[petsc-users] parallel computing error
­권승리 / 학생 / 항공우주공학과 ksl7912 at snu.ac.kr
Fri May 5 06:25:12 CDT 2023
Dear Matthew Knepley
However, I've already installed ScaLAPACK.
cd $PETSC_DIR
./configure --download-mpich --with-debugging=0 COPTFLAGS='-O3
-march=native -mtune=native' CXXOPTFLAGS='-O3 -march=native -mtune=native'
FOPTFLAGS='-O3 -march=native -mtune=native' --download-mumps --
*download-scalapack* --download-parmetis --download-metis
--download-parmetis --download-hpddm --download-slepc
Is there some way to use ScaLAPCK?
Or, Can I run the part related to MatMatSolve with a single core?
2023년 5월 5일 (금) 오후 6:21, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Fri, May 5, 2023 at 3:49 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
> wrote:
>> Dear Barry Smith
>> Thanks to you, I knew the difference between MATAIJ and MATDENSE.
>> However, I still have some problems.
>> There is no problem when I run with a single core. But, MatGetFactor
>> error occurs when using multi-core.
>> Could you give me some advice?
>> The error message is
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: See
>> https://petsc.org/release/overview/linear_solve_table/ for possible LU
>> and Cholesky solvers
>> [0]PETSC ERROR: MatSolverType petsc does not support matrix type mpidense
> PETSc uses 3rd party packages for parallel dense factorization. You would
> need to reconfigure with either ScaLAPACK
> or Elemental.
>   Thanks,
>      Matt
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.18.5, unknown
>> [0]PETSC ERROR: ./app on a arch-linux-c-opt named ubuntu by ksl Fri May
>>  5 00:35:23 2023
>> [0]PETSC ERROR: Configure options --download-mpich --with-debugging=0
>> COPTFLAGS="-O3 -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native
>> -mtune=native" FOPTFLAGS="-O3 -march=native -mtune=native" --download-mumps
>> --download-scalapack --download-parmetis --download-metis
>> [0]PETSC ERROR: #1 MatGetFactor() at
>> /home/ksl/petsc/src/mat/interface/matrix.c:4757
>> [0]PETSC ERROR: #2 main() at
>> /home/ksl/Downloads/coding_test/coding/a1.c:66
>> [0]PETSC ERROR: No PETSc Option Table entries
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> application called MPI_Abort(MPI_COMM_SELF, 92) - process 0
>> My code is below:
>> int main(int argc, char** args)
>>     Mat A, E, A_temp, A_fac;
>>     int n = 15;
>>     PetscInitialize(&argc, &args, NULL, NULL);
>>     PetscCallMPI(MPI_Comm_size(PETSC_COMM_WORLD, &size));
>>     PetscCall(MatCreate(PETSC_COMM_WORLD, &A));
>>     PetscCall(MatSetType(A,MATDENSE));
>>     PetscCall(MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, n, n));
>>     PetscCall(MatSetFromOptions(A));
>>     PetscCall(MatSetUp(A));
>>     // Insert values
>>     double val;
>>     for (int i = 0; i < n; i++) {
>>         for (int j = 0; j < n; j++) {
>>             if (i == j){
>>                 val = 2.0;
>>             else{
>>                 val = 1.0;
>>             PetscCall(MatSetValue(A, i, j, val, INSERT_VALUES));
>>     PetscCall(MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY));
>>     PetscCall(MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY));
>>     // Make Identity matrix
>>     PetscCall(MatCreate(PETSC_COMM_WORLD, &E));
>>     PetscCall(MatSetType(E,MATDENSE));
>>     PetscCall(MatSetSizes(E, PETSC_DECIDE, PETSC_DECIDE, n, n));
>>     PetscCall(MatSetFromOptions(E));
>>     PetscCall(MatSetUp(E));
>>     PetscCall(MatShift(E,1.0));
>>     PetscCall(MatAssemblyBegin(E, MAT_FINAL_ASSEMBLY));
>>     PetscCall(MatAssemblyEnd(E, MAT_FINAL_ASSEMBLY));
>>     PetscCall(MatDuplicate(A, MAT_DO_NOT_COPY_VALUES, &A_temp));
>>     PetscCall(MatGetFactor(A, MATSOLVERPETSC, MAT_FACTOR_LU, &A_fac));
>>     IS isr, isc; MatFactorInfo info;
>>     MatGetOrdering(A, MATORDERINGNATURAL, &isr, &isc);
>>     PetscCall(MatLUFactorSymbolic(A_fac, A, isr, isc, &info));
>>     PetscCall(MatLUFactorNumeric(A_fac, A, &info));
>>     MatMatSolve(A_fac, E, A_temp);
>>     PetscCall(MatView(A_temp, PETSC_VIEWER_STDOUT_WORLD));
>>     MatDestroy(&A);
>>     MatDestroy(&A_temp);
>>     MatDestroy(&A_fac);
>>     MatDestroy(&E);
>>     PetscCall(PetscFinalize());
>> Best regards
>> Seung Lee Kwon
>> 2023년 5월 4일 (목) 오후 10:19, Barry Smith <bsmith at petsc.dev>님이 작성:
>>>   The code in ex125.c contains
>>>  PetscCall(MatCreate(PETSC_COMM_WORLD, &C));
>>>   PetscCall(MatSetOptionsPrefix(C, "rhs_"));
>>>   PetscCall(MatSetSizes(C, m, PETSC_DECIDE, PETSC_DECIDE, nrhs));
>>>   PetscCall(MatSetType(C, MATDENSE));
>>>   PetscCall(MatSetFromOptions(C));
>>>   PetscCall(MatSetUp(C));
>>> This dense parallel matrix is suitable for passing to MatMatSolve() as
>>> the right-hand side matrix. Note it is created with PETSC_COMM_WORLD and
>>> its type is set to be MATDENSE.
