[petsc-users] conflict between petsc.h90 and MPI_INT, MPI_SUM etc...
Timothée Nicolas timothee.nicolas at gmail.com
Tue Jan 31 10:26:34 CST 2017
Thank you! Yes it is 3.7
 Indeed I found that there was a 'use mpi'  somewhere in the tree of
modules called. I could break the module apart without great difficulty, so
that I don't call mpi anymore in the affected portion of the code. It looks
like it indeed fixes the issue. But it's also nice to give me the other
solution with PETSC_AVOID_MPIF_H, which could have been very useful if I
hadn't been able to easily break the module apart.
Cheers
Timothee
2017-01-31 17:21 GMT+01:00 Satish Balay <balay at mcs.anl.gov>:
> This is petsc-3.7?
> Looks like mpif.h is getting included in some module that your code
> is currently using.
> Is this module your code - or petsc code?
> Is using mpi via module [perhaps mpi.mod is preferable over mpif.h] -
> then you can do something like:
> #define PETSC_AVOID_MPIF_H
> #include <petsc/finclude/petsc.h90>
> Satish
> On Tue, 31 Jan 2017, Timothée Nicolas wrote:
> > Dear all,
> > I am a bit confused as to how to link PETSc correctly in a code that
> > already uses MPI natively. I wish to define a DMDA for my problem, but
> when
> > I try to include petsc.h90, the compiler complains that MPI_XXXXX
> variables
> > are already defined:
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(9): error #6401: The
> > attributes of this name conflict with those made accessible by a USE
> > statement.   [MPI_SOURCE]
> >        INTEGER MPI_SOURCE, MPI_TAG, MPI_ERROR
> > statement.   [MPI_TAG]
> > statement.   [MPI_ERROR]
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(11): error #6401: The
> > statement.   [MPI_STATUS_SIZE]
> >        INTEGER MPI_STATUS_SIZE
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(13): error #6401: The
> > statement.   [MPI_STATUS_IGNORE]
> >        INTEGER MPI_STATUS_IGNORE(MPI_STATUS_SIZE)
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(14): error #6401: The
> > statement.   [MPI_STATUSES_IGNORE]
> >        INTEGER MPI_STATUSES_IGNORE(MPI_STATUS_SIZE,1)
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(15): error #6401: The
> > statement.   [MPI_ERRCODES_IGNORE]
> >        INTEGER MPI_ERRCODES_IGNORE(1)
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(16): error #6401: The
> > statement.   [MPI_ARGVS_NULL]
> >        CHARACTER*1 MPI_ARGVS_NULL(1,1)
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(17): error #6401: The
> > statement.   [MPI_ARGV_NULL]
> >        CHARACTER*1 MPI_ARGV_NULL(1)
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(18): error #6401: The
> > statement.   [MPI_SUCCESS]
> >        INTEGER MPI_SUCCESS
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(20): error #6401: The
> > statement.   [MPI_ERR_SIZE]
> >        INTEGER MPI_ERR_SIZE
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(22): error #6401: The
> > statement.   [MPI_ERR_INFO_KEY]
> >        INTEGER MPI_ERR_INFO_KEY
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(24): error #6401: The
> > statement.   [MPI_ERR_FILE]
> >        INTEGER MPI_ERR_FILE
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(26): error #6401: The
> > statement.   [MPI_ERR_AMODE]
> >        INTEGER MPI_ERR_AMODE
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(28): error #6401: The
> > statement.   [MPI_ERR_TRUNCATE]
> >        INTEGER MPI_ERR_TRUNCATE
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(30): error #6401: The
> > statement.   [MPI_ERR_BASE]
> >        INTEGER MPI_ERR_BASE
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(32): error #6401: The
> > statement.   [MPI_ERR_OP]
> >        INTEGER MPI_ERR_OP
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(34): error #6401: The
> > statement.   [MPI_ERR_ASSERT]
> >        INTEGER MPI_ERR_ASSERT
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(36): error #6401: The
> > statement.   [MPI_ERR_NAME]
> >        INTEGER MPI_ERR_NAME
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(38): error #6401: The
> > statement.   [MPI_ERR_NO_MEM]
> >        INTEGER MPI_ERR_NO_MEM
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(40): error #6401: The
> > statement.   [MPI_ERR_INFO]
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(42): error #6401: The
> > statement.   [MPI_ERR_COUNT]
> >        INTEGER MPI_ERR_COUNT
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(44): error #6401: The
> > statement.   [MPI_ERR_SPAWN]
> >        INTEGER MPI_ERR_SPAWN
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(46): error #6401: The
> > statement.   [MPI_ERR_CONVERSION]
> >        INTEGER MPI_ERR_CONVERSION
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(48): error #6401: The
> > statement.   [MPI_ERR_GROUP]
> >        INTEGER MPI_ERR_GROUP
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(50): error #6401: The
> > statement.   [MPI_ERR_RMA_SYNC]
> >        INTEGER MPI_ERR_RMA_SYNC
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(52): error #6401: The
> > statement.   [MPI_ERR_NOT_SAME]
> >        INTEGER MPI_ERR_NOT_SAME
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(54): error #6401: The
> > statement.   [MPI_ERR_KEYVAL]
> >        INTEGER MPI_ERR_KEYVAL
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(56): error #6401: The
> > statement.   [MPI_ERR_ACCESS]
> >        INTEGER MPI_ERR_ACCESS
> > /cm/shared/apps/mpich/ge/intel/3.2/include/mpif.h(58): error #6401: The
> > statement.   [MPI_ERR_DIMS]
> >        INTEGER MPI_ERR_DIMS
> > I usually write everything consistently within PETSc, but for the first
> > time, I have to use some PETSc routines in a code that is mostly standard
> > FORTRAN 90.
> > Is including PETSc via #include <petsc/finclude/petscdef.h> the wrong
> > method?
> > Best
> > Timothee
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170131/1e56b64c/attachment.html>
