[petsc-users] How to find the map between the high order coordinates of DMPlex and vertex numbering?
Zongze Yang yangzongze at gmail.com
Mon May 15 22:29:46 CDT 2023
Got it. Thank you for your explanation!
Best wishes,
Zongze
On Mon, 15 May 2023 at 23:28, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, May 15, 2023 at 9:55 AM Zongze Yang <yangzongze at gmail.com> wrote:
>> On Mon, 15 May 2023 at 17:24, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Sun, May 14, 2023 at 7:23 PM Zongze Yang <yangzongze at gmail.com>
>>> wrote:
>>>> Could you try to project the coordinates into the continuity space by
>>>> enabling the option
>>>> `-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true`?
>>> There is a comment in the code about that:
>>>   /* XXX FIXME Requires DMPlexSetClosurePermutationLexicographic() */
>>> So what is currently done is you project into the discontinuous space
>>> from the GMsh coordinates,
>>> and then we get the continuous coordinates from those later. This is why
>>> we get the right answer.
>> Sorry, I'm having difficulty understanding the comment and fully
>> understanding your intended meaning. Are you saying that we can only
>> project the space to a discontinuous space?
> For higher order simplices, because we do not have the mapping to the GMsh
> order yet.
>> Additionally, should we always set
>> `dm_plex_gmsh_project_petscdualspace_lagrange_continuity` to false for
>> high-order gmsh files?
> This is done automatically if you do not override it.
>> With the option set to `true`, I got the following error:
> Yes, do not do that.
>   Thanks,
>      Matt
>> $ $PETSC_DIR/$PETSC_ARCH/tests/dm/impls/plex/tests/runex33_gmsh_3d_q2.sh
>> -e "-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true"
>> not ok dm_impls_plex_tests-ex33_gmsh_3d_q2 # Error code: 77
>> #       Volume: 0.46875
>> #       [0]PETSC ERROR: --------------------- Error Message
>> #       [0]PETSC ERROR: Petsc has generated inconsistent data
>> #       [0]PETSC ERROR: Calculated volume 0.46875 != 1. actual volume
>> (error 0.53125 > 1e-06 tol)
>> #       [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>> shooting.
>> #       [0]PETSC ERROR: Petsc Development GIT revision:
>> v3.19.1-294-g9cc24bc9b93  GIT Date: 2023-05-15 12:07:10 +0000
>> #       [0]PETSC ERROR: ../ex33 on a arch-linux-c-debug named AMA-PC-RA18
>> by yzz Mon May 15 21:53:43 2023
>> #       [0]PETSC ERROR: Configure options
>> --CFLAGS=-I/opt/intel/oneapi/mkl/latest/include
>> --CXXFLAGS=-I/opt/intel/oneapi/mkl/latest/include
>> --LDFLAGS="-Wl,-rpath,/opt/intel/oneapi/mkl/latest/lib/intel64
>> -L/opt/intel/oneapi/mkl/latest/lib/intel64" --download-bison
>> --download-chaco --download-cmake
>> --download-eigen="/home/yzz/firedrake/complex-int32-mkl-X-debug/src/eigen-3.3.3.tgz
>> " --download-fftw --download-hdf5 --download-hpddm --download-hwloc
>> --download-libpng --download-metis --download-mmg --download-mpich
>> --download-mumps --download-netcdf --download-p4est --download-parmmg
>> --download-pastix --download-pnetcdf --download-ptscotch
>> --download-scalapack --download-slepc --download-suitesparse
>> --download-superlu_dist --download-tetgen --download-triangle
>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/latest --with-c2html=0
>> --with-debugging=1 --with-fortran-bindings=0
>> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/latest
>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/latest
>> --with-scalar-type=complex --with-shared-libraries=1 --with-x=1 --with-zlib
>> PETSC_ARCH=arch-linux-c-debug
>> #       [0]PETSC ERROR: #1 CheckVolume() at
>> /home/yzz/opt/petsc/src/dm/impls/plex/tests/ex33.c:246
>> #       [0]PETSC ERROR: #2 main() at
>> /home/yzz/opt/petsc/src/dm/impls/plex/tests/ex33.c:261
>> #       [0]PETSC ERROR: PETSc Option Table entries:
