[petsc-users] How to find the map between the high order coordinates of DMPlex and vertex numbering?
    Zongze Yang
    yangzongze at gmail.com
    Mon May 15 08:54:55 CDT 2023
On Mon, 15 May 2023 at 17:24, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 14, 2023 at 7:23 PM Zongze Yang <yangzongze at gmail.com> wrote:
>> Could you try to project the coordinates into the continuity space by
>> enabling the option
>> `-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true`?
> There is a comment in the code about that:
>   /* XXX FIXME Requires DMPlexSetClosurePermutationLexicographic() */
> So what is currently done is you project into the discontinuous space from
> the GMsh coordinates,
> and then we get the continuous coordinates from those later. This is why
> we get the right answer.
Sorry, I'm having difficulty understanding the comment and fully
understanding your intended meaning. Are you saying that we can only
project the space to a discontinuous space?
Additionally, should we always set
`dm_plex_gmsh_project_petscdualspace_lagrange_continuity` to false for
high-order gmsh files?
With the option set to `true`, I got the following error:
$ $PETSC_DIR/$PETSC_ARCH/tests/dm/impls/plex/tests/runex33_gmsh_3d_q2.sh -e
"-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true"
not ok dm_impls_plex_tests-ex33_gmsh_3d_q2 # Error code: 77
#       Volume: 0.46875
#       [0]PETSC ERROR: --------------------- Error Message
#       [0]PETSC ERROR: Petsc has generated inconsistent data
#       [0]PETSC ERROR: Calculated volume 0.46875 != 1. actual volume
(error 0.53125 > 1e-06 tol)
#       [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
shooting.
#       [0]PETSC ERROR: Petsc Development GIT revision:
v3.19.1-294-g9cc24bc9b93  GIT Date: 2023-05-15 12:07:10 +0000
#       [0]PETSC ERROR: ../ex33 on a arch-linux-c-debug named AMA-PC-RA18
by yzz Mon May 15 21:53:43 2023
#       [0]PETSC ERROR: Configure options
--CFLAGS=-I/opt/intel/oneapi/mkl/latest/include
--CXXFLAGS=-I/opt/intel/oneapi/mkl/latest/include
--LDFLAGS="-Wl,-rpath,/opt/intel/oneapi/mkl/latest/lib/intel64
-L/opt/intel/oneapi/mkl/latest/lib/intel64" --download-bison
--download-chaco --download-cmake
--download-eigen="/home/yzz/firedrake/complex-int32-mkl-X-debug/src/eigen-3.3.3.tgz
" --download-fftw --download-hdf5 --download-hpddm --download-hwloc
--download-libpng --download-metis --download-mmg --download-mpich
--download-mumps --download-netcdf --download-p4est --download-parmmg
--download-pastix --download-pnetcdf --download-ptscotch
--download-scalapack --download-slepc --download-suitesparse
--download-superlu_dist --download-tetgen --download-triangle
--with-blaslapack-dir=/opt/intel/oneapi/mkl/latest --with-c2html=0
--with-debugging=1 --with-fortran-bindings=0
--with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/latest
--with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/latest
--with-scalar-type=complex --with-shared-libraries=1 --with-x=1 --with-zlib
PETSC_ARCH=arch-linux-c-debug
#       [0]PETSC ERROR: #1 CheckVolume() at
/home/yzz/opt/petsc/src/dm/impls/plex/tests/ex33.c:246
#       [0]PETSC ERROR: #2 main() at
/home/yzz/opt/petsc/src/dm/impls/plex/tests/ex33.c:261
#       [0]PETSC ERROR: PETSc Option Table entries:
#       [0]PETSC ERROR: -coord_space 0 (source: command line)
#       [0]PETSC ERROR: -dm_plex_filename
/home/yzz/opt/petsc/share/petsc/datafiles/meshes/cube_q2.msh (source:
command line)
#       [0]PETSC ERROR: -dm_plex_gmsh_project (source: command line)
#       [0]PETSC ERROR:
-dm_plex_gmsh_project_petscdualspace_lagrange_continuity true (source:
command line)
#       [0]PETSC ERROR: -tol 1e-6 (source: command line)
#       [0]PETSC ERROR: -volume 1.0 (source: command line)
#       [0]PETSC ERROR: ----------------End of Error Message -------send
entire error message to petsc-maint at mcs.anl.gov----------
