[petsc-users] Multiplication of partitioned with non-partitioned (sparse) PETSc matrices
Thanasis Boutsikakis thanasis.boutsikakis at corintis.com
Wed Aug 23 06:59:07 CDT 2023
Thanks for the clarification Mark.
I have tried such an implementation but I since I could not find the equivalent of https://petsc.org/main/manualpages/Mat/MatMPIAIJGetLocalMat/ for petsc4py, I used A.getLocalSubMatrix to do so, which returns a ‘localref’ object that I cannot then use to get my local 'seqaij’ matrix. I also tried A.getDenseLocalMatrix() but it seems not to be suitable for my case. I couldn’t find an example in the petsc4py source code or something relevant, do you have any ideas?
"""Experimenting with petsc mat-mat multiplication"""
# import pdb
import numpy as np
from firedrake import COMM_WORLD
from firedrake.petsc import PETSc
from numpy.testing import assert_array_almost_equal
import pdb
nproc = COMM_WORLD.size
rank = COMM_WORLD.rank
def Print(x: str):
    """Prints the string only on the root process
    Args:
        x (str): String to be printed
    PETSc.Sys.Print(x)
def create_petsc_matrix_seq(input_array):
    """Building a sequential petsc matrix from an array
    Args:
        input_array (np array): Input array
    Returns:
        seq mat: PETSc matrix
    assert len(input_array.shape) == 2
    m, n = input_array.shape
    matrix = PETSc.Mat().createAIJ(size=(m, n), comm=PETSc.COMM_SELF)
    matrix.setUp()
    matrix.setValues(range(m), range(n), input_array, addv=False)
    # Assembly the matrix to compute the final structure
    matrix.assemblyBegin()
    matrix.assemblyEnd()
    return matrix
def create_petsc_matrix(input_array, partition_like=None):
    """Create a PETSc matrix from an input_array
    Args:
        partition_like (petsc mat, optional): Petsc matrix. Defaults to None.
        sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
    Returns:
        petsc mat: PETSc matrix
    # Check if input_array is 1D and reshape if necessary
    assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
    global_rows, global_cols = input_array.shape
    comm = COMM_WORLD
    if partition_like is not None:
        local_rows_start, local_rows_end = partition_like.getOwnershipRange()
        local_rows = local_rows_end - local_rows_start
        # No parallelization in the columns, set local_cols = None to parallelize
        size = ((local_rows, global_rows), (global_cols, global_cols))
    else:
        size = ((None, global_rows), (global_cols, global_cols))
    matrix = PETSc.Mat().createAIJ(size=size, comm=comm)
    matrix.setUp()
    local_rows_start, local_rows_end = matrix.getOwnershipRange()
    for counter, i in enumerate(range(local_rows_start, local_rows_end)):
        # Calculate the correct row in the array for the current process
        row_in_array = counter + local_rows_start
        matrix.setValues(
            i, range(global_cols), input_array[row_in_array, :], addv=False
    return matrix
m, k = 10, 3
# Generate the random numpy matrices
np.random.seed(0)  # sets the seed to 0
A_np = np.random.randint(low=0, high=6, size=(m, k))
B_np = np.random.randint(low=0, high=6, size=(k, k))
# Create B as a sequential matrix on each process
B_seq = create_petsc_matrix_seq(B_np)
Print(B_seq.getType())
Print(B_seq.getSizes())
A = create_petsc_matrix(A_np)
print("A type:", A.getType())
print("A sizes:", A.getSizes())
print("A local ownership range:", A.getOwnershipRange())
# pdb.set_trace()
# Create a local sequential matrix for A using the local submatrix
local_rows_start, local_rows_end = A.getOwnershipRange()
print("local_rows_start:", local_rows_start)
print("local_rows_end:", local_rows_end)
print("local_rows:", local_rows)
local_A = PETSc.Mat().createAIJ(size=(local_rows, k), comm=PETSc.COMM_SELF)
