[petsc-users] Using PETSc GPU backend
Ng, Cho-Kuen cho at slac.stanford.edu
Fri Jun 30 00:12:21 CDT 2023
Mark,
The application code reads in parameters from an input file, where we can put the PETSc runtime options. Then we pass the options to PetscInitialize(...). Does that sounds right?
Cho
Sent: Thursday, June 29, 2023 8:32 PM
To: Mark Adams <mfadams at lbl.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Using PETSc GPU backend
Mark,
Thanks for the information. How do I put the runtime options for the executable, say, a.out, which does not have the provision to append arguments? Do I need to change the C++ main to read in the options?
Cho
Sent: Thursday, June 29, 2023 5:55 PM
To: Ng, Cho-Kuen <cho at slac.stanford.edu>
Run with options: -mat_type aijcusparse -vec_type cuda -log_view -options_left
The last column of the performance data (from -log_view) will be the percent flops on the GPU. Check that that is > 0.
The end of the output will list the options that were used and options that were _not_ used (if any). Check that there are no options left.
On Thu, Jun 29, 2023 at 7:50 PM Ng, Cho-Kuen via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
I installed PETSc on Perlmutter using "spack install petsc+cuda+zoltan" and used it by "spack load petsc/fwge6pf". Then I compiled the application code (purely CPU code) linking to the petsc package, hoping that I can get performance improvement using the petsc GPU backend. However, the timing was the same using the same number of MPI tasks with and without GPU accelerators. Have I missed something in the process, for example, setting up PETSc options at runtime to use the GPU backend?
Cho
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230630/0cb39a3d/attachment-0001.html>
