[petsc-users] windows build
Mon Jul 17 05:42:44 CDT 2023
On Mon, Jul 17, 2023 at 6:08 AM Константин via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello. I have such problem, while I'm making petsc
> $ make
> C:/cygwin64/home/itugr/asd/petsc//lib/petsc/conf/petscvariables:140: ***
> Too many open files.  Stop.
>  Are there any advices how to fix it?
This is an OS problem, and since this is Windows, I would try rebooting.
  THanks,
    Matt
> Константин
> Вторник, 11 июля 2023, 23:09 +03:00 от Satish Balay <balay at mcs.anl.gov>:
> On Tue, 11 Jul 2023, Константин via petsc-users wrote:
> > Hello, I'm trying to build petsc on windows. And when I make it I have
> such problem
> from the screenshot - it appears you are not using cygwin
> terminal(bash-shell) - as per instructions
> https://petsc.org/release/install/windows/
> What compilers are you attempting to use with PETSc? Can you retry your
> build - as per the above instructions?
> If you still encounter issues - send us the corresponding configure.log.
> Also - best if you can copy/paste text from terminal - instead of
> screenshots
> Note: if you can use WSL2(linux) on your windows machine - that might be
> an easier install
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230717/6416f84c/attachment.html>
