[petsc-users] Multiplication of partitioned with non-partitioned (sparse) PETSc matrices
Thanasis Boutsikakis thanasis.boutsikakis at corintis.com
Wed Aug 23 04:35:32 CDT 2023
Thanks for the suggestion Pierre.
Yes B is duplicated by all processes.
In this case, should B be created as a sequential sparse matrix using COMM_SELF? I guess if not, the multiplication of B with the output of https://petsc.org/main/manualpages/Mat/MatMPIAIJGetLocalMat/ would not go through, right?
Thanos
> On 23 Aug 2023, at 10:47, Pierre Jolivet <pierre.jolivet at lip6.fr> wrote:
>> On 23 Aug 2023, at 5:35 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>> Hi all,
>> I am trying to multiply two Petsc matrices as C = A * B, where A is a tall matrix and B is a relatively small matrix.
>> I have taken the decision to create A as (row-)partitioned matrix and B as a non-partitioned matrix that it is entirely shared by all procs (to avoid unnecessary communication).
>> Here is my code:
>> import numpy as np
>> from firedrake import COMM_WORLD
>> from firedrake.petsc import PETSc
>> from numpy.testing import assert_array_almost_equal
>> nproc = COMM_WORLD.size
>> rank = COMM_WORLD.rank
>> def create_petsc_matrix_non_partitioned(input_array):
>>     """Building a mpi non-partitioned petsc matrix from an array
>>     Args:
>>         input_array (np array): Input array
>>         sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
>>     Returns:
>>         mpi mat: PETSc matrix
>>     assert len(input_array.shape) == 2
>>     m, n = input_array.shape
>>     matrix = PETSc.Mat().createAIJ(size=((m, n), (m, n)), comm=COMM_WORLD)
>>     # Set the values of the matrix
>>     matrix.setValues(range(m), range(n), input_array[:, :], addv=False)
>>     # Assembly the matrix to compute the final structure
>>     matrix.assemblyBegin()
>>     matrix.assemblyEnd()
>>     return matrix
>> def create_petsc_matrix(input_array, partition_like=None):
>>     """Create a PETSc matrix from an input_array
>>     Args:
>>         partition_like (petsc mat, optional): Petsc matrix. Defaults to None.
>>     Returns:
>>         petsc mat: PETSc matrix
>>     # Check if input_array is 1D and reshape if necessary
>>     assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
>>     global_rows, global_cols = input_array.shape
>>     comm = COMM_WORLD
>>     if partition_like is not None:
>>         local_rows_start, local_rows_end = partition_like.getOwnershipRange()
>>         local_rows = local_rows_end - local_rows_start
>>         # No parallelization in the columns, set local_cols = None to parallelize
>>         size = ((local_rows, global_rows), (global_cols, global_cols))
>>     else:
>>         size = ((None, global_rows), (global_cols, global_cols))
>>     matrix = PETSc.Mat().createAIJ(size=size, comm=comm)
>>     matrix.setUp()
>>     local_rows_start, local_rows_end = matrix.getOwnershipRange()
>>     for counter, i in enumerate(range(local_rows_start, local_rows_end)):
>>         # Calculate the correct row in the array for the current process
>>         row_in_array = counter + local_rows_start
>>         matrix.setValues(
>>             i, range(global_cols), input_array[row_in_array, :], addv=False
>>     return matrix
>> m, k = 10, 3
>> # Generate the random numpy matrices
>> np.random.seed(0)  # sets the seed to 0
>> A_np = np.random.randint(low=0, high=6, size=(m, k))
>> B_np = np.random.randint(low=0, high=6, size=(k, k))
>> A = create_petsc_matrix(A_np)
>> B = create_petsc_matrix_non_partitioned(B_np)
>> # Now perform the multiplication
>> C = A * B
>> The problem with this is that there is a mismatch between the local rows of A (depend on the partitioning) and the global rows of B (3 for all procs), so that the multiplication cannot happen in parallel. Here is the error:
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
>> system msg for write_line failure : Bad file descriptor
>> Is there a standard way to achieve this?
> Your B is duplicated by all processes?
> If so, then, call https://petsc.org/main/manualpages/Mat/MatMPIAIJGetLocalMat/, do a sequential product with B on COMM_SELF, not COMM_WORLD, and use https://petsc.org/main/manualpages/Mat/MatCreateMPIMatConcatenateSeqMat/ with the output.
> Thanks,
> Pierre
>> Thanks,
>> Thanos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230823/fb33de61/attachment.html>
