[petsc-users] matshell for spectral methods in fortran
Tue May 23 15:20:11 CDT 2017
   I cannot easily see why this would or wouldn't work. If you send me the entire code as an attachment and makefile I can try to run it.
   Barry
> On May 23, 2017, at 2:36 PM, Luv Sharma <luvsharma11 at gmail.com> wrote:
> Dear Barry,
> Thanks for your quick reply.
> I have tried following:
> module spectral_mech_basic
>  implicit none
>  private
> #include <petsc/finclude/petsc.h90>
> ! *PETSc data here*
>  DM ..
>  SNES ..
> contains
> subroutine basicPETSc_init
>  external :: &
>    *petsc functions here*
> ! initialize solver specific parts of PETSc
>  call SNESCreate(PETSC_COMM_WORLD,snes,ierr); CHKERRQ(ierr)
>  call SNESSetOptionsPrefix(snes,'mech_',ierr);CHKERRQ(ierr)
>  call DMDACreate3d(PETSC_COMM_WORLD, &
>         DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, &
>         DMDA_STENCIL_BOX, &
>         grid(1),grid(2),grid(3), &
>         1 , 1, worldsize, &
>         9, 0, &
>         grid(1),grid(2),localK, &
>         da,ierr)
>  CHKERRQ(ierr)
>  call SNESSetDM(snes,da,ierr); CHKERRQ(ierr)
>  call DMCreateGlobalVector(da,solution_vec,ierr); CHKERRQ(ierr)
>  call DMDASNESSetFunctionLocal(da,INSERT_VALUES,BasicPETSC_formResidual,PETSC_NULL_OBJECT,ierr)
>  CHKERRQ(ierr)
>  !call DMCreateMatrix(da,J_shell,ierr)
>  !CHKERRQ(ierr)
>  !call DMSetMatType(da,MATSHELL,ierr)
>  !CHKERRQ(ierr)
>  !call DMSNESSetJacobianLocal(da,SPEC_mech_formJacobian,PETSC_NULL_OBJECT,ierr)                 !< function to evaluate stiffness matrix
>  !CHKERRQ(ierr)
>  matsize = 9_pInt*grid(1)*grid(2)*grid(3)
>  call MatCreateShell( PETSC_COMM_WORLD, matsize, matsize, matsize, matsize, PETSC_NULL_OBJECT, J_shell, ierr )
>  CHKERRQ(ierr)
>  call SNESSetJacobian( snes, J_shell, J_shell, SPEC_mech_formJacobian, PETSC_NULL_OBJECT, ierr)
>  CHKERRQ(ierr)
>  call MatShellSetOperation(J_shell, MATOP_MULT, jac_shell, ierr )
>  CHKERRQ(ierr)
>  call SNESGetKSP(snes,ksp,ierr); CHKERRQ(ierr)
>  call KSPGetPC(ksp,pc,ierr); CHKERRQ(ierr)
>  call PCSetType(pc,PCNONE,ierr); CHKERRQ(ierr)
>  call SNESSetFromOptions(snes,ierr); CHKERRQ(ierr)
> ! init fields
>  call DMDAVecGetArrayF90(da,solution_vec,F,ierr); CHKERRQ(ierr)
>  call DMDAVecRestoreArrayF90(da,solution_vec,F,ierr); CHKERRQ(ierr)
> end subroutine basicPETSc_init
> type(tSolutionState) function &
>   basicPETSc_solution(incInfoIn,timeinc,timeinc_old,stress_BC,rotation_BC)
>  implicit none
> ! PETSc Data
>  PetscErrorCode :: ierr
>  SNESConvergedReason :: reason
>  external :: &
>    SNESSolve, &
> ! solve BVP
>  call SNESSolve(snes,PETSC_NULL_OBJECT,solution_vec,ierr)
>  CHKERRQ(ierr)
> end function BasicPETSc_solution
> !> @brief forms the basic residual vector
> subroutine BasicPETSC_formResidual(in,x_scal,f_scal,dummy,ierr)
>  implicit none
>  DMDALocalInfo, dimension(DMDA_LOCAL_INFO_SIZE) :: &
>    in
>  PetscScalar, dimension(3,3, &
>    XG_RANGE,YG_RANGE,ZG_RANGE), intent(in) :: &
>    x_scal
>    X_RANGE,Y_RANGE,Z_RANGE), intent(out) :: &
>    f_scal
> ! constructing residual
>  f_scal = tensorField_real(1:3,1:3,1:grid(1),1:grid(2),1:grid3)
