[petsc-users] parallel computing error
­권승리 / 학생 / 항공우주공학과 ksl7912 at snu.ac.kr
Fri May 5 07:00:19 CDT 2023
Dear Pierre Jolivet
Thank you for your explanation.
I will try to use a converting matrix.
I know it's really inefficient, but I need an inverse matrix (inv(A))
itself for my research.
If parallel computing is difficult to get inv(A),  can I run the part
related to MatMatSolve with a single core?
Best,
Seung Lee Kwon
2023년 5월 5일 (금) 오후 8:35, Pierre Jolivet <pierre.jolivet at lip6.fr>님이 작성:
> On 5 May 2023, at 1:25 PM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr> wrote:
> Dear Matthew Knepley
> However, I've already installed ScaLAPACK.
> cd $PETSC_DIR
> ./configure --download-mpich --with-debugging=0 COPTFLAGS='-O3
> -march=native -mtune=native' CXXOPTFLAGS='-O3 -march=native -mtune=native'
> FOPTFLAGS='-O3 -march=native -mtune=native' --download-mumps --
> *download-scalapack* --download-parmetis --download-metis
> --download-parmetis --download-hpddm --download-slepc
> Is there some way to use ScaLAPCK?
> You need to convert your MatDense to MatSCALAPACK before the call to
> MatMatSolve().
> This library (ScaLAPACK, but also Elemental) has severe limitations with
> respect to the matrix distribution.
> Depending on what you are doing, you may be better of using KSPMatSolve()
> and computing only an approximation of the solution with a cheap
> preconditioner (I don’t recall you telling us why you need to do such an
> operation even though we told you it was not practical — or maybe I’m being
> confused by another thread).
> Thanks,
> Pierre
> Or, Can I run the part related to MatMatSolve with a single core?
> 2023년 5월 5일 (금) 오후 6:21, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Fri, May 5, 2023 at 3:49 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>> wrote:
>>> Dear Barry Smith
>>> Thanks to you, I knew the difference between MATAIJ and MATDENSE.
>>> However, I still have some problems.
>>> There is no problem when I run with a single core. But, MatGetFactor
>>> error occurs when using multi-core.
>>> Could you give me some advice?
>>> The error message is
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: See
>>> https://petsc.org/release/overview/linear_solve_table/ for possible LU
>>> and Cholesky solvers
>>> [0]PETSC ERROR: MatSolverType petsc does not support matrix type mpidense
>> PETSc uses 3rd party packages for parallel dense factorization. You would
>> need to reconfigure with either ScaLAPACK
>> or Elemental.
>>   Thanks,
>>      Matt
>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.18.5, unknown
>>> [0]PETSC ERROR: ./app on a arch-linux-c-opt named ubuntu by ksl Fri May
>>>  5 00:35:23 2023
>>> [0]PETSC ERROR: Configure options --download-mpich --with-debugging=0
>>> COPTFLAGS="-O3 -march=native -mtune=native" CXXOPTFLAGS="-O3 -march=native
>>> -mtune=native" FOPTFLAGS="-O3 -march=native -mtune=native" --download-mumps
>>> --download-scalapack --download-parmetis --download-metis
>>> [0]PETSC ERROR: #1 MatGetFactor() at
>>> /home/ksl/petsc/src/mat/interface/matrix.c:4757
>>> [0]PETSC ERROR: #2 main() at
>>> /home/ksl/Downloads/coding_test/coding/a1.c:66
>>> [0]PETSC ERROR: No PETSc Option Table entries
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>> error message to petsc-maint at mcs.anl.gov----------
>>> application called MPI_Abort(MPI_COMM_SELF, 92) - process 0
>>> My code is below:
>>> int main(int argc, char** args)
>>>     Mat A, E, A_temp, A_fac;
>>>     int n = 15;
>>>     PetscInitialize(&argc, &args, NULL, NULL);
>>>     PetscCallMPI(MPI_Comm_size(PETSC_COMM_WORLD, &size));
>>>     PetscCall(MatCreate(PETSC_COMM_WORLD, &A));
>>>     PetscCall(MatSetType(A,MATDENSE));
>>>     PetscCall(MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, n, n));
>>>     PetscCall(MatSetFromOptions(A));
>>>     PetscCall(MatSetUp(A));
>>>     // Insert values
>>>     double val;
>>>     for (int i = 0; i < n; i++) {
>>>         for (int j = 0; j < n; j++) {
>>>             if (i == j){
>>>                 val = 2.0;
>>>             else{
>>>                 val = 1.0;
>>>             PetscCall(MatSetValue(A, i, j, val, INSERT_VALUES));
>>>     PetscCall(MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY));
>>>     PetscCall(MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY));
>>>     // Make Identity matrix
>>>     PetscCall(MatCreate(PETSC_COMM_WORLD, &E));
>>>     PetscCall(MatSetType(E,MATDENSE));
>>>     PetscCall(MatSetSizes(E, PETSC_DECIDE, PETSC_DECIDE, n, n));
>>>     PetscCall(MatSetFromOptions(E));
