[petsc-users] parallel computing error
Pierre Jolivet pierre.jolivet at lip6.fr
Fri May 5 06:35:10 CDT 2023
> On 5 May 2023, at 1:25 PM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr> wrote:
> Dear Matthew Knepley
> However, I've already installed ScaLAPACK.
> cd $PETSC_DIR
> ./configure --download-mpich --with-debugging=0 COPTFLAGS='-O3 -march=native -mtune=native' CXXOPTFLAGS='-O3 -march=native -mtune=native' FOPTFLAGS='-O3 -march=native -mtune=native' --download-mumps --download-scalapack --download-parmetis --download-metis --download-parmetis --download-hpddm --download-slepc
> Is there some way to use ScaLAPCK?
You need to convert your MatDense to MatSCALAPACK before the call to MatMatSolve().
This library (ScaLAPACK, but also Elemental) has severe limitations with respect to the matrix distribution.
Depending on what you are doing, you may be better of using KSPMatSolve() and computing only an approximation of the solution with a cheap preconditioner (I don’t recall you telling us why you need to do such an operation even though we told you it was not practical — or maybe I’m being confused by another thread).
Pierre
> Or, Can I run the part related to MatMatSolve with a single core?
> 2023년 5월 5일 (금) 오후 6:21, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>님이 작성:
>> On Fri, May 5, 2023 at 3:49 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr <mailto:ksl7912 at snu.ac.kr>> wrote:
>>> Dear Barry Smith
>>> Thanks to you, I knew the difference between MATAIJ and MATDENSE.
>>> However, I still have some problems.
>>> There is no problem when I run with a single core. But, MatGetFactor error occurs when using multi-core.
>>> Could you give me some advice?
>>> The error message is
>>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>> [0]PETSC ERROR: See https://petsc.org/release/overview/linear_solve_table/ for possible LU and Cholesky solvers
>>> [0]PETSC ERROR: MatSolverType petsc does not support matrix type mpidense
>> PETSc uses 3rd party packages for parallel dense factorization. You would need to reconfigure with either ScaLAPACK
>> or Elemental.
>>   Thanks,
>>      Matt
>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.18.5, unknown
>>> [0]PETSC ERROR: ./app on a arch-linux-c-opt named ubuntu by ksl Fri May  5 00:35:23 2023
>>> [0]PETSC ERROR: Configure options --download-mpich --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native -mtune=native" --download-mumps --download-scalapack --download-parmetis --download-metis --download-parmetis --download-hpddm --download-slepc
>>> [0]PETSC ERROR: #1 MatGetFactor() at /home/ksl/petsc/src/mat/interface/matrix.c:4757
>>> [0]PETSC ERROR: #2 main() at /home/ksl/Downloads/coding_test/coding/a1.c:66
>>> [0]PETSC ERROR: No PETSc Option Table entries
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
>>> application called MPI_Abort(MPI_COMM_SELF, 92) - process 0
>>> My code is below:
>>> int main(int argc, char** args)
>>>     Mat A, E, A_temp, A_fac;
>>>     int n = 15;
>>>     PetscInitialize(&argc, &args, NULL, NULL);
>>>     PetscCallMPI(MPI_Comm_size(PETSC_COMM_WORLD, &size));
>>>     PetscCall(MatCreate(PETSC_COMM_WORLD, &A));
>>>     PetscCall(MatSetType(A,MATDENSE));
>>>     PetscCall(MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, n, n));
>>>     PetscCall(MatSetFromOptions(A));
>>>     PetscCall(MatSetUp(A));
>>>     // Insert values
>>>     double val;
>>>     for (int i = 0; i < n; i++) {
>>>         for (int j = 0; j < n; j++) {
>>>             if (i == j){
>>>                 val = 2.0;
>>>             else{
>>>                 val = 1.0;
>>>             PetscCall(MatSetValue(A, i, j, val, INSERT_VALUES));
>>>     PetscCall(MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY));
>>>     PetscCall(MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY));
>>>     // Make Identity matrix
>>>     PetscCall(MatCreate(PETSC_COMM_WORLD, &E));
>>>     PetscCall(MatSetType(E,MATDENSE));
>>>     PetscCall(MatSetSizes(E, PETSC_DECIDE, PETSC_DECIDE, n, n));
>>>     PetscCall(MatSetFromOptions(E));
>>>     PetscCall(MatSetUp(E));
>>>     PetscCall(MatShift(E,1.0));
>>>     PetscCall(MatAssemblyBegin(E, MAT_FINAL_ASSEMBLY));
>>>     PetscCall(MatAssemblyEnd(E, MAT_FINAL_ASSEMBLY));
>>>     PetscCall(MatDuplicate(A, MAT_DO_NOT_COPY_VALUES, &A_temp));
>>>     PetscCall(MatGetFactor(A, MATSOLVERPETSC, MAT_FACTOR_LU, &A_fac));
>>>     IS isr, isc; MatFactorInfo info;
>>>     MatGetOrdering(A, MATORDERINGNATURAL, &isr, &isc);
>>>     PetscCall(MatLUFactorSymbolic(A_fac, A, isr, isc, &info));
>>>     PetscCall(MatLUFactorNumeric(A_fac, A, &info));
>>>     MatMatSolve(A_fac, E, A_temp);
>>>     PetscCall(MatView(A_temp, PETSC_VIEWER_STDOUT_WORLD));
>>>     MatDestroy(&A);
>>>     MatDestroy(&A_temp);
>>>     MatDestroy(&A_fac);
>>>     MatDestroy(&E);
>>>     PetscCall(PetscFinalize());
>>> Best regards
>>> Seung Lee Kwon
>>> 2023년 5월 4일 (목) 오후 10:19, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>님이 작성:
>>>>   The code in ex125.c contains
>>>>  PetscCall(MatCreate(PETSC_COMM_WORLD, &C));
>>>>   PetscCall(MatSetOptionsPrefix(C, "rhs_"));
>>>>   PetscCall(MatSetSizes(C, m, PETSC_DECIDE, PETSC_DECIDE, nrhs));
>>>>   PetscCall(MatSetType(C, MATDENSE));
>>>>   PetscCall(MatSetFromOptions(C));
>>>>   PetscCall(MatSetUp(C));
>>>> This dense parallel matrix is suitable for passing to MatMatSolve() as the right-hand side matrix. Note it is created with PETSC_COMM_WORLD and its type is set to be MATDENSE.
