>>     Sum space of 2 concatenated subspaces (all identical)
>>>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI process
>>>>>>>         type: poly
>>>>>>>         Space in 2 variables with 1 components, size 6
>>>>>>>         Polynomial space of degree 2
>>>>>>>   PetscDualSpace Object: P2 1 MPI process
>>>>>>>     type: lagrange
>>>>>>>     Dual space with 2 components, size 12
>>>>>>>     Continuous Lagrange dual space
>>>>>>>     Quadrature on a triangle of order 5 on 9 points (dim 2)
>>>>>>> Volume: 1.
>>>>>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_3rd.msh
>>>>>>> PetscFE Object: P3 1 MPI process
>>>>>>>   type: basic
>>>>>>>   PetscSpace Object: P3 1 MPI process
>>>>>>>     type: sum
>>>>>>>     Space in 2 variables with 2 components, size 20
>>>>>>>         type: poly
>>>>>>>         Space in 2 variables with 1 components, size 10
>>>>>>>         Polynomial space of degree 3
>>>>>>>   PetscDualSpace Object: P3 1 MPI process
>>>>>>>     type: lagrange
>>>>>>>     Dual space with 2 components, size 20
>>>>>>>     Quadrature on a triangle of order 7 on 16 points (dim 2)
>>>>>>> Volume: 1.
>>>>>>> Thank you for your attention and understanding. I apologize once
>>>>>>> again for my previous oversight.
>>>>>> Great! If you make an MR for this, you will be included on the next
>>>>>> list of PETSc contributors. Otherwise, I can do it.
>>>>> I appreciate your offer to handle the MR. Please go ahead and take
>>>>> care of it. Thank you!
>>>> I have created the MR with your tests. They are working for me:
>>>>   https://gitlab.com/petsc/petsc/-/merge_requests/6463
>>>>   Thanks,
>>>>      Matt
>>>>> Best Wishes,
>>>>> Zongze
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Best wishes,
>>>>>>> Zongze
>>>>>>> On Sun, 14 May 2023 at 16:44, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Sat, May 13, 2023 at 6:08 AM Zongze Yang <yangzongze at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hi, Matt,
>>>>>>>>> There seem to be ongoing issues with projecting high-order
>>>>>>>>> coordinates from a gmsh file to other spaces. I would like to inquire
>>>>>>>>> whether there are any plans to resolve this problem.
>>>>>>>>> Thank you for your attention to this matter.
>>>>>>>> Yes, I will look at it. The important thing is to have a good test.
>>>>>>>> Here are the higher order geometry tests
>>>>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tests/ex33.c
>>>>>>>> I take shapes with known volume, mesh them with higher order
>>>>>>>> geometry, and look at the convergence to the true volume. Could you add a
>>>>>>>> GMsh test, meaning the .msh file and known volume, and I will fix it?
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Best wishes,
>>>>>>>>> Zongze
>>>>>>>>> On Sat, 18 Jun 2022 at 20:31, Zongze Yang <yangzongze at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Thank you for your reply. May I ask for some references on the
>>>>>>>>>> order of the dofs on PETSc's FE Space (especially high order elements)?
>>>>>>>>>> Thanks,
>>>>>>>>>>  Zongze
>>>>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月18日周六 20:02写道:
>>>>>>>>>>> On Sat, Jun 18, 2022 at 2:16 AM Zongze Yang <
>>>>>>>>>>>> In order to check if I made mistakes in the python code, I try
>>>>>>>>>>>> to use c code to show the issue on DMProjectCoordinates. The code and mesh
>>>>>>>>>>>> file is attached.
>>>>>>>>>>>> If the code is correct, there must be something wrong with
>>>>>>>>>>>> `DMProjectCoordinates` or `DMPlexCreateGmshFromFile` for high-order mesh.
>>>>>>>>>>> Something is definitely wrong with high order, periodic
>>>>>>>>>>> simplices from Gmsh. We had not tested that case. I am at a conference and
>>>>>>>>>>> cannot look at it for a week.
>>>>>>>>>>> My suspicion is that the space we make when reading in the Gmsh
>>>>>>>>>>> coordinates does not match the values (wrong order).
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>     Matt
>>>>>>>>>>>> The command and the output are listed below: (Obviously the
>>>>>>>>>>>> bounding box is changed.)
>>>>>>>>>>>> $ ./test_gmsh_load_2rd -filename cube-p2.msh -old_fe_view
>>>>>>>>>>>> -new_fe_view
>>>>>>>>>>>> Old Bounding Box:
>>>>>>>>>>>>   0: lo = 0. hi = 1.
>>>>>>>>>>>>   1: lo = 0. hi = 1.
>>>>>>>>>>>>   2: lo = 0. hi = 1.