>> #       [0]PETSC ERROR: -coord_space 0 (source: command line)
>> #       [0]PETSC ERROR: -dm_plex_filename
>> /home/yzz/opt/petsc/share/petsc/datafiles/meshes/cube_q2.msh (source:
>> command line)
>> #       [0]PETSC ERROR: -dm_plex_gmsh_project (source: command line)
>> #       [0]PETSC ERROR:
>> -dm_plex_gmsh_project_petscdualspace_lagrange_continuity true (source:
>> command line)
>> #       [0]PETSC ERROR: -tol 1e-6 (source: command line)
>> #       [0]PETSC ERROR: -volume 1.0 (source: command line)
>> #       [0]PETSC ERROR: ----------------End of Error Message -------send
>> entire error message to petsc-maint at mcs.anl.gov----------
>> #       application called MPI_Abort(MPI_COMM_SELF, 77) - process 0
>>  ok dm_impls_plex_tests-ex33_gmsh_3d_q2 # SKIP Command failed so no diff
>> Best wishes,
>> Zongze
>>   Thanks,
>>>      Matt
>>>> Best wishes,
>>>> Zongze
>>>> On Mon, 15 May 2023 at 04:24, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sun, May 14, 2023 at 12:27 PM Zongze Yang <yangzongze at gmail.com>
>>>>> wrote:
>>>>>> On Sun, 14 May 2023 at 23:54, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Sun, May 14, 2023 at 9:21 AM Zongze Yang <yangzongze at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi, Matt,
>>>>>>>> The issue has been resolved while testing on the latest version of
>>>>>>>> PETSc. It seems that the problem has been fixed in the following merge
>>>>>>>> request:  https://gitlab.com/petsc/petsc/-/merge_requests/5970
>>>>>>> No problem. Glad it is working.
>>>>>>>> I sincerely apologize for any inconvenience caused by my previous
>>>>>>>> message. However, I would like to provide you with additional information
>>>>>>>> regarding the test files. Attached to this email, you will find two Gmsh
>>>>>>>> files: "square_2rd.msh" and "square_3rd.msh." These files contain
>>>>>>>> high-order triangulated mesh data for the unit square.
>>>>>>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_2rd.msh
>>>>>>>> -dm_plex_gmsh_project_fe_view -volume 1
>>>>>>>> PetscFE Object: P2 1 MPI process
>>>>>>>>   type: basic
>>>>>>>>   Basic Finite Element in 2 dimensions with 2 components
>>>>>>>>   PetscSpace Object: P2 1 MPI process
>>>>>>>>     type: sum
>>>>>>>>     Space in 2 variables with 2 components, size 12
>>>>>>>>     Sum space of 2 concatenated subspaces (all identical)
>>>>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI process
>>>>>>>>         type: poly
>>>>>>>>         Space in 2 variables with 1 components, size 6
>>>>>>>>         Polynomial space of degree 2
>>>>>>>>   PetscDualSpace Object: P2 1 MPI process
>>>>>>>>     type: lagrange
>>>>>>>>     Dual space with 2 components, size 12
>>>>>>>>     Continuous Lagrange dual space
>>>>>>>>     Quadrature on a triangle of order 5 on 9 points (dim 2)
>>>>>>>> Volume: 1.
>>>>>>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_3rd.msh
>>>>>>>> PetscFE Object: P3 1 MPI process
>>>>>>>>   type: basic
>>>>>>>>   PetscSpace Object: P3 1 MPI process
>>>>>>>>     type: sum
>>>>>>>>     Space in 2 variables with 2 components, size 20
>>>>>>>>         type: poly
>>>>>>>>         Space in 2 variables with 1 components, size 10
>>>>>>>>         Polynomial space of degree 3
>>>>>>>>   PetscDualSpace Object: P3 1 MPI process
>>>>>>>>     type: lagrange
>>>>>>>>     Dual space with 2 components, size 20
>>>>>>>>     Quadrature on a triangle of order 7 on 16 points (dim 2)
>>>>>>>> Volume: 1.
>>>>>>>> Thank you for your attention and understanding. I apologize once
>>>>>>>> again for my previous oversight.
>>>>>>> Great! If you make an MR for this, you will be included on the next
>>>>>>> list of PETSc contributors. Otherwise, I can do it.
>>>>>> I appreciate your offer to handle the MR. Please go ahead and take
>>>>>> care of it. Thank you!
