[petsc-users] matshell for spectral methods in fortran
Tue May 23 14:16:27 CDT 2017
   You didn't include any code related to creating or setting the MATSHELL.  What goes wrong with your Fortran code.
> On May 23, 2017, at 2:05 PM, Luv Sharma <luvsharma11 at gmail.com> wrote:
> Dear PETSc team,
> I am working on a code which solves mechanical equilibrium using spectral methods.
> I want to make use of the matshell to get the action J*v.
> I have been able to successfully implement it using petsc4py. But having difficulties to get it working in a fortran code.
> I am using petsc-3.7.6.
> Below is a stripped down version of the existing fortran code (module). Can you please help me in figuring out how the right way to do it a code with following structure?
> module spectral_mech_basic
>  implicit none
>  private
> #include <petsc/finclude/petsc.h90>
> ! *PETSc data here*
>  DM ..
>  SNES ..
> contains
> subroutine basicPETSc_init
>  external :: &
>    *petsc functions here*
> ! initialize solver specific parts of PETSc
>  call SNESCreate(PETSC_COMM_WORLD,snes,ierr); CHKERRQ(ierr)
>  call SNESSetOptionsPrefix(snes,'mech_',ierr);CHKERRQ(ierr)
>  call DMDACreate3d(PETSC_COMM_WORLD, &
>         DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, &
>         DMDA_STENCIL_BOX, &
>         grid(1),grid(2),grid(3), &
>         1 , 1, worldsize, &
>         9, 0, &
>         grid(1),grid(2),localK, &
>         da,ierr)
>  CHKERRQ(ierr)
>  call SNESSetDM(snes,da,ierr); CHKERRQ(ierr)
>  call DMCreateGlobalVector(da,solution_vec,ierr); CHKERRQ(ierr)
>  call DMDASNESSetFunctionLocal(da,INSERT_VALUES,BasicPETSC_formResidual,PETSC_NULL_OBJECT,ierr)
>  CHKERRQ(ierr)
>  call SNESGetKSP(snes,ksp,ierr); CHKERRQ(ierr)
>  call KSPGetPC(ksp,pc,ierr); CHKERRQ(ierr)
>  call PCSetType(pc,PCNONE,ierr); CHKERRQ(ierr)
>  call SNESSetFromOptions(snes,ierr); CHKERRQ(ierr)
> ! init fields
>  call DMDAVecGetArrayF90(da,solution_vec,F,ierr); CHKERRQ(ierr)
>  call DMDAVecRestoreArrayF90(da,solution_vec,F,ierr); CHKERRQ(ierr)
> end subroutine basicPETSc_init
> type(tSolutionState) function &
>   basicPETSc_solution(incInfoIn,timeinc,timeinc_old,stress_BC,rotation_BC)
>  implicit none
> ! PETSc Data
>  PetscErrorCode :: ierr
>  SNESConvergedReason :: reason
>  external :: &
>    SNESSolve, &
> ! solve BVP
>  call SNESSolve(snes,PETSC_NULL_OBJECT,solution_vec,ierr)
>  CHKERRQ(ierr)
> end function BasicPETSc_solution
> !> @brief forms the basic residual vector
> subroutine BasicPETSC_formResidual(in,x_scal,f_scal,dummy,ierr)
>  implicit none
>  DMDALocalInfo, dimension(DMDA_LOCAL_INFO_SIZE) :: &
>    in
>  PetscScalar, dimension(3,3, &
>    XG_RANGE,YG_RANGE,ZG_RANGE), intent(in) :: &
>    x_scal
>    X_RANGE,Y_RANGE,Z_RANGE), intent(out) :: &
>    f_scal
> ! constructing residual
>  f_scal = tensorField_real(1:3,1:3,1:grid(1),1:grid(2),1:grid3)
> end subroutine BasicPETSc_formResidual
> end module spectral_mech_basic
> Best regards,
> Luv
>> On 3 Nov 2016, at 01:17, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Is anyone away of cases where PETSc has been used with spectral methods?
>>   Thanks
>>    Barry
