[petsc-users] conflict between petsc.h90 and MPI_INT, MPI_SUM etc...
Tue Jan 31 10:21:13 CST 2017
This is petsc-3.7?
Looks like mpif.h is getting included in some module that your code
is currently using.
Is this module your code - or petsc code?
Is using mpi via module [perhaps mpi.mod is preferable over mpif.h] -
then you can do something like:
#define PETSC_AVOID_MPIF_H
#include <petsc/finclude/petsc.h90>
Satish
On Tue, 31 Jan 2017, Timothée Nicolas wrote:
> Dear all,
> I am a bit confused as to how to link PETSc correctly in a code that
> already uses MPI natively. I wish to define a DMDA for my problem, but when
> I try to include petsc.h90, the compiler complains that MPI_XXXXX variables
> are already defined:
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(9): error #6401: The
> attributes of this name conflict with those made accessible by a USE
> statement.   [MPI_SOURCE]
>        INTEGER MPI_SOURCE, MPI_TAG, MPI_ERROR
> statement.   [MPI_TAG]
> statement.   [MPI_ERROR]
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(11): error #6401: The
> statement.   [MPI_STATUS_SIZE]
>        INTEGER MPI_STATUS_SIZE
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(13): error #6401: The
> statement.   [MPI_STATUS_IGNORE]
>        INTEGER MPI_STATUS_IGNORE(MPI_STATUS_SIZE)
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(14): error #6401: The
> statement.   [MPI_STATUSES_IGNORE]
>        INTEGER MPI_STATUSES_IGNORE(MPI_STATUS_SIZE,1)
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(15): error #6401: The
> statement.   [MPI_ERRCODES_IGNORE]
>        INTEGER MPI_ERRCODES_IGNORE(1)
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(16): error #6401: The
> statement.   [MPI_ARGVS_NULL]
>        CHARACTER*1 MPI_ARGVS_NULL(1,1)
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(17): error #6401: The
> statement.   [MPI_ARGV_NULL]
>        CHARACTER*1 MPI_ARGV_NULL(1)
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(18): error #6401: The
> statement.   [MPI_SUCCESS]
>        INTEGER MPI_SUCCESS
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(20): error #6401: The
> statement.   [MPI_ERR_SIZE]
>        INTEGER MPI_ERR_SIZE
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(22): error #6401: The
> statement.   [MPI_ERR_INFO_KEY]
>        INTEGER MPI_ERR_INFO_KEY
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(24): error #6401: The
> statement.   [MPI_ERR_FILE]
>        INTEGER MPI_ERR_FILE
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(26): error #6401: The
> statement.   [MPI_ERR_AMODE]
>        INTEGER MPI_ERR_AMODE
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(28): error #6401: The
> statement.   [MPI_ERR_TRUNCATE]
>        INTEGER MPI_ERR_TRUNCATE
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(30): error #6401: The
> statement.   [MPI_ERR_BASE]
>        INTEGER MPI_ERR_BASE
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(32): error #6401: The
> statement.   [MPI_ERR_OP]
>        INTEGER MPI_ERR_OP
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(34): error #6401: The
> statement.   [MPI_ERR_ASSERT]
>        INTEGER MPI_ERR_ASSERT
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(36): error #6401: The
> statement.   [MPI_ERR_NAME]
>        INTEGER MPI_ERR_NAME
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(38): error #6401: The
> statement.   [MPI_ERR_NO_MEM]
>        INTEGER MPI_ERR_NO_MEM
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(40): error #6401: The
> statement.   [MPI_ERR_INFO]
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(42): error #6401: The
> statement.   [MPI_ERR_COUNT]
>        INTEGER MPI_ERR_COUNT
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(44): error #6401: The
> statement.   [MPI_ERR_SPAWN]
>        INTEGER MPI_ERR_SPAWN
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(46): error #6401: The
> statement.   [MPI_ERR_CONVERSION]
>        INTEGER MPI_ERR_CONVERSION
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(48): error #6401: The
> statement.   [MPI_ERR_GROUP]
>        INTEGER MPI_ERR_GROUP
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(50): error #6401: The
> statement.   [MPI_ERR_RMA_SYNC]
>        INTEGER MPI_ERR_RMA_SYNC
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(52): error #6401: The
> statement.   [MPI_ERR_NOT_SAME]
>        INTEGER MPI_ERR_NOT_SAME
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(54): error #6401: The
> statement.   [MPI_ERR_KEYVAL]
>        INTEGER MPI_ERR_KEYVAL
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(56): error #6401: The
> statement.   [MPI_ERR_ACCESS]
>        INTEGER MPI_ERR_ACCESS
> /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(58): error #6401: The
> statement.   [MPI_ERR_DIMS]
>        INTEGER MPI_ERR_DIMS
> I usually write everything consistently within PETSc, but for the first
> time, I have to use some PETSc routines in a code that is mostly standard
> FORTRAN 90.
> Is including PETSc via #include <petsc/finclude/petscdef.h> the wrong
> method?
> Best
> Timothee
