[petsc-users] windows build
Константин itugrik76 at mail.ru
Mon Jul 17 05:07:33 CDT 2023
Hello. I have such problem, while I'm making petsc
$ make
C:/cygwin64/home/itugr/asd/petsc//lib/petsc/conf/petscvariables:140: *** Too many open files.  Stop.
 Are there any advices how to fix it?
Константин
>Вторник, 11 июля 2023, 23:09 +03:00 от Satish Balay <balay at mcs.anl.gov>:
>On Tue, 11 Jul 2023, Константин via petsc-users wrote:
>> Hello, I'm trying to build petsc on windows. And when I make it I have such problem
>from the screenshot - it appears you are not using cygwin terminal(bash-shell) - as per instructions
>https://petsc.org/release/install/windows/
>What compilers are you attempting to use with PETSc? Can you retry your build - as per the above instructions?
>If you still encounter issues - send us the corresponding configure.log.
>Also - best if you can copy/paste text from terminal - instead of screenshots
>Note: if you can use WSL2(linux) on your windows machine - that might be an easier install
>Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230717/32614385/attachment.html>