>>>>> I have created the MR with your tests. They are working for me:
>>>>>   https://gitlab.com/petsc/petsc/-/merge_requests/6463
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Best Wishes,
>>>>>> Zongze
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Best wishes,
>>>>>>>> Zongze
>>>>>>>> On Sun, 14 May 2023 at 16:44, Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Sat, May 13, 2023 at 6:08 AM Zongze Yang <yangzongze at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Hi, Matt,
>>>>>>>>>> There seem to be ongoing issues with projecting high-order
>>>>>>>>>> coordinates from a gmsh file to other spaces. I would like to inquire
>>>>>>>>>> whether there are any plans to resolve this problem.
>>>>>>>>>> Thank you for your attention to this matter.
>>>>>>>>> Yes, I will look at it. The important thing is to have a good
>>>>>>>>> test. Here are the higher order geometry tests
>>>>>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tests/ex33.c
>>>>>>>>> I take shapes with known volume, mesh them with higher order
>>>>>>>>> geometry, and look at the convergence to the true volume. Could you add a
>>>>>>>>> GMsh test, meaning the .msh file and known volume, and I will fix it?
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> Best wishes,
>>>>>>>>>> Zongze
>>>>>>>>>> On Sat, 18 Jun 2022 at 20:31, Zongze Yang <yangzongze at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Thank you for your reply. May I ask for some references on the
>>>>>>>>>>> order of the dofs on PETSc's FE Space (especially high order elements)?
>>>>>>>>>>> Thanks,
>>>>>>>>>>>  Zongze
>>>>>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月18日周六 20:02写道:
>>>>>>>>>>>> On Sat, Jun 18, 2022 at 2:16 AM Zongze Yang <
>>>>>>>>>>>>> In order to check if I made mistakes in the python code, I try
>>>>>>>>>>>>> to use c code to show the issue on DMProjectCoordinates. The code and mesh
>>>>>>>>>>>>> file is attached.
>>>>>>>>>>>>> If the code is correct, there must be something wrong with
>>>>>>>>>>>>> `DMProjectCoordinates` or `DMPlexCreateGmshFromFile` for high-order mesh.
>>>>>>>>>>>> Something is definitely wrong with high order, periodic
>>>>>>>>>>>> simplices from Gmsh. We had not tested that case. I am at a conference and
>>>>>>>>>>>> cannot look at it for a week.
>>>>>>>>>>>> My suspicion is that the space we make when reading in the Gmsh
>>>>>>>>>>>> coordinates does not match the values (wrong order).
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>     Matt
>>>>>>>>>>>>> The command and the output are listed below: (Obviously the
>>>>>>>>>>>>> bounding box is changed.)
>>>>>>>>>>>>> $ ./test_gmsh_load_2rd -filename cube-p2.msh -old_fe_view
>>>>>>>>>>>>> -new_fe_view
>>>>>>>>>>>>> Old Bounding Box:
>>>>>>>>>>>>>   0: lo = 0. hi = 1.
>>>>>>>>>>>>>   1: lo = 0. hi = 1.
>>>>>>>>>>>>>   2: lo = 0. hi = 1.
>>>>>>>>>>>>> PetscFE Object: OldCoordinatesFE 1 MPI processes
>>>>>>>>>>>>>   type: basic
>>>>>>>>>>>>>   Basic Finite Element in 3 dimensions with 3 components
>>>>>>>>>>>>>   PetscSpace Object: P2 1 MPI processes
>>>>>>>>>>>>>     type: sum
>>>>>>>>>>>>>     Space in 3 variables with 3 components, size 30
>>>>>>>>>>>>>     Sum space of 3 concatenated subspaces (all identical)
>>>>>>>>>>>>> processes
>>>>>>>>>>>>>         type: poly
>>>>>>>>>>>>>         Space in 3 variables with 1 components, size 10
>>>>>>>>>>>>>   PetscDualSpace Object: P2 1 MPI processes
>>>>>>>>>>>>>     type: lagrange
>>>>>>>>>>>>>     Dual space with 3 components, size 30
>>>>>>>>>>>>>     Discontinuous Lagrange dual space
>>>>>>>>>>>>>     Quadrature of order 5 on 27 points (dim 3)
>>>>>>>>>>>>> PetscFE Object: NewCoordinatesFE 1 MPI processes
>>>>>>>>>>>>>   type: basic
>>>>>>>>>>>>>     type: sum
>>>>>>>>>>>>> processes
>>>>>>>>>>>>>         type: poly
>>>>>>>>>>>>>     type: lagrange
>>>>>>>>>>>>> New Bounding Box:
>>>>>>>>>>>>>   0: lo = 2.5624e-17 hi = 8.
