[petsc-users] Python PETSc performance vs scipy ZVODE
Niclas Götting ngoetting at itp.uni-bremen.de
Wed Aug 9 08:40:04 CDT 2023
Hi all,
I'm currently trying to convert a quantum simulation from scipy to
PETSc. The problem itself is extremely simple and of the form \dot{u}(t)
= (A_const + f(t)*B_const)*u(t), where f(t) in this simple test case is
a square function. The matrices A_const and B_const are extremely sparse
and therefore I thought, the problem will be well suited for PETSc.
Currently, I solve the ODE with the following procedure in scipy (I can
provide the necessary data files, if needed, but they are just some
trace-preserving, very sparse matrices):
import numpy as np
import scipy.sparse
import scipy.integrate
from tqdm import tqdm
l = np.load("../liouvillian.npy")
pump = np.load("../pump_operator.npy")
state = np.load("../initial_state.npy")
l = scipy.sparse.csr_array(l)
pump = scipy.sparse.csr_array(pump)
def f(t, y, *args):
     return (l + 0.5 * (5 < t < 10) * pump) @ y
     #return l @ y # Uncomment for f(t) = 0
dt = 0.1
NUM_STEPS = 200
res = np.empty((NUM_STEPS, 4096), dtype=np.complex128)
solver =
scipy.integrate.ode(f).set_integrator("zvode").set_initial_value(state)
times = []
for i in tqdm(range(NUM_STEPS)):
     res[i, :] = solver.integrate(solver.t + dt)
     times.append(solver.t)
Here, A_const = l, B_const = pump and f(t) = 5 < t < 10. tqdm reports
about 330it/s on my machine. When converting the code to PETSc, I came
to the following result (according to the chapter
https://petsc.org/main/manual/ts/#special-cases)
import sys
import petsc4py
petsc4py.init(args=sys.argv)
import numpy as np
import scipy.sparse
from petsc4py import PETSc
comm = PETSc.COMM_WORLD
def mat_to_real(arr):
     return np.block([[arr.real, -arr.imag], [arr.imag,
arr.real]]).astype(np.float64)
def mat_to_petsc_aij(arr):
     arr_sc_sp = scipy.sparse.csr_array(arr)
     mat = PETSc.Mat().createAIJ(arr.shape[0], comm=comm)
     rstart, rend = mat.getOwnershipRange()
     print(rstart, rend)
     print(arr.shape[0])
     print(mat.sizes)
     I = arr_sc_sp.indptr[rstart : rend + 1] - arr_sc_sp.indptr[rstart]
     J = arr_sc_sp.indices[arr_sc_sp.indptr[rstart] :
arr_sc_sp.indptr[rend]]
     V = arr_sc_sp.data[arr_sc_sp.indptr[rstart] : arr_sc_sp.indptr[rend]]
     print(I.shape, J.shape, V.shape)
     mat.setValuesCSR(I, J, V)
     mat.assemble()
     return mat
l = mat_to_real(l)
pump = mat_to_real(pump)
state = np.hstack([state.real, state.imag]).astype(np.float64)
l = mat_to_petsc_aij(l)
pump = mat_to_petsc_aij(pump)
jac = l.duplicate()
for i in range(8192):
     jac.setValue(i, i, 0)
jac.assemble()
jac += l
vec = l.createVecRight()
vec.setValues(np.arange(state.shape[0], dtype=np.int32), state)
vec.assemble()
dt = 0.1
ts = PETSc.TS().create(comm=comm)
ts.setFromOptions()
ts.setProblemType(ts.ProblemType.LINEAR)
ts.setEquationType(ts.EquationType.ODE_EXPLICIT)
ts.setType(ts.Type.RK)
ts.setRKType(ts.RKType.RK3BS)
ts.setTime(0)
print("KSP:", ts.getKSP().getType())
print("KSP PC:",ts.getKSP().getPC().getType())
print("SNES :", ts.getSNES().getType())
def jacobian(ts, t, u, Amat, Pmat):
     Amat.zeroEntries()
     Amat.aypx(1, l, structure=PETSc.Mat.Structure.SUBSET_NONZERO_PATTERN)
     Amat.axpy(0.5 * (5 < t < 10), pump,
ts.setRHSFunction(PETSc.TS.computeRHSFunctionLinear)
#ts.setRHSJacobian(PETSc.TS.computeRHSJacobianConstant, l, l) #
ts.setRHSJacobian(jacobian, jac)
NUM_STEPS = 200
res = np.empty((NUM_STEPS, 8192), dtype=np.float64)
times = []
rstart, rend = vec.getOwnershipRange()
     time = ts.getTime()
     ts.setMaxTime(time + dt)
     ts.solve(vec)
     res[i, rstart:rend] = vec.getArray()[:]
     times.append(time)
I decomposed the complex ODE into a larger real ODE, so that I can
easily switch maybe to GPU computation later on. Now, the solutions of
both scripts are very much identical, but PETSc runs about 3 times
slower at 120it/s on my machine. I don't use MPI for PETSc yet.
I strongly suppose that the problem lies within the jacobian definition,
as PETSc is about 3 times *faster* than scipy with f(t) = 0 and
therefore a constant jacobian.
Thank you in advance.
All the best,
Niclas