>>>>>>>>>>>> PetscFE Object: OldCoordinatesFE 1 MPI processes
>>>>>>>>>>>>   type: basic
>>>>>>>>>>>>   Basic Finite Element in 3 dimensions with 3 components
>>>>>>>>>>>>   PetscSpace Object: P2 1 MPI processes
>>>>>>>>>>>>     type: sum
>>>>>>>>>>>>     Space in 3 variables with 3 components, size 30
>>>>>>>>>>>>     Sum space of 3 concatenated subspaces (all identical)
>>>>>>>>>>>> processes
>>>>>>>>>>>>         type: poly
>>>>>>>>>>>>         Space in 3 variables with 1 components, size 10
>>>>>>>>>>>>   PetscDualSpace Object: P2 1 MPI processes
>>>>>>>>>>>>     type: lagrange
>>>>>>>>>>>>     Dual space with 3 components, size 30
>>>>>>>>>>>>     Discontinuous Lagrange dual space
>>>>>>>>>>>>     Quadrature of order 5 on 27 points (dim 3)
>>>>>>>>>>>> PetscFE Object: NewCoordinatesFE 1 MPI processes
>>>>>>>>>>>>   type: basic
>>>>>>>>>>>>     type: sum
>>>>>>>>>>>> processes
>>>>>>>>>>>>         type: poly
>>>>>>>>>>>>     type: lagrange
>>>>>>>>>>>> New Bounding Box:
>>>>>>>>>>>>   0: lo = 2.5624e-17 hi = 8.
>>>>>>>>>>>>   1: lo = -9.23372e-17 hi = 7.
>>>>>>>>>>>>   2: lo = 2.72091e-17 hi = 8.5
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Zongze
>>>>>>>>>>>> Zongze Yang <yangzongze at gmail.com> 于2022年6月17日周五 14:54写道:
>>>>>>>>>>>>> I tried the projection operation. However, it seems that the
>>>>>>>>>>>>> projection gives the wrong solution. After projection, the bounding box is
>>>>>>>>>>>>> changed! See logs below.
>>>>>>>>>>>>> First, I patch the petsc4py by adding `DMProjectCoordinates`:
>>>>>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>>> b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>>> index d8a58d183a..dbcdb280f1 100644
>>>>>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>>> @@ -307,6 +307,12 @@ cdef class DM(Object):
>>>>>>>>>>>>>          PetscINCREF(c.obj)
>>>>>>>>>>>>>          return c
>>>>>>>>>>>>> +    def projectCoordinates(self, FE fe=None):
>>>>>>>>>>>>> +        if fe is None:
>>>>>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, NULL) )
>>>>>>>>>>>>> +        else:
>>>>>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, fe.fe) )
>>>>>>>>>>>>>      def getBoundingBox(self):
>>>>>>>>>>>>>          cdef PetscInt i,dim=0
>>>>>>>>>>>>>          CHKERR( DMGetCoordinateDim(self.dm, &dim) )
>>>>>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>>> b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>>> index 514b6fa472..c778e39884 100644
>>>>>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>>> @@ -90,6 +90,7 @@ cdef extern from * nogil:
>>>>>>>>>>>>>      int DMGetCoordinateDim(PetscDM,PetscInt*)
>>>>>>>>>>>>>      int DMSetCoordinateDim(PetscDM,PetscInt)
>>>>>>>>>>>>>      int DMLocalizeCoordinates(PetscDM)
>>>>>>>>>>>>> +    int DMProjectCoordinates(PetscDM, PetscFE)
>>>>>>>>>>>>>      int
>>>>>>>>>>>>> DMCreateInterpolation(PetscDM,PetscDM,PetscMat*,PetscVec*)
>>>>>>>>>>>>>      int DMCreateInjection(PetscDM,PetscDM,PetscMat*)
>>>>>>>>>>>>> Then in python, I load a mesh and project the coordinates to
>>>>>>>>>>>>> P2:
>>>>>>>>>>>>> import firedrake as fd
>>>>>>>>>>>>> from firedrake.petsc import PETSc
>>>>>>>>>>>>> # plex = fd.mesh._from_gmsh('test-fd-load-p2.msh')
>>>>>>>>>>>>> plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh')
>>>>>>>>>>>>> print('old bbox:', plex.getBoundingBox())
>>>>>>>>>>>>> dim = plex.getDimension()
>>>>>>>>>>>>> #                                 (dim,  nc, isSimplex, k,
>>>>>>>>>>>>>      qorder, comm=None)
>>>>>>>>>>>>> fe_new = PETSc.FE().createLagrange(dim, dim,      True, 2,
>>>>>>>>>>>>> PETSc.DETERMINE)
>>>>>>>>>>>>> plex.projectCoordinates(fe_new)
>>>>>>>>>>>>> fe_new.view()
>>>>>>>>>>>>> print('new bbox:', plex.getBoundingBox())
>>>>>>>>>>>>> The output is (The bounding box is changed!)