>>>>>>>>>>>>>   1: lo = -9.23372e-17 hi = 7.
>>>>>>>>>>>>>   2: lo = 2.72091e-17 hi = 8.5
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Zongze
>>>>>>>>>>>>> Zongze Yang <yangzongze at gmail.com> 于2022年6月17日周五 14:54写道:
>>>>>>>>>>>>>> I tried the projection operation. However, it seems that the
>>>>>>>>>>>>>> projection gives the wrong solution. After projection, the bounding box is
>>>>>>>>>>>>>> changed! See logs below.
>>>>>>>>>>>>>> First, I patch the petsc4py by adding `DMProjectCoordinates`:
>>>>>>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>>>> b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>>>> index d8a58d183a..dbcdb280f1 100644
>>>>>>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>>>> @@ -307,6 +307,12 @@ cdef class DM(Object):
>>>>>>>>>>>>>>          PetscINCREF(c.obj)
>>>>>>>>>>>>>>          return c
>>>>>>>>>>>>>> +    def projectCoordinates(self, FE fe=None):
>>>>>>>>>>>>>> +        if fe is None:
>>>>>>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, NULL) )
>>>>>>>>>>>>>> +        else:
>>>>>>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, fe.fe) )
>>>>>>>>>>>>>>      def getBoundingBox(self):
>>>>>>>>>>>>>>          cdef PetscInt i,dim=0
>>>>>>>>>>>>>>          CHKERR( DMGetCoordinateDim(self.dm, &dim) )
>>>>>>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>>>> b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>>>> index 514b6fa472..c778e39884 100644
>>>>>>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>>>> @@ -90,6 +90,7 @@ cdef extern from * nogil:
>>>>>>>>>>>>>>      int DMGetCoordinateDim(PetscDM,PetscInt*)
>>>>>>>>>>>>>>      int DMSetCoordinateDim(PetscDM,PetscInt)
>>>>>>>>>>>>>>      int DMLocalizeCoordinates(PetscDM)
>>>>>>>>>>>>>> +    int DMProjectCoordinates(PetscDM, PetscFE)
>>>>>>>>>>>>>>      int
>>>>>>>>>>>>>> DMCreateInterpolation(PetscDM,PetscDM,PetscMat*,PetscVec*)
>>>>>>>>>>>>>>      int DMCreateInjection(PetscDM,PetscDM,PetscMat*)
>>>>>>>>>>>>>> Then in python, I load a mesh and project the coordinates to
>>>>>>>>>>>>>> P2:
>>>>>>>>>>>>>> import firedrake as fd
>>>>>>>>>>>>>> from firedrake.petsc import PETSc
>>>>>>>>>>>>>> # plex = fd.mesh._from_gmsh('test-fd-load-p2.msh')
>>>>>>>>>>>>>> plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh')
>>>>>>>>>>>>>> print('old bbox:', plex.getBoundingBox())
>>>>>>>>>>>>>> dim = plex.getDimension()
>>>>>>>>>>>>>> #                                 (dim,  nc, isSimplex, k,
>>>>>>>>>>>>>>        qorder, comm=None)
>>>>>>>>>>>>>> fe_new = PETSc.FE().createLagrange(dim, dim,      True, 2,
>>>>>>>>>>>>>> PETSc.DETERMINE)
>>>>>>>>>>>>>> plex.projectCoordinates(fe_new)
>>>>>>>>>>>>>> fe_new.view()
>>>>>>>>>>>>>> print('new bbox:', plex.getBoundingBox())
>>>>>>>>>>>>>> The output is (The bounding box is changed!)
