[petsc-users] periodic boundary conditions
Tue Jul 18 10:38:17 CDT 2023
On Tue, Jul 18, 2023 at 11:18 AM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Thanks Matt.
> The mesh is structured (rectilinear), so it is periodic in that sense.
> Can you please explain how I can impose it strongly?
Strongly means make those variables equal in a pointwise sense. We do this
in the
LocalToGlobal mapping, so one set is eliminated in the global problem.
    Matt
> My initial thought was to come up with a relation between the periodic
> nodes:
> x = P x’
> Say for 1-D problem with two elements
> (1)-------------(2)------------(3)
> P = [1 0, 0 1, 1 0]
> x = [x1 x2 x3]
> x’ = [x1 x2]
> and solve
> [P^T A P] x’ = P^T b
> I don’t think [P^T A P] is deterministic.
> Kind regards,
> Karthik.
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Tuesday, 18 July 2023 at 14:31
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] periodic boundary conditions
> On Tue, Jul 18, 2023 at 9:02 AM Karthikeyan Chockalingam - STFC UKRI via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> This is exactly not a PETSc question. I am solving a Poisson equation
> using finite elements. I would like to impose PBC. I am thinking of using
> the Lagrange multiplier method to impose them as constraints. Or do you
> think I could take an alternative approach?
> There are several options:
> 1) Just make a periodic mesh. This is what Plex does by default.
> 2) Impose the conditions strongly. This is what is done if you create the
> ZBox shape in Plex.
> 3) Impose the conditions weakly. This is what you are doing with Lagrange
> multipliers. You could
> also do a Nitsche boundary condition for this.
> Since the constraint is so simple, I do not see an advantage to imposing
> it weakly.
>   Thanks,
>      Matt
> Thank you for your help.
> Kind regards,
> Karthik.
> *Dr. Karthik Chockalingam*
> High Performance Software Engineering Group
> Hartree Centre | Science and Technology Facilities Council
>  [image: signature_3970890138]
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230718/d7cb46a3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230718/d7cb46a3/attachment-0001.png>
