[petsc-users] Multiplication of partitioned with non-partitioned (sparse) PETSc matrices
Mark Adams mfadams at lbl.gov
Wed Aug 23 05:56:41 CDT 2023
On Wed, Aug 23, 2023 at 5:36 AM Thanasis Boutsikakis <
thanasis.boutsikakis at corintis.com> wrote:
> Thanks for the suggestion Pierre.
> Yes B is duplicated by all processes.
> In this case, should B be created as a sequential sparse matrix using
> COMM_SELF?
Yes, that is what Pierre said,
> I guess if not, the multiplication of B with the output of
> https://petsc.org/main/manualpages/Mat/MatMPIAIJGetLocalMat/ would not go
> through, right?
> Thanks,
> Thanos
> On 23 Aug 2023, at 10:47, Pierre Jolivet <pierre.jolivet at lip6.fr> wrote:
> On 23 Aug 2023, at 5:35 PM, Thanasis Boutsikakis <
> Hi all,
> I am trying to multiply two Petsc matrices as C = A * B, where A is a tall
> matrix and B is a relatively small matrix.
> I have taken the decision to create A as (row-)partitioned matrix and B as
> a non-partitioned matrix that it is entirely shared by all procs (to avoid
> unnecessary communication).
> Here is my code:
> import numpy as np
> from firedrake import COMM_WORLD
> from firedrake.petsc import PETSc
> from numpy.testing import assert_array_almost_equal
> nproc = COMM_WORLD.size
> rank = COMM_WORLD.rank
> def create_petsc_matrix_non_partitioned(input_array):
> """Building a mpi non-partitioned petsc matrix from an array
> Args:
> input_array (np array): Input array
> sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
> Returns:
> mpi mat: PETSc matrix
> assert len(input_array.shape) == 2
> m, n = input_array.shape
> matrix = PETSc.Mat().createAIJ(size=((m, n), (m, n)), comm=COMM_WORLD)
> # Set the values of the matrix
> matrix.setValues(range(m), range(n), input_array[:, :], addv=False)
> # Assembly the matrix to compute the final structure
> matrix.assemblyBegin()
> matrix.assemblyEnd()
> return matrix
> def create_petsc_matrix(input_array, partition_like=None):
> """Create a PETSc matrix from an input_array
> Args:
> partition_like (petsc mat, optional): Petsc matrix. Defaults to None.
> Returns:
> petsc mat: PETSc matrix
> # Check if input_array is 1D and reshape if necessary
> assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
> global_rows, global_cols = input_array.shape
> comm = COMM_WORLD
> if partition_like is not None:
> local_rows_start, local_rows_end = partition_like.getOwnershipRange()
> local_rows = local_rows_end - local_rows_start
> # No parallelization in the columns, set local_cols = None to parallelize
> size = ((local_rows, global_rows), (global_cols, global_cols))
> else:
> size = ((None, global_rows), (global_cols, global_cols))
> matrix = PETSc.Mat().createAIJ(size=size, comm=comm)
> matrix.setUp()
> local_rows_start, local_rows_end = matrix.getOwnershipRange()
> for counter, i in enumerate(range(local_rows_start, local_rows_end)):
> # Calculate the correct row in the array for the current process
> row_in_array = counter + local_rows_start
> matrix.setValues(
> i, range(global_cols), input_array[row_in_array, :], addv=False
> return matrix
> m, k = 10, 3
> # Generate the random numpy matrices
> np.random.seed(0) # sets the seed to 0
> A_np = np.random.randint(low=0, high=6, size=(m, k))
> B_np = np.random.randint(low=0, high=6, size=(k, k))
> A = create_petsc_matrix(A_np)
> B = create_petsc_matrix_non_partitioned(B_np)
> # Now perform the multiplication
> C = A * B
> The problem with this is that there is a mismatch between the local rows
> of A (depend on the partitioning) and the global rows of B (3 for all
> procs), so that the multiplication cannot happen in parallel. Here is the
> error:
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is
> causing the crash.
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
> system msg for write_line failure : Bad file descriptor
> Is there a standard way to achieve this?
> Your B is duplicated by all processes?
> If so, then, call
> https://petsc.org/main/manualpages/Mat/MatMPIAIJGetLocalMat/, do a
> sequential product with B on COMM_SELF, not COMM_WORLD, and use
> https://petsc.org/main/manualpages/Mat/MatCreateMPIMatConcatenateSeqMat/ with
> the output.
> Thanks,
> Pierre
> Thanks,
> Thanos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230823/8df6863d/attachment-0001.html>
