[petsc-users] DMPlex bug in src/snes/tutorials/ex17.c
Wed Aug 9 10:58:22 CDT 2023
On Wed, Aug 9, 2023 at 11:09 AM Ilya Fursov <ilya.foursov.7bd at gmail.com>
wrote:
> Hello,
> I have a problem running src/snes/tutorials/ex17.c in parallel,
> given the specific runtime options (these options are actually taken from
> the test example ex17_3d_q3_trig_elas).
> *The serial version works fine:*
> ./ex17 -dm_plex_box_faces 1,1,1 -sol_type elas_trig -dm_plex_dim 3
> -dm_plex_simplex 0 -displacement_petscspace_degree 3 -dm_refine 0
> -convest_num_refine 1 -snes_convergence_estimate -snes_monitor
> *The parallel version fails:*
> mpirun -n 2 ./ex17 -dm_plex_box_faces 1,1,1 -sol_type elas_trig
> -dm_plex_dim 3 -dm_plex_simplex 0 -displacement_petscspace_degree 3
> -dm_refine 0 -convest_num_refine 1 -snes_convergence_estimate -snes_monitor
> *with the error message (--with-debugging=1):*
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: Cell 0 has not been assigned a cell type
Yes, I need to put some more checks for corner cases. You have a 1 element
mesh on 2 processes, so there is no cell 0, but I am expecting at least one
cell during setup. Give
  -dm_refine 1
or
  -dm_plex_box_faces 2,2,2
or something like that.
     Matt
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> be the program crashed before they were used or a spelling mistake, etc!
> [0]PETSC ERROR:   Option left: name:-convest_num_refine value: 1 source:
> command line
> [0]PETSC ERROR:   Option left: name:-displacement_petscspace_degree value:
> 3 source: command line
> [0]PETSC ERROR:   Option left: name:-snes_convergence_estimate (no value)
> [0]PETSC ERROR:   Option left: name:-snes_monitor (no value) source:
> command line
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.19.4, unknown
> [0]PETSC ERROR: ./ex17 on a DEBUG named ilya-HP-Notebook by ilya Wed Aug
>  9 19:23:02 2023
> [0]PETSC ERROR: Configure options PETSC_ARCH=DEBUG
> PETSC_DIR=/home/ilya/build/petsc-09aug-debug/petsc
> --with-blaslapack-dir=/home/ilya/progs/OpenBLAS-0.3.21
> --with-mpi-dir=/home/ilya/progs/openmpi-4.1.4 --with-debugging=1
> --download-hdf5 --download-hypre --download-chaco --download-metis
> --download-parmetis --download-suitesparse --download-moab --download-mumps
> --download-scalapack --download-superlu --download-superlu_dist
> --download-triangle --download-ml --download-giflib --download-libjpeg
> --download-libpng --download-zlib --download-spai --download-tchem
> --download-party --download-cmake --download-hwloc --download-ptscotch
> --download-revolve --download-cams --download-spai
> [0]PETSC ERROR: #1 DMPlexGetCellType() at
> /home/ilya/build/petsc-09aug-debug/petsc/src/dm/impls/plex/plex.c:5169
> [0]PETSC ERROR: #2 SetupFE() at ex17.c:621
> [0]PETSC ERROR: #3 main() at ex17.c:654
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -convest_num_refine 1 (source: command line)
> [0]PETSC ERROR: -displacement_petscspace_degree 3 (source: command line)
> [0]PETSC ERROR: -dm_plex_box_faces 1,1,1 (source: command line)
> [0]PETSC ERROR: -dm_plex_dim 3 (source: command line)
> [0]PETSC ERROR: -dm_plex_simplex 0 (source: command line)
> [0]PETSC ERROR: -dm_refine 0 (source: command line)
> [0]PETSC ERROR: -snes_convergence_estimate (source: command line)
> [0]PETSC ERROR: -snes_monitor (source: command line)
> [0]PETSC ERROR: -sol_type elas_trig (source: command line)
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> *And when --with-debugging=0, it fails with segmentation violation:*
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is
> causing the crash.
> Regards,
> Ilya
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230809/dbd95ca3/attachment.html>