> end subroutine BasicPETSc_formResidual
> !> @brief matmult routine
>     ! a shell jacobian; returns the action J*v
> subroutine jac_shell(Jshell,v_in,v_out)
>  use math, only: &
>    math_rotate_backward33, &
>    math_transpose33, &
>    math_mul3333xx33
>  use mesh, only: &
>    grid, &
>    grid3
>  use spectral_utilities, only: &
>    wgt, &
>    tensorField_real, &
>    utilities_FFTtensorForward, &
>    utilities_fourierGammaConvolution, &
>    utilities_FFTtensorBackward, &
>    Utilities_constitutiveResponse, &
>    Utilities_divergenceRMS
>  implicit none
> ! DMDALocalInfo, dimension(DMDA_LOCAL_INFO_SIZE) :: &
> !   in
>    1000,1,1), intent(in) :: &
>    v_in
>    1000,1,1), intent(out) :: &
>    v_out
>  Mat                  :: Jshell
>  integer(pInt) :: &
>    i,j,k,e
>  e = 0_pInt
>  tensorField_real = 0.0_pReal
>  print*, SHAPE(v_in)
>  print*, SHAPE(v_out)
>  do k = 1_pInt, grid3; do j = 1_pInt, grid(2); do i = 1_pInt, grid(1)
>   e = e + 1_pInt
>   tensorField_real(1:3,1:3,i,j,k) =  j*v
>  enddo; enddo; enddo
>  call utilities_FFTtensorForward()
>  call utilities_fourierGammaConvolution()
>  call utilities_FFTtensorBackward()
>  v_out = tensorField_real(1:3,1:3,1:grid(1),1:grid(2),1:grid3)
> end subroutine jac_shell
> subroutine SPEC_mech_formJacobian(snes,xx_local,Jac_pre,Jac,dummy,ierr)
>  implicit none
>  SNES            :: snes
>  DM                                   :: dm_local
>  Vec                                  :: x_local, xx_local
>  Mat                                  :: Jac_pre, Jac
>  PetscObject                          :: dummy
> end subroutine SPEC_mech_formJacobian
> end module spectral_mech_basic
> Best regards,
> Luv
>> On 23 May 2017, at 21:16, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   You didn't include any code related to creating or setting the MATSHELL.  What goes wrong with your Fortran code.
>>> On May 23, 2017, at 2:05 PM, Luv Sharma <luvsharma11 at gmail.com> wrote:
>>> Dear PETSc team,
>>> I am working on a code which solves mechanical equilibrium using spectral methods.
>>> I want to make use of the matshell to get the action J*v.
>>> I have been able to successfully implement it using petsc4py. But having difficulties to get it working in a fortran code.
>>> I am using petsc-3.7.6.
>>> Below is a stripped down version of the existing fortran code (module). Can you please help me in figuring out how the right way to do it a code with following structure?
>>> implicit none
>>> private
>>> ! *PETSc data here*
>>> DM ..
>>> SNES ..
>>> contains
>>> external :: &
>>>        DMDA_STENCIL_BOX, &
>>>        1 , 1, worldsize, &
>>>        9, 0, &
>>>        da,ierr)
>>> CHKERRQ(ierr)
>>> CHKERRQ(ierr)
>>> ! init fields
>>> implicit none
>>> ! PETSc Data
>>> external :: &
>>>   SNESSolve, &
>>> ! solve BVP
>>> CHKERRQ(ierr)
>>> implicit none
>>>   in
>>>   x_scal
>>>   f_scal
>>> Best regards,
>>> Luv
>>>> On 3 Nov 2016, at 01:17, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Is anyone away of cases where PETSc has been used with spectral methods?
>>>>  Thanks
>>>>   Barry