# pdb.set_trace()
comm = A.getComm()
rows = PETSc.IS().createStride(local_rows, first=0, step=1, comm=comm)
cols = PETSc.IS().createStride(k, first=0, step=1, comm=comm)
print("rows indices:", rows.getIndices())
print("cols indices:", cols.getIndices())
# pdb.set_trace()
# Create the local to global mapping for rows and columns
l2g_rows = PETSc.LGMap().create(rows.getIndices(), comm=comm)
l2g_cols = PETSc.LGMap().create(cols.getIndices(), comm=comm)
print("l2g_rows type:", type(l2g_rows))
print("l2g_rows:", l2g_rows.view())
print("l2g_rows type:", type(l2g_cols))
print("l2g_cols:", l2g_cols.view())
# pdb.set_trace()
# Set the local-to-global mapping for the matrix
A.setLGMap(l2g_rows, l2g_cols)
# pdb.set_trace()
# Now you can get the local submatrix
local_A = A.getLocalSubMatrix(rows, cols)
local_A.assemblyBegin()
local_A.assemblyEnd()
Print(local_A.getType())
Print(local_A.getSizes())
# pdb.set_trace()
# Multiply the two matrices
local_C = local_A.matMult(B_seq)
> On 23 Aug 2023, at 12:56, Mark Adams <mfadams at lbl.gov> wrote:
> On Wed, Aug 23, 2023 at 5:36 AM Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>> Thanks for the suggestion Pierre.
>> Yes B is duplicated by all processes.
>> In this case, should B be created as a sequential sparse matrix using COMM_SELF?
> Yes, that is what Pierre said,
> Mark
>> I guess if not, the multiplication of B with the output of https://petsc.org/main/manualpages/Mat/MatMPIAIJGetLocalMat/ would not go through, right?
>> Thanks,
>> Thanos
>>> On 23 Aug 2023, at 10:47, Pierre Jolivet <pierre.jolivet at lip6.fr <mailto:pierre.jolivet at lip6.fr>> wrote:
>>>> On 23 Aug 2023, at 5:35 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com <mailto:thanasis.boutsikakis at corintis.com>> wrote:
>>>> Hi all,
>>>> I am trying to multiply two Petsc matrices as C = A * B, where A is a tall matrix and B is a relatively small matrix.
>>>> I have taken the decision to create A as (row-)partitioned matrix and B as a non-partitioned matrix that it is entirely shared by all procs (to avoid unnecessary communication).
>>>> Here is my code:
>>>> import numpy as np
>>>> def create_petsc_matrix_non_partitioned(input_array):
>>>>     """Building a mpi non-partitioned petsc matrix from an array
>>>>     Args:
>>>>     Returns:
>>>>         mpi mat: PETSc matrix
>>>>     matrix = PETSc.Mat().createAIJ(size=((m, n), (m, n)), comm=COMM_WORLD)
>>>>     # Set the values of the matrix
>>>>     matrix.setValues(range(m), range(n), input_array[:, :], addv=False)
>>>>     return matrix
>>>>     Args:
>>>>     Returns:
>>>>     comm = COMM_WORLD
>>>>     else:
>>>>     matrix.setUp()
>>>>         matrix.setValues(
>>>>     return matrix
>>>> m, k = 10, 3
>>>> B = create_petsc_matrix_non_partitioned(B_np)
>>>> # Now perform the multiplication
>>>> C = A * B
>>>> The problem with this is that there is a mismatch between the local rows of A (depend on the partitioning) and the global rows of B (3 for all procs), so that the multiplication cannot happen in parallel. Here is the error:
>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>>> [0]PETSC ERROR: to get more information on the crash.
>>>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
>>>> system msg for write_line failure : Bad file descriptor
>>>> Is there a standard way to achieve this?
>>> Your B is duplicated by all processes?
>>> If so, then, call https://petsc.org/main/manualpages/Mat/MatMPIAIJGetLocalMat/, do a sequential product with B on COMM_SELF, not COMM_WORLD, and use https://petsc.org/main/manualpages/Mat/MatCreateMPIMatConcatenateSeqMat/ with the output.
>>> Thanks,
>>> Pierre
>>>> Thanks,
>>>> Thanos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230823/e30f0163/attachment-0001.html>