>>>>>>>>>>>>> old bbox: ((0.0, 1.0), (0.0, 1.0), (0.0, 1.0))
>>>>>>>>>>>>> PetscFE Object: P2 1 MPI processes
>>>>>>>>>>>>>   type: basic
>>>>>>>>>>>>>     type: sum
>>>>>>>>>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI processes
>>>>>>>>>>>>>         type: poly
>>>>>>>>>>>>>     type: lagrange
>>>>>>>>>>>>> new bbox: ((-6.530133708576188e-17, 36.30670832662781), (-3.899962995254311e-17, 36.2406171632539), (-8.8036464152166e-17, 36.111577025012224))
>>>>>>>>>>>>> By the way, for the original DG coordinates, where can I find the relation of the closure and the order of the dofs for the cell?
>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>   Zongze
>>>>>>>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月17日周五 01:11写道:
>>>>>>>>>>>>>> On Thu, Jun 16, 2022 at 12:06 PM Zongze Yang <
>>>>>>>>>>>>>>> 在 2022年6月16日,23:22,Matthew Knepley <knepley at gmail.com> 写道:
>>>>>>>>>>>>>>> On Thu, Jun 16, 2022 at 11:11 AM Zongze Yang <
>>>>>>>>>>>>>>>> Hi, if I load a `gmsh` file with second-order elements, the
>>>>>>>>>>>>>>>> coordinates will be stored in a DG-P2 space. After obtaining the
>>>>>>>>>>>>>>>> coordinates of a cell, how can I map the coordinates to vertex and edge?
>>>>>>>>>>>>>>> By default, they are stored as P2, not DG.
>>>>>>>>>>>>>>> I checked the coordinates vector, and found the dogs only
>>>>>>>>>>>>>>> defined on cell other than vertex and edge, so I said they are stored as DG.
>>>>>>>>>>>>>>> Then the function DMPlexVecGetClosure
>>>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/> seems return
>>>>>>>>>>>>>>> the coordinates in lex order.
>>>>>>>>>>>>>>> Some code in reading gmsh file reads that
>>>>>>>>>>>>>>> 1756:     if (isSimplex) continuity = PETSC_FALSE
>>>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Sys/PETSC_FALSE/>;
>>>>>>>>>>>>>>> 1758:     GmshCreateFE(comm, NULL, isSimplex, continuity,
>>>>>>>>>>>>>>> nodeType, dim, coordDim, order, &fe)
>>>>>>>>>>>>>>> The continuity is set to false for simplex.
>>>>>>>>>>>>>> Oh, yes. That needs to be fixed. For now, you can just
>>>>>>>>>>>>>> project it to P2 if you want using
>>>>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMProjectCoordinates/
>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Zongze
>>>>>>>>>>>>>>> You can ask for the coordinates of a vertex or an edge
>>>>>>>>>>>>>>> directly using
>>>>>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexPointLocalRead/
>>>>>>>>>>>>>>> by giving the vertex or edge point. You can get all the
>>>>>>>>>>>>>>> coordinates on a cell, in the closure order, using
>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>> Below is some code load the gmsh file, I want to know the
>>>>>>>>>>>>>>>> relation between `cl` and `cell_coords`.
>>>>>>>>>>>>>>>> import numpy as np
>>>>>>>>>>>>>>>> # Load gmsh file (2rd)
>>>>>>>>>>>>>>>> cs, ce = plex.getHeightStratum(0)
>>>>>>>>>>>>>>>> cdm = plex.getCoordinateDM()
>>>>>>>>>>>>>>>> csec = dm.getCoordinateSection()
>>>>>>>>>>>>>>>> coords_gvec = dm.getCoordinates()
>>>>>>>>>>>>>>>> for i in range(cs, ce):
>>>>>>>>>>>>>>>>     cell_coords = cdm.getVecClosure(csec, coords_gvec, i)
>>>>>>>>>>>>>>>>     print(f'coordinates for cell {i}
>>>>>>>>>>>>>>>> :\n{cell_coords.reshape([-1, 3])}')
>>>>>>>>>>>>>>>>     cl = dm.getTransitiveClosure(i)
>>>>>>>>>>>>>>>>     print('closure:', cl)
>>>>>>>>>>>>>>>>     break
>>>>>>>>>>>>>>>> Best wishes,
>>>>>>>>>>>>>>>> Zongze
>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230515/4df9824d/attachment-0001.html>