>>>     PetscCall(MatSetUp(E));
>>>     PetscCall(MatShift(E,1.0));
>>>     PetscCall(MatAssemblyBegin(E, MAT_FINAL_ASSEMBLY));
>>>     PetscCall(MatAssemblyEnd(E, MAT_FINAL_ASSEMBLY));
>>>     PetscCall(MatDuplicate(A, MAT_DO_NOT_COPY_VALUES, &A_temp));
>>>     PetscCall(MatGetFactor(A, MATSOLVERPETSC, MAT_FACTOR_LU, &A_fac));
>>>     IS isr, isc; MatFactorInfo info;
>>>     MatGetOrdering(A, MATORDERINGNATURAL, &isr, &isc);
>>>     PetscCall(MatLUFactorSymbolic(A_fac, A, isr, isc, &info));
>>>     PetscCall(MatLUFactorNumeric(A_fac, A, &info));
>>>     MatMatSolve(A_fac, E, A_temp);
>>>     PetscCall(MatView(A_temp, PETSC_VIEWER_STDOUT_WORLD));
>>>     MatDestroy(&A);
>>>     MatDestroy(&A_temp);
>>>     MatDestroy(&A_fac);
>>>     MatDestroy(&E);
>>>     PetscCall(PetscFinalize());
>>> Best regards
>>> Seung Lee Kwon
>>> 2023년 5월 4일 (목) 오후 10:19, Barry Smith <bsmith at petsc.dev>님이 작성:
>>>>   The code in ex125.c contains
>>>>  PetscCall(MatCreate(PETSC_COMM_WORLD, &C));
>>>>   PetscCall(MatSetOptionsPrefix(C, "rhs_"));
>>>>   PetscCall(MatSetSizes(C, m, PETSC_DECIDE, PETSC_DECIDE, nrhs));
>>>>   PetscCall(MatSetType(C, MATDENSE));
>>>>   PetscCall(MatSetFromOptions(C));
>>>>   PetscCall(MatSetUp(C));
>>>> This dense parallel matrix is suitable for passing to MatMatSolve() as
>>>> the right-hand side matrix. Note it is created with PETSC_COMM_WORLD and
>>>> its type is set to be MATDENSE.
>>>>   You may need to make a sample code by stripping out all the excess
>>>> code in ex125.c to just create an MATAIJ and MATDENSE and solves with
>>>> MatMatSolve() to determine why you code does not work.
>>>> On May 4, 2023, at 3:20 AM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>>>> wrote:
>>>> Dear Barry Smith
>>>> Thank you for your reply.
>>>> I've already installed MUMPS.
>>>> And I checked the example you said (ex125.c), I don't understand why
>>>> the RHS matrix becomes the SeqDense matrix.
>>>> Could you explain in more detail?
>>>> Best regards
>>>> Seung Lee Kwon
>>>> 2023년 5월 4일 (목) 오후 12:08, Barry Smith <bsmith at petsc.dev>님이 작성:
>>>>>   You can configure with MUMPS ./configure --download-mumps
>>>>> --download-scalapack --download-ptscotch --download-metis
>>>>> --download-parmetis
>>>>>   And then use MatMatSolve() as in src/mat/tests/ex125.c with
>>>>> parallel MatMatSolve() using MUMPS as the solver.
>>>>>   Barry
>>>>> On May 3, 2023, at 10:29 PM, ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>>>>> wrote:
>>>>> Dear developers
>>>>> But I should use the MatCreateSeqDense because I want to use the
>>>>> MatMatSolve that B matrix must be a SeqDense matrix.
>>>>> Using MatMatSolve is an inevitable part of my code.
>>>>> Could you give me a comment to avoid this error?
>>>>> Best,
>>>>> Seung Lee Kwon
>>>>> 2023년 5월 3일 (수) 오후 7:30, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>>> On Wed, May 3, 2023 at 6:05 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>>>>>> wrote:
>>>>>>> Dear developers
>>>>>>> I'm trying to use parallel computing and I ran the command 'mpirun
>>>>>>> -np 4 ./app'
>>>>>>> In this case, there are two problems.
>>>>>>> *First,* I encountered error message
>>>>>>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>>>>>>> [1]PETSC ERROR: Invalid argument
>>>>>>> [1]PETSC ERROR: Comm must be of size 1
>>>>>>> The code on the error position is
>>>>>>> MatCreateSeqDense(PETSC_COMM_SELF, nns, ns, NULL, &Kns));
>>>>>> 1) "Seq" means sequential, that is "not parallel".
>>>>>> 2) This line should still be fine since PETSC_COMM_SELF is a serial
>>>>>> communicator
>>>>>> 3) You should be checking the error code for each call, maybe using
>>>>>> the CHKERRQ() macro
>>>>>> 4) Please always send the entire error message, not a snippet
>>>>>>   THanks
>>>>>>      Matt
>>>>>>> Could "MatCreateSeqDense" not be used in parallel computing?
>>>>>>> *Second*, the same error message is repeated as many times as the
>>>>>>> number of cores.
>>>>>>> if I use command -np 4, then the error message is repeated 4 times.
>>>>>>> Could you recommend some advice related to this?
>>>>>>> Best,
>>>>>>> Seung Lee Kwon
>>>>>>> Seung Lee Kwon, Ph.D.Candidate
>>>>>>> Aerospace Structures and Materials Laboratory
>>>>>>> Department of Mechanical and Aerospace Engineering
>>>>>>> Seoul National University
>>>>>>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea,
>>>>>>> 08826
>>>>>>> E-mail : ksl7912 at snu.ac.kr
>>>>>>> Office : +82-2-880-7389
>>>>>>> C. P : +82-10-4695-1062
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230505/e57d224c/attachment-0001.html>
