[petsc-users] DMPlex edge/vertex orientation
Fri Aug 4 11:49:37 CDT 2023
On Fri, Aug 4, 2023 at 12:06 PM onur.notonur via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I'm currently working with 3D DMPlex and performing crucial calculations
> involving face normals and edge tangents. I've noticed that face normals
> are directed from support[0] to support[1].
That is an accident of implementation and not enforced.
> However, I'm uncertain about the conventions for edges and vertices in
> relation to faces. Specifically, I need to determine the order of vertices
> that create a surface and whether they are stored in a counter-clockwise
> (CCW) or clockwise (CW) manner. As DMPlex follows a hierarchy of
> cell-face-edge-vertex, my main question becomes about the orientation of
> edges. Any clarification on this aspect would be immensely helpful!
1) All computed quantities follow the closure ordering, namely that the
order that vertices come out in the DMPlexGetTransitiveClosure() call is
the one used for computing.
2) Closures are always ordered to produce outward normals
3) Since we build k-cells out of k-1 cells, the k-1 cells _already_ have an
ordering before I make my k-cell. Thus I have to tell you how to order the
k-1 cell, with respect to its closure ordering, when you are building your
k-cell. This is what an "orientation" is, namely a representation of the
dihedral group for that k-1 cell.
Example: A segment has two orientations, which we label 0 and -1. When we
build a triangle out of segments, we order them counter-clockwise, so that
the normals are all outward. The same thing is done
for quads.
Triangles have 6 orientations, all the permutations of the edges. We pick
one when making tetrahedra such that the normals are outward _and_ the
vertices are in the closure order.
> Additionally, I'm unfamiliar with most of the terms used in DMPlex. For
> example "orientation" in DMPlexGetConeOrientation. If you could suggest
> some readings or resources that explain these concepts, I would greatly
> appreciate it.
I am finishing up my book on it, which I will post. To start, here is a
paper
  https://arxiv.org/abs/2004.08729
      Matt
> Thx,
> Onur
> Sent with Proton Mail <https://proton.me/> secure email.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230804/d0b6dfde/attachment-0001.html>
