[petsc-users] DMSWARM particle coordinates per rank
Matthew Young myoung.space.science at gmail.com
Fri May 12 08:39:49 CDT 2023
Got it.
I'm specifically thinking about this in terms of the gather stage of my PIC
code, where I loop over local particles to fill local density and flux
arrays by linearly interpolating particle positions to the grid. The gather
function currently assumes that the coordinates (i.e., the array
representation of DMSwarmPICField_coor) of all particles on a given rank
would correspond to only the global indices owned by that rank, via the
relationship between indices and coordinates in the associated cell DM.
Based on what you described, it sounds like I need to make sure that I
initially lay down the particles so that their rank matches their
coordinates.
--Matt
Matthew Young, PhD (he/him)
Research Scientist II
Space Science Center
University of New Hampshire
Matthew.Young at unh.edu
On Fri, May 12, 2023 at 5:15 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 11, 2023 at 9:15 PM Matthew Young <
> myoung.space.science at gmail.com> wrote:
>> Does setting up a PIC-type DMSWARM with an associated cell DM guarantee
>> that each MPI rank will own the particles with coordinates inside the
>> bounds of the portion of the grid it owns?
> There is a caveat that we are currently fixing. Swarm communication is
> setup to be nearest neighbor (since there is no coarse grid of
> bounding boxes). So if your particles are initially in the right place, and
> only move nearest neighbor, everything is fine. We are adding a hierarchy
> of bounding boxes so that we can communicate anywhere.
>   Thanks,
>       Matt
>> --Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230512/48493dba/attachment.html>