>>>>   You may need to make a sample code by stripping out all the excess code in ex125.c to just create an MATAIJ and MATDENSE and solves with MatMatSolve() to determine why you code does not work.
>>>>> On May 4, 2023, at 3:20 AM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr <mailto:ksl7912 at snu.ac.kr>> wrote:
>>>>> Dear Barry Smith
>>>>> Thank you for your reply.
>>>>> I've already installed MUMPS.
>>>>> And I checked the example you said (ex125.c), I don't understand why the RHS matrix becomes the SeqDense matrix.
>>>>> Could you explain in more detail?
>>>>> Best regards
>>>>> Seung Lee Kwon
>>>>> 2023년 5월 4일 (목) 오후 12:08, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>님이 작성:
>>>>>>   You can configure with MUMPS ./configure --download-mumps --download-scalapack --download-ptscotch --download-metis --download-parmetis
>>>>>>   And then use MatMatSolve() as in src/mat/tests/ex125.c with parallel MatMatSolve() using MUMPS as the solver.
>>>>>>   Barry
>>>>>>> On May 3, 2023, at 10:29 PM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr <mailto:ksl7912 at snu.ac.kr>> wrote:
>>>>>>> Dear developers
>>>>>>> Thank you for your explanation.
>>>>>>> But I should use the MatCreateSeqDense because I want to use the MatMatSolve that B matrix must be a SeqDense matrix.
>>>>>>> Using MatMatSolve is an inevitable part of my code.
>>>>>>> Could you give me a comment to avoid this error?
>>>>>>> Best,
>>>>>>> Seung Lee Kwon
>>>>>>> 2023년 5월 3일 (수) 오후 7:30, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>님이 작성:
>>>>>>>> On Wed, May 3, 2023 at 6:05 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr <mailto:ksl7912 at snu.ac.kr>> wrote:
>>>>>>>>> Dear developers
>>>>>>>>> I'm trying to use parallel computing and I ran the command 'mpirun -np 4 ./app'
>>>>>>>>> In this case, there are two problems.
>>>>>>>>> First, I encountered error message
>>>>>>>>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>>>>>>> [1]PETSC ERROR: Invalid argument
>>>>>>>>> [1]PETSC ERROR: Comm must be of size 1
>>>>>>>>> The code on the error position is
>>>>>>>>> MatCreateSeqDense(PETSC_COMM_SELF, nns, ns, NULL, &Kns));
>>>>>>>> 1) "Seq" means sequential, that is "not parallel".
>>>>>>>> 2) This line should still be fine since PETSC_COMM_SELF is a serial communicator
>>>>>>>> 3) You should be checking the error code for each call, maybe using the CHKERRQ() macro
>>>>>>>> 4) Please always send the entire error message, not a snippet
>>>>>>>>   THanks
>>>>>>>>      Matt
>>>>>>>>> Could "MatCreateSeqDense" not be used in parallel computing?
>>>>>>>>> Second, the same error message is repeated as many times as the number of cores.
>>>>>>>>> if I use command -np 4, then the error message is repeated 4 times.
>>>>>>>>> Could you recommend some advice related to this?
>>>>>>>>> Best,
>>>>>>>>> Seung Lee Kwon
>>>>>>>>> Seung Lee Kwon, Ph.D.Candidate
>>>>>>>>> Aerospace Structures and Materials Laboratory
>>>>>>>>> Department of Mechanical and Aerospace Engineering
>>>>>>>>> Seoul National University
>>>>>>>>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
>>>>>>>>> E-mail : ksl7912 at snu.ac.kr <mailto:ksl7912 at snu.ac.kr>
>>>>>>>>> Office : +82-2-880-7389
>>>>>>>>> C. P : +82-10-4695-1062
>>>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230505/75ac2eae/attachment-0001.html>
