[petsc-users] matshell for spectral methods in fortran
Luv Sharma luvsharma11 at gmail.com
Tue May 23 14:05:08 CDT 2017
Dear PETSc team,
I am working on a code which solves mechanical equilibrium using spectral methods.
I want to make use of the matshell to get the action J*v.
I have been able to successfully implement it using petsc4py. But having difficulties to get it working in a fortran code.
I am using petsc-3.7.6.
Below is a stripped down version of the existing fortran code (module). Can you please help me in figuring out how the right way to do it a code with following structure?
module spectral_mech_basic
 implicit none
 private
#include <petsc/finclude/petsc.h90>
! *PETSc data here*
 DM ..
 SNES ..
contains
subroutine basicPETSc_init
 external :: &
   *petsc functions here*
! initialize solver specific parts of PETSc
 call SNESCreate(PETSC_COMM_WORLD,snes,ierr); CHKERRQ(ierr)
 call SNESSetOptionsPrefix(snes,'mech_',ierr);CHKERRQ(ierr)
 call DMDACreate3d(PETSC_COMM_WORLD, &
        DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, DM_BOUNDARY_NONE, &
        DMDA_STENCIL_BOX, &
        grid(1),grid(2),grid(3), &
        1 , 1, worldsize, &
        9, 0, &
        grid(1),grid(2),localK, &
        da,ierr)
 CHKERRQ(ierr)
 call SNESSetDM(snes,da,ierr); CHKERRQ(ierr)
 call DMCreateGlobalVector(da,solution_vec,ierr); CHKERRQ(ierr)
 call DMDASNESSetFunctionLocal(da,INSERT_VALUES,BasicPETSC_formResidual,PETSC_NULL_OBJECT,ierr)
 CHKERRQ(ierr)
 call SNESGetKSP(snes,ksp,ierr); CHKERRQ(ierr)
 call KSPGetPC(ksp,pc,ierr); CHKERRQ(ierr)
 call PCSetType(pc,PCNONE,ierr); CHKERRQ(ierr)
 call SNESSetFromOptions(snes,ierr); CHKERRQ(ierr)
! init fields
 call DMDAVecGetArrayF90(da,solution_vec,F,ierr); CHKERRQ(ierr)
 call DMDAVecRestoreArrayF90(da,solution_vec,F,ierr); CHKERRQ(ierr)
end subroutine basicPETSc_init
type(tSolutionState) function &
  basicPETSc_solution(incInfoIn,timeinc,timeinc_old,stress_BC,rotation_BC)
 implicit none
! PETSc Data
 PetscErrorCode :: ierr
 SNESConvergedReason :: reason
 external :: &
   SNESSolve, &
! solve BVP
 call SNESSolve(snes,PETSC_NULL_OBJECT,solution_vec,ierr)
 CHKERRQ(ierr)
end function BasicPETSc_solution
!> @brief forms the basic residual vector
subroutine BasicPETSC_formResidual(in,x_scal,f_scal,dummy,ierr)
 implicit none
 DMDALocalInfo, dimension(DMDA_LOCAL_INFO_SIZE) :: &
   in
 PetscScalar, dimension(3,3, &
   XG_RANGE,YG_RANGE,ZG_RANGE), intent(in) :: &
   x_scal
   X_RANGE,Y_RANGE,Z_RANGE), intent(out) :: &
   f_scal
! constructing residual
 f_scal = tensorField_real(1:3,1:3,1:grid(1),1:grid(2),1:grid3)
end subroutine BasicPETSc_formResidual
end module spectral_mech_basic
Best regards,
Luv
> On 3 Nov 2016, at 01:17, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Is anyone away of cases where PETSc has been used with spectral methods?
>   Thanks
>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170523/3c865a59/attachment-0001.html>
