[petsc-users] periodic boundary conditions
Karthikeyan Chockalingam - STFC UKRI karthikeyan.chockalingam at stfc.ac.uk
Tue Jul 18 10:51:27 CDT 2023
Yes, I clearly understand I need to eliminate one set of periodic nodes. I was hoping to use x = P x’ to eliminate one set. It is a kind of mapping.
Sorry, I am not sure if it is the LocalToGlobal mapping you are referring to. Is there an example or reference to show how the LocalToGlobal mapping is being used to impose PBC?
Best,
Karthik.
Date: Tuesday, 18 July 2023 at 16:38
To: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] periodic boundary conditions
On Tue, Jul 18, 2023 at 11:18 AM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
Thanks Matt.
The mesh is structured (rectilinear), so it is periodic in that sense.
Can you please explain how I can impose it strongly?
Strongly means make those variables equal in a pointwise sense. We do this in the
LocalToGlobal mapping, so one set is eliminated in the global problem.
    Matt
My initial thought was to come up with a relation between the periodic nodes:
x = P x’
Say for 1-D problem with two elements
(1)-------------(2)------------(3)
P = [1 0, 0 1, 1 0]
x = [x1 x2 x3]
x’ = [x1 x2]
and solve
[P^T A P] x’ = P^T b
I don’t think [P^T A P] is deterministic.
Kind regards,
Karthik.
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Date: Tuesday, 18 July 2023 at 14:31
To: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
On Tue, Jul 18, 2023 at 9:02 AM Karthikeyan Chockalingam - STFC UKRI via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello,
This is exactly not a PETSc question. I am solving a Poisson equation using finite elements. I would like to impose PBC. I am thinking of using the Lagrange multiplier method to impose them as constraints. Or do you think I could take an alternative approach?
There are several options:
1) Just make a periodic mesh. This is what Plex does by default.
2) Impose the conditions strongly. This is what is done if you create the ZBox shape in Plex.
3) Impose the conditions weakly. This is what you are doing with Lagrange multipliers. You could
also do a Nitsche boundary condition for this.
Since the constraint is so simple, I do not see an advantage to imposing it weakly.
     Matt
Thank you for your help.
Kind regards,
Karthik.
Dr. Karthik Chockalingam
High Performance Software Engineering Group
Hartree Centre | Science and Technology Facilities Council
 [signature_3970890138]
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230718/920a607b/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230718/920a607b/attachment-0001.png>