#       application called MPI_Abort(MPI_COMM_SELF, 77) - process 0
 ok dm_impls_plex_tests-ex33_gmsh_3d_q2 # SKIP Command failed so no diff
Best wishes,
Zongze
>      Matt
>> Best wishes,
>> Zongze
>> On Mon, 15 May 2023 at 04:24, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Sun, May 14, 2023 at 12:27 PM Zongze Yang <yangzongze at gmail.com>
>>> wrote:
>>>> On Sun, 14 May 2023 at 23:54, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Sun, May 14, 2023 at 9:21 AM Zongze Yang <yangzongze at gmail.com>
>>>>> wrote:
>>>>>> Hi, Matt,
>>>>>> The issue has been resolved while testing on the latest version of
>>>>>> PETSc. It seems that the problem has been fixed in the following merge
>>>>>> request:  https://gitlab.com/petsc/petsc/-/merge_requests/5970
>>>>> No problem. Glad it is working.
>>>>>> I sincerely apologize for any inconvenience caused by my previous
>>>>>> message. However, I would like to provide you with additional information
>>>>>> regarding the test files. Attached to this email, you will find two Gmsh
>>>>>> files: "square_2rd.msh" and "square_3rd.msh." These files contain
>>>>>> high-order triangulated mesh data for the unit square.
>>>>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_2rd.msh
>>>>>> -dm_plex_gmsh_project_fe_view -volume 1
>>>>>> PetscFE Object: P2 1 MPI process
>>>>>>   type: basic
>>>>>>   Basic Finite Element in 2 dimensions with 2 components
>>>>>>   PetscSpace Object: P2 1 MPI process
>>>>>>     type: sum
>>>>>>     Space in 2 variables with 2 components, size 12
>>>>>>     Sum space of 2 concatenated subspaces (all identical)
>>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI process
>>>>>>         type: poly
>>>>>>         Space in 2 variables with 1 components, size 6
>>>>>>         Polynomial space of degree 2
>>>>>>   PetscDualSpace Object: P2 1 MPI process
>>>>>>     type: lagrange
>>>>>>     Dual space with 2 components, size 12
>>>>>>     Continuous Lagrange dual space
>>>>>>     Quadrature on a triangle of order 5 on 9 points (dim 2)
>>>>>> Volume: 1.
>>>>>> $ ./ex33 -coord_space 0 -dm_plex_filename square_3rd.msh
>>>>>> PetscFE Object: P3 1 MPI process
>>>>>>   type: basic
>>>>>>   PetscSpace Object: P3 1 MPI process
>>>>>>     type: sum
>>>>>>     Space in 2 variables with 2 components, size 20
>>>>>>         type: poly
>>>>>>         Space in 2 variables with 1 components, size 10
>>>>>>         Polynomial space of degree 3
>>>>>>   PetscDualSpace Object: P3 1 MPI process
>>>>>>     type: lagrange
>>>>>>     Dual space with 2 components, size 20
>>>>>>     Quadrature on a triangle of order 7 on 16 points (dim 2)
>>>>>> Volume: 1.
>>>>>> Thank you for your attention and understanding. I apologize once
>>>>>> again for my previous oversight.
>>>>> Great! If you make an MR for this, you will be included on the next
>>>>> list of PETSc contributors. Otherwise, I can do it.
>>>> I appreciate your offer to handle the MR. Please go ahead and take care
>>>> of it. Thank you!
>>> I have created the MR with your tests. They are working for me:
>>>   https://gitlab.com/petsc/petsc/-/merge_requests/6463
>>>   Thanks,
>>>      Matt
>>>> Best Wishes,
>>>> Zongze
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Best wishes,
>>>>>> Zongze
>>>>>> On Sun, 14 May 2023 at 16:44, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Sat, May 13, 2023 at 6:08 AM Zongze Yang <yangzongze at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi, Matt,
>>>>>>>> There seem to be ongoing issues with projecting high-order
>>>>>>>> coordinates from a gmsh file to other spaces. I would like to inquire
>>>>>>>> whether there are any plans to resolve this problem.
