[petsc-users] matshell for spectral methods in fortran
Luv Sharma luvsharma11 at gmail.com
Tue May 23 14:36:12 CDT 2017
Dear Barry,
Thanks for your quick reply.
I have tried following:
module spectral_mech_basic
 implicit none
 private
#include <petsc/finclude/petsc.h90>
! *PETSc data here*
 DM ..
 SNES ..
contains
subroutine basicPETSc_init
 external :: &
   *petsc functions here*
! initialize solver specific parts of PETSc
 call SNESCreate(PETSC_COMM_WORLD,snes,ierr); CHKERRQ(ierr)
 call SNESSetOptionsPrefix(snes,'mech_',ierr);CHKERRQ(ierr)
 call DMDACreate3d(PETSC_COMM_WORLD, &
        DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, &
        DMDA_STENCIL_BOX, &
        grid(1),grid(2),grid(3), &
        1 , 1, worldsize, &
        9, 0, &
        grid(1),grid(2),localK, &
        da,ierr)
 CHKERRQ(ierr)
 call SNESSetDM(snes,da,ierr); CHKERRQ(ierr)
 call DMCreateGlobalVector(da,solution_vec,ierr); CHKERRQ(ierr)
 call DMDASNESSetFunctionLocal(da,INSERT_VALUES,BasicPETSC_formResidual,PETSC_NULL_OBJECT,ierr)
 CHKERRQ(ierr)
 !call DMCreateMatrix(da,J_shell,ierr)
 !CHKERRQ(ierr)
 !call DMSetMatType(da,MATSHELL,ierr)
 !CHKERRQ(ierr)
 !call DMSNESSetJacobianLocal(da,SPEC_mech_formJacobian,PETSC_NULL_OBJECT,ierr)                 !< function to evaluate stiffness matrix
 !CHKERRQ(ierr)
 matsize = 9_pInt*grid(1)*grid(2)*grid(3)
 call MatCreateShell( PETSC_COMM_WORLD, matsize, matsize, matsize, matsize, PETSC_NULL_OBJECT, J_shell, ierr )
 CHKERRQ(ierr)
 call SNESSetJacobian( snes, J_shell, J_shell, SPEC_mech_formJacobian, PETSC_NULL_OBJECT, ierr)
 CHKERRQ(ierr)
 call MatShellSetOperation(J_shell, MATOP_MULT, jac_shell, ierr )
 CHKERRQ(ierr)
 call SNESGetKSP(snes,ksp,ierr); CHKERRQ(ierr)
 call KSPGetPC(ksp,pc,ierr); CHKERRQ(ierr)
 call PCSetType(pc,PCNONE,ierr); CHKERRQ(ierr)
 call SNESSetFromOptions(snes,ierr); CHKERRQ(ierr)
! init fields
 call DMDAVecGetArrayF90(da,solution_vec,F,ierr); CHKERRQ(ierr)
 call DMDAVecRestoreArrayF90(da,solution_vec,F,ierr); CHKERRQ(ierr)
end subroutine basicPETSc_init
type(tSolutionState) function &
  basicPETSc_solution(incInfoIn,timeinc,timeinc_old,stress_BC,rotation_BC)
 implicit none
! PETSc Data
 PetscErrorCode :: ierr
 SNESConvergedReason :: reason
 external :: &
   SNESSolve, &
! solve BVP
 call SNESSolve(snes,PETSC_NULL_OBJECT,solution_vec,ierr)
 CHKERRQ(ierr)
end function BasicPETSc_solution
!> @brief forms the basic residual vector
subroutine BasicPETSC_formResidual(in,x_scal,f_scal,dummy,ierr)
 implicit none
 DMDALocalInfo, dimension(DMDA_LOCAL_INFO_SIZE) :: &
   in
 PetscScalar, dimension(3,3, &
   XG_RANGE,YG_RANGE,ZG_RANGE), intent(in) :: &
   x_scal
   X_RANGE,Y_RANGE,Z_RANGE), intent(out) :: &
   f_scal
! constructing residual
 f_scal = tensorField_real(1:3,1:3,1:grid(1),1:grid(2),1:grid3)
end subroutine BasicPETSc_formResidual
!> @brief matmult routine
    ! a shell jacobian; returns the action J*v
subroutine jac_shell(Jshell,v_in,v_out)
 use math, only: &
   math_rotate_backward33, &
   math_transpose33, &
   math_mul3333xx33
 use mesh, only: &
   grid, &
   grid3
 use spectral_utilities, only: &
   wgt, &
   tensorField_real, &
   utilities_FFTtensorForward, &
   utilities_fourierGammaConvolution, &
   utilities_FFTtensorBackward, &
   Utilities_constitutiveResponse, &
   Utilities_divergenceRMS
 implicit none
! DMDALocalInfo, dimension(DMDA_LOCAL_INFO_SIZE) :: &
!   in
   1000,1,1), intent(in) :: &
   v_in
   1000,1,1), intent(out) :: &
   v_out
 Mat                  :: Jshell
 integer(pInt) :: &
   i,j,k,e
 e = 0_pInt
 tensorField_real = 0.0_pReal
 print*, SHAPE(v_in)
 print*, SHAPE(v_out)
 do k = 1_pInt, grid3; do j = 1_pInt, grid(2); do i = 1_pInt, grid(1)
  e = e + 1_pInt
  tensorField_real(1:3,1:3,i,j,k) =  j*v
 enddo; enddo; enddo
 call utilities_FFTtensorForward()
 call utilities_fourierGammaConvolution()
 call utilities_FFTtensorBackward()
 v_out = tensorField_real(1:3,1:3,1:grid(1),1:grid(2),1:grid3)
end subroutine jac_shell
subroutine SPEC_mech_formJacobian(snes,xx_local,Jac_pre,Jac,dummy,ierr)
 implicit none
 SNES            :: snes
 DM                                   :: dm_local
 Vec                                  :: x_local, xx_local
 Mat                                  :: Jac_pre, Jac
 PetscObject                          :: dummy
end subroutine SPEC_mech_formJacobian
end module spectral_mech_basic
Best regards,
Luv
> On 23 May 2017, at 21:16, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   You didn't include any code related to creating or setting the MATSHELL.  What goes wrong with your Fortran code.
>> On May 23, 2017, at 2:05 PM, Luv Sharma <luvsharma11 at gmail.com> wrote:
>> Dear PETSc team,
>> I am working on a code which solves mechanical equilibrium using spectral methods.
>> I want to make use of the matshell to get the action J*v.
>> I have been able to successfully implement it using petsc4py. But having difficulties to get it working in a fortran code.
>> I am using petsc-3.7.6.
>> Below is a stripped down version of the existing fortran code (module). Can you please help me in figuring out how the right way to do it a code with following structure?
>> implicit none
>> private
>> ! *PETSc data here*
>> DM ..
>> SNES ..
>> contains
>> external :: &
>>        DMDA_STENCIL_BOX, &
>>        1 , 1, worldsize, &
>>        9, 0, &
>>        da,ierr)
>> CHKERRQ(ierr)
>> CHKERRQ(ierr)
>> ! init fields
>> implicit none
>> ! PETSc Data
>> external :: &
>>   SNESSolve, &
>> ! solve BVP
>> CHKERRQ(ierr)
>> implicit none
>>   in
>>   x_scal
>>   f_scal
>> Best regards,
>> Luv
>>> On 3 Nov 2016, at 01:17, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Is anyone away of cases where PETSc has been used with spectral methods?
>>>  Thanks
>>>   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170523/8ee73acf/attachment-0001.html>
