[petsc-users] Using PETSc GPU backend
Fri Jun 30 05:16:32 CDT 2023
On Fri, Jun 30, 2023 at 1:13 AM Ng, Cho-Kuen via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Mark,
> The application code reads in parameters from an input file, where we can
> put the PETSc runtime options. Then we pass the options to
> PetscInitialize(...). Does that sounds right?
PETSc will read command line argument automatically in PetscInitialize()
unless you shut it off.
    Matt
> Cho
> *From:* Ng, Cho-Kuen <cho at slac.stanford.edu>
> *Sent:* Thursday, June 29, 2023 8:32 PM
> *To:* Mark Adams <mfadams at lbl.gov>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Using PETSc GPU backend
> Mark,
> Thanks for the information. How do I put the runtime options for the
> executable, say, a.out, which does not have the provision to append
> arguments? Do I need to change the C++ main to read in the options?
> Cho
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* Thursday, June 29, 2023 5:55 PM
> *To:* Ng, Cho-Kuen <cho at slac.stanford.edu>
> Run with options: -mat_type aijcusparse -vec_type cuda -log_view
> -options_left
> The last column of the performance data (from -log_view) will be the
> percent flops on the GPU. Check that that is > 0.
> The end of the output will list the options that were used and options
> that were _not_ used (if any). Check that there are no options left.
> Mark
> On Thu, Jun 29, 2023 at 7:50 PM Ng, Cho-Kuen via petsc-users <
> I installed PETSc on Perlmutter using "spack install petsc+cuda+zoltan" and
> used it by "spack load petsc/fwge6pf". Then I compiled the application
> code (purely CPU code) linking to the petsc package, hoping that I can get
> performance improvement using the petsc GPU backend. However, the timing
> was the same using the same number of MPI tasks with and without GPU
> accelerators. Have I missed something in the process, for example, setting
> up PETSc options at runtime to use the GPU backend?
> Thanks,
> Cho
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230630/b0e005bc/attachment.html>