>>>>>>>>>>>>>> old bbox: ((0.0, 1.0), (0.0, 1.0), (0.0, 1.0))
>>>>>>>>>>>>>> PetscFE Object: P2 1 MPI processes
>>>>>>>>>>>>>>   type: basic
>>>>>>>>>>>>>>     type: sum
>>>>>>>>>>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI processes
>>>>>>>>>>>>>>         type: poly
>>>>>>>>>>>>>>     type: lagrange
>>>>>>>>>>>>>> new bbox: ((-6.530133708576188e-17, 36.30670832662781), (-3.899962995254311e-17, 36.2406171632539), (-8.8036464152166e-17, 36.111577025012224))
>>>>>>>>>>>>>> By the way, for the original DG coordinates, where can I find the relation of the closure and the order of the dofs for the cell?
>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>>   Zongze
>>>>>>>>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月17日周五 01:11写道:
>>>>>>>>>>>>>>> On Thu, Jun 16, 2022 at 12:06 PM Zongze Yang <
>>>>>>>>>>>>>>>> 在 2022年6月16日,23:22,Matthew Knepley <knepley at gmail.com> 写道:
>>>>>>>>>>>>>>>> On Thu, Jun 16, 2022 at 11:11 AM Zongze Yang <
>>>>>>>>>>>>>>>>> Hi, if I load a `gmsh` file with second-order elements,
>>>>>>>>>>>>>>>>> the coordinates will be stored in a DG-P2 space. After obtaining the
>>>>>>>>>>>>>>>>> coordinates of a cell, how can I map the coordinates to vertex and edge?
>>>>>>>>>>>>>>>> By default, they are stored as P2, not DG.
>>>>>>>>>>>>>>>> I checked the coordinates vector, and found the dogs only
>>>>>>>>>>>>>>>> defined on cell other than vertex and edge, so I said they are stored as DG.
>>>>>>>>>>>>>>>> Then the function DMPlexVecGetClosure
>>>>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/> seems return
>>>>>>>>>>>>>>>> the coordinates in lex order.
>>>>>>>>>>>>>>>> Some code in reading gmsh file reads that
>>>>>>>>>>>>>>>> 1756:     if (isSimplex) continuity = PETSC_FALSE
>>>>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Sys/PETSC_FALSE/>;
>>>>>>>>>>>>>>>> 1758:     GmshCreateFE(comm, NULL, isSimplex, continuity,
>>>>>>>>>>>>>>>> nodeType, dim, coordDim, order, &fe)
>>>>>>>>>>>>>>>> The continuity is set to false for simplex.
>>>>>>>>>>>>>>> Oh, yes. That needs to be fixed. For now, you can just
>>>>>>>>>>>>>>> project it to P2 if you want using
>>>>>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMProjectCoordinates/
>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Zongze
>>>>>>>>>>>>>>>> You can ask for the coordinates of a vertex or an edge
>>>>>>>>>>>>>>>> directly using
>>>>>>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexPointLocalRead/
>>>>>>>>>>>>>>>> by giving the vertex or edge point. You can get all the
>>>>>>>>>>>>>>>> coordinates on a cell, in the closure order, using
>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>> Below is some code load the gmsh file, I want to know the
>>>>>>>>>>>>>>>>> relation between `cl` and `cell_coords`.
>>>>>>>>>>>>>>>>> import numpy as np
>>>>>>>>>>>>>>>>> # Load gmsh file (2rd)
>>>>>>>>>>>>>>>>> cs, ce = plex.getHeightStratum(0)
>>>>>>>>>>>>>>>>> cdm = plex.getCoordinateDM()
>>>>>>>>>>>>>>>>> csec = dm.getCoordinateSection()
>>>>>>>>>>>>>>>>> coords_gvec = dm.getCoordinates()
>>>>>>>>>>>>>>>>> for i in range(cs, ce):
>>>>>>>>>>>>>>>>>     cell_coords = cdm.getVecClosure(csec, coords_gvec, i)
>>>>>>>>>>>>>>>>>     print(f'coordinates for cell {i}
>>>>>>>>>>>>>>>>> :\n{cell_coords.reshape([-1, 3])}')
>>>>>>>>>>>>>>>>>     cl = dm.getTransitiveClosure(i)
>>>>>>>>>>>>>>>>>     print('closure:', cl)
>>>>>>>>>>>>>>>>>     break
>>>>>>>>>>>>>>>>> Best wishes,
>>>>>>>>>>>>>>>>> Zongze
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230516/b09a6a1b/attachment-0001.html>
