[petsc-users] DMSWARM particle coordinates per rank
Fri May 12 09:05:26 CDT 2023
On Fri, May 12, 2023 at 9:40 AM Matthew Young <
myoung.space.science at gmail.com> wrote:
> Got it.
> I'm specifically thinking about this in terms of the gather stage of my
> PIC code, where I loop over local particles to fill local density and flux
> arrays by linearly interpolating particle positions to the grid. The gather
> function currently assumes that the coordinates (i.e., the array
> representation of DMSwarmPICField_coor) of all particles on a given rank
> would correspond to only the global indices owned by that rank, via the
> relationship between indices and coordinates in the associated cell DM.
> Based on what you described, it sounds like I need to make sure that I
> initially lay down the particles so that their rank matches their
> coordinates.
Right now, yes. I will fix that before August.
    Matt
> --Matt
> Matthew Young, PhD (he/him)
> Research Scientist II
> Space Science Center
> University of New Hampshire
> Matthew.Young at unh.edu
> On Fri, May 12, 2023 at 5:15 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, May 11, 2023 at 9:15 PM Matthew Young <
>>> Does setting up a PIC-type DMSWARM with an associated cell DM guarantee
>>> that each MPI rank will own the particles with coordinates inside the
>>> bounds of the portion of the grid it owns?
>> There is a caveat that we are currently fixing. Swarm communication is
>> setup to be nearest neighbor (since there is no coarse grid of
>> bounding boxes). So if your particles are initially in the right place, and
>> only move nearest neighbor, everything is fine. We are adding a hierarchy
>> of bounding boxes so that we can communicate anywhere.
>>   Thanks,
>>       Matt
>>> --Matt
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230512/1d4ff65d/attachment-0001.html>