>>>   You may need to make a sample code by stripping out all the excess
>>> code in ex125.c to just create an MATAIJ and MATDENSE and solves with
>>> MatMatSolve() to determine why you code does not work.
>>> On May 4, 2023, at 3:20 AM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>>> wrote:
>>> Dear Barry Smith
>>> Thank you for your reply.
>>> I've already installed MUMPS.
>>> And I checked the example you said (ex125.c), I don't understand why the
>>> RHS matrix becomes the SeqDense matrix.
>>> Could you explain in more detail?
>>> Best regards
>>> Seung Lee Kwon
>>> 2023년 5월 4일 (목) 오후 12:08, Barry Smith <bsmith at petsc.dev>님이 작성:
>>>>   You can configure with MUMPS ./configure --download-mumps
>>>> --download-scalapack --download-ptscotch --download-metis
>>>> --download-parmetis
>>>>   And then use MatMatSolve() as in src/mat/tests/ex125.c with parallel
>>>> MatMatSolve() using MUMPS as the solver.
>>>>   Barry
>>>> On May 3, 2023, at 10:29 PM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>>>> wrote:
>>>> Dear developers
>>>> Thank you for your explanation.
>>>> But I should use the MatCreateSeqDense because I want to use the
>>>> MatMatSolve that B matrix must be a SeqDense matrix.
>>>> Using MatMatSolve is an inevitable part of my code.
>>>> Could you give me a comment to avoid this error?
>>>> Best,
>>>> Seung Lee Kwon
>>>> 2023년 5월 3일 (수) 오후 7:30, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>> On Wed, May 3, 2023 at 6:05 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>>>>> wrote:
>>>>>> Dear developers
>>>>>> I'm trying to use parallel computing and I ran the command 'mpirun
>>>>>> -np 4 ./app'
>>>>>> In this case, there are two problems.
>>>>>> *First,* I encountered error message
>>>>>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>>>>>> [1]PETSC ERROR: Invalid argument
>>>>>> [1]PETSC ERROR: Comm must be of size 1
>>>>>> The code on the error position is
>>>>>> MatCreateSeqDense(PETSC_COMM_SELF, nns, ns, NULL, &Kns));
>>>>> 1) "Seq" means sequential, that is "not parallel".
>>>>> 2) This line should still be fine since PETSC_COMM_SELF is a serial
>>>>> communicator
>>>>> 3) You should be checking the error code for each call, maybe using
>>>>> the CHKERRQ() macro
>>>>> 4) Please always send the entire error message, not a snippet
>>>>>   THanks
>>>>>      Matt
>>>>>> Could "MatCreateSeqDense" not be used in parallel computing?
>>>>>> *Second*, the same error message is repeated as many times as the
>>>>>> number of cores.
>>>>>> if I use command -np 4, then the error message is repeated 4 times.
>>>>>> Could you recommend some advice related to this?
>>>>>> Best,
>>>>>> Seung Lee Kwon
>>>>>> Seung Lee Kwon, Ph.D.Candidate
>>>>>> Aerospace Structures and Materials Laboratory
>>>>>> Department of Mechanical and Aerospace Engineering
>>>>>> Seoul National University
>>>>>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
>>>>>> E-mail : ksl7912 at snu.ac.kr
>>>>>> Office : +82-2-880-7389
>>>>>> C. P : +82-10-4695-1062
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230505/987239ce/attachment.html>