>>>>>>>> Thank you for your attention to this matter.
>>>>>>> Yes, I will look at it. The important thing is to have a good test.
>>>>>>> Here are the higher order geometry tests
>>>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/tests/ex33.c
>>>>>>> I take shapes with known volume, mesh them with higher order
>>>>>>> geometry, and look at the convergence to the true volume. Could you add a
>>>>>>> GMsh test, meaning the .msh file and known volume, and I will fix it?
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Best wishes,
>>>>>>>> Zongze
>>>>>>>> On Sat, 18 Jun 2022 at 20:31, Zongze Yang <yangzongze at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Thank you for your reply. May I ask for some references on the
>>>>>>>>> order of the dofs on PETSc's FE Space (especially high order elements)?
>>>>>>>>> Thanks,
>>>>>>>>>  Zongze
>>>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月18日周六 20:02写道:
>>>>>>>>>> On Sat, Jun 18, 2022 at 2:16 AM Zongze Yang <yangzongze at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> In order to check if I made mistakes in the python code, I try
>>>>>>>>>>> to use c code to show the issue on DMProjectCoordinates. The code and mesh
>>>>>>>>>>> file is attached.
>>>>>>>>>>> If the code is correct, there must be something wrong with
>>>>>>>>>>> `DMProjectCoordinates` or `DMPlexCreateGmshFromFile` for high-order mesh.
>>>>>>>>>> Something is definitely wrong with high order, periodic simplices
>>>>>>>>>> from Gmsh. We had not tested that case. I am at a conference and cannot
>>>>>>>>>> look at it for a week.
>>>>>>>>>> My suspicion is that the space we make when reading in the Gmsh
>>>>>>>>>> coordinates does not match the values (wrong order).
>>>>>>>>>>   Thanks,
>>>>>>>>>>     Matt
>>>>>>>>>>> The command and the output are listed below: (Obviously the
>>>>>>>>>>> bounding box is changed.)
>>>>>>>>>>> $ ./test_gmsh_load_2rd -filename cube-p2.msh -old_fe_view
>>>>>>>>>>> -new_fe_view
>>>>>>>>>>> Old Bounding Box:
>>>>>>>>>>>   0: lo = 0. hi = 1.
>>>>>>>>>>>   1: lo = 0. hi = 1.
>>>>>>>>>>>   2: lo = 0. hi = 1.
>>>>>>>>>>> PetscFE Object: OldCoordinatesFE 1 MPI processes
>>>>>>>>>>>   type: basic
>>>>>>>>>>>   Basic Finite Element in 3 dimensions with 3 components
>>>>>>>>>>>   PetscSpace Object: P2 1 MPI processes
>>>>>>>>>>>     type: sum
>>>>>>>>>>>     Space in 3 variables with 3 components, size 30
>>>>>>>>>>>     Sum space of 3 concatenated subspaces (all identical)
>>>>>>>>>>>       PetscSpace Object: sum component (sumcomp_) 1 MPI processes
>>>>>>>>>>>         type: poly
>>>>>>>>>>>         Space in 3 variables with 1 components, size 10
>>>>>>>>>>>   PetscDualSpace Object: P2 1 MPI processes
>>>>>>>>>>>     type: lagrange
>>>>>>>>>>>     Dual space with 3 components, size 30
>>>>>>>>>>>     Discontinuous Lagrange dual space
>>>>>>>>>>>     Quadrature of order 5 on 27 points (dim 3)
>>>>>>>>>>> PetscFE Object: NewCoordinatesFE 1 MPI processes
>>>>>>>>>>>   type: basic
>>>>>>>>>>>     type: sum
>>>>>>>>>>>         type: poly
>>>>>>>>>>>     type: lagrange
>>>>>>>>>>> New Bounding Box:
>>>>>>>>>>>   0: lo = 2.5624e-17 hi = 8.
