[petsc-users] windows build
hamid badi badi.hamid at gmail.com
Mon Jul 17 05:12:11 CDT 2023
For me, I got no problem when compiling Petsc with Mumps under mingw/clang
or gcc, everything works fine.
May be i could write a tutorial when I'll have time, now i'm on holidays.
Le lun. 17 juil. 2023 à 12:08, Константин via petsc-users <
petsc-users at mcs.anl.gov> a écrit :
> Hello. I have such problem, while I'm making petsc
> $ make
> C:/cygwin64/home/itugr/asd/petsc//lib/petsc/conf/petscvariables:140: ***
> Too many open files.  Stop.
>  Are there any advices how to fix it?
> Константин
> Вторник, 11 июля 2023, 23:09 +03:00 от Satish Balay <balay at mcs.anl.gov>:
> On Tue, 11 Jul 2023, Константин via petsc-users wrote:
> > Hello, I'm trying to build petsc on windows. And when I make it I have
> such problem
> from the screenshot - it appears you are not using cygwin
> terminal(bash-shell) - as per instructions
> https://petsc.org/release/install/windows/
> What compilers are you attempting to use with PETSc? Can you retry your
> build - as per the above instructions?
> If you still encounter issues - send us the corresponding configure.log.
> Also - best if you can copy/paste text from terminal - instead of
> screenshots
> Note: if you can use WSL2(linux) on your windows machine - that might be
> an easier install
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230717/80575213/attachment-0001.html>