>>>>>>>>>>>   1: lo = -9.23372e-17 hi = 7.
>>>>>>>>>>>   2: lo = 2.72091e-17 hi = 8.5
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Zongze
>>>>>>>>>>> Zongze Yang <yangzongze at gmail.com> 于2022年6月17日周五 14:54写道:
>>>>>>>>>>>> I tried the projection operation. However, it seems that the
>>>>>>>>>>>> projection gives the wrong solution. After projection, the bounding box is
>>>>>>>>>>>> changed! See logs below.
>>>>>>>>>>>> First, I patch the petsc4py by adding `DMProjectCoordinates`:
>>>>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>> b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>> index d8a58d183a..dbcdb280f1 100644
>>>>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/DM.pyx
>>>>>>>>>>>> @@ -307,6 +307,12 @@ cdef class DM(Object):
>>>>>>>>>>>>          PetscINCREF(c.obj)
>>>>>>>>>>>>          return c
>>>>>>>>>>>> +    def projectCoordinates(self, FE fe=None):
>>>>>>>>>>>> +        if fe is None:
>>>>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, NULL) )
>>>>>>>>>>>> +        else:
>>>>>>>>>>>> +            CHKERR( DMProjectCoordinates(self.dm, fe.fe) )
>>>>>>>>>>>>      def getBoundingBox(self):
>>>>>>>>>>>>          cdef PetscInt i,dim=0
>>>>>>>>>>>>          CHKERR( DMGetCoordinateDim(self.dm, &dim) )
>>>>>>>>>>>> diff --git a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>> b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>> index 514b6fa472..c778e39884 100644
>>>>>>>>>>>> --- a/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>> +++ b/src/binding/petsc4py/src/PETSc/petscdm.pxi
>>>>>>>>>>>> @@ -90,6 +90,7 @@ cdef extern from * nogil:
>>>>>>>>>>>>      int DMGetCoordinateDim(PetscDM,PetscInt*)
>>>>>>>>>>>>      int DMSetCoordinateDim(PetscDM,PetscInt)
>>>>>>>>>>>>      int DMLocalizeCoordinates(PetscDM)
>>>>>>>>>>>> +    int DMProjectCoordinates(PetscDM, PetscFE)
>>>>>>>>>>>>      int
>>>>>>>>>>>> DMCreateInterpolation(PetscDM,PetscDM,PetscMat*,PetscVec*)
>>>>>>>>>>>>      int DMCreateInjection(PetscDM,PetscDM,PetscMat*)
>>>>>>>>>>>> Then in python, I load a mesh and project the coordinates to P2:
>>>>>>>>>>>> import firedrake as fd
>>>>>>>>>>>> from firedrake.petsc import PETSc
>>>>>>>>>>>> # plex = fd.mesh._from_gmsh('test-fd-load-p2.msh')
>>>>>>>>>>>> plex = fd.mesh._from_gmsh('test-fd-load-p2-rect.msh')
>>>>>>>>>>>> print('old bbox:', plex.getBoundingBox())
>>>>>>>>>>>> dim = plex.getDimension()
>>>>>>>>>>>> #                                 (dim,  nc, isSimplex, k,
>>>>>>>>>>>>      qorder, comm=None)
>>>>>>>>>>>> fe_new = PETSc.FE().createLagrange(dim, dim,      True, 2,
>>>>>>>>>>>> PETSc.DETERMINE)
>>>>>>>>>>>> plex.projectCoordinates(fe_new)
>>>>>>>>>>>> fe_new.view()
>>>>>>>>>>>> print('new bbox:', plex.getBoundingBox())
>>>>>>>>>>>> The output is (The bounding box is changed!)
>>>>>>>>>>>> old bbox: ((0.0, 1.0), (0.0, 1.0), (0.0, 1.0))
>>>>>>>>>>>> PetscFE Object: P2 1 MPI processes
>>>>>>>>>>>>   type: basic
>>>>>>>>>>>>     type: sum
>>>>>>>>>>>>         type: poly
>>>>>>>>>>>>     type: lagrange
>>>>>>>>>>>> new bbox: ((-6.530133708576188e-17, 36.30670832662781), (-3.899962995254311e-17, 36.2406171632539), (-8.8036464152166e-17, 36.111577025012224))
>>>>>>>>>>>> By the way, for the original DG coordinates, where can I find the relation of the closure and the order of the dofs for the cell?
>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>   Zongze
>>>>>>>>>>>> Matthew Knepley <knepley at gmail.com> 于2022年6月17日周五 01:11写道:
>>>>>>>>>>>>> On Thu, Jun 16, 2022 at 12:06 PM Zongze Yang <
>>>>>>>>>>>>>> 在 2022年6月16日,23:22,Matthew Knepley <knepley at gmail.com> 写道:
>>>>>>>>>>>>>> On Thu, Jun 16, 2022 at 11:11 AM Zongze Yang <
>>>>>>>>>>>>>>> Hi, if I load a `gmsh` file with second-order elements, the
>>>>>>>>>>>>>>> coordinates will be stored in a DG-P2 space. After obtaining the
>>>>>>>>>>>>>>> coordinates of a cell, how can I map the coordinates to vertex and edge?
>>>>>>>>>>>>>> By default, they are stored as P2, not DG.
>>>>>>>>>>>>>> I checked the coordinates vector, and found the dogs only
>>>>>>>>>>>>>> defined on cell other than vertex and edge, so I said they are stored as DG.
>>>>>>>>>>>>>> Then the function DMPlexVecGetClosure
>>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexVecGetClosure/> seems return
>>>>>>>>>>>>>> the coordinates in lex order.
>>>>>>>>>>>>>> Some code in reading gmsh file reads that
>>>>>>>>>>>>>> 1756:     if (isSimplex) continuity = PETSC_FALSE
>>>>>>>>>>>>>> <https://petsc.org/main/docs/manualpages/Sys/PETSC_FALSE/>;
>>>>>>>>>>>>>> 1758:     GmshCreateFE(comm, NULL, isSimplex, continuity,
>>>>>>>>>>>>>> nodeType, dim, coordDim, order, &fe)
>>>>>>>>>>>>>> The continuity is set to false for simplex.
>>>>>>>>>>>>> Oh, yes. That needs to be fixed. For now, you can just project
>>>>>>>>>>>>> it to P2 if you want using
>>>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMProjectCoordinates/
>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Zongze
>>>>>>>>>>>>>> You can ask for the coordinates of a vertex or an edge
>>>>>>>>>>>>>> directly using
>>>>>>>>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexPointLocalRead/
>>>>>>>>>>>>>> by giving the vertex or edge point. You can get all the
>>>>>>>>>>>>>> coordinates on a cell, in the closure order, using
>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>> Below is some code load the gmsh file, I want to know the
>>>>>>>>>>>>>>> relation between `cl` and `cell_coords`.
>>>>>>>>>>>>>>> import numpy as np
>>>>>>>>>>>>>>> # Load gmsh file (2rd)
>>>>>>>>>>>>>>> cs, ce = plex.getHeightStratum(0)
>>>>>>>>>>>>>>> cdm = plex.getCoordinateDM()
>>>>>>>>>>>>>>> csec = dm.getCoordinateSection()
>>>>>>>>>>>>>>> coords_gvec = dm.getCoordinates()
>>>>>>>>>>>>>>> for i in range(cs, ce):
>>>>>>>>>>>>>>>     cell_coords = cdm.getVecClosure(csec, coords_gvec, i)
>>>>>>>>>>>>>>>     print(f'coordinates for cell {i}
>>>>>>>>>>>>>>> :\n{cell_coords.reshape([-1, 3])}')
>>>>>>>>>>>>>>>     cl = dm.getTransitiveClosure(i)
>>>>>>>>>>>>>>>     print('closure:', cl)
>>>>>>>>>>>>>>>     break
>>>>>>>>>>>>>>> Best wishes,
>>>>>>>>>>>>>>> Zongze
>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230515/2805283e/attachment-0001.html>
